Το DVR106 δεν γράφει δισκάκια ΤΥ!!!!!
paokaras45
Για λογους που αφορουσαν σε προσωπικα δεδομενα κανω εγω ποστ το log του nero του χρηστη paokara45
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 5:35:34 μμ
Nero version: 6.6.0.3
Recorder: <PIONEER DVD-RW DVR-106D>Version: 1.08 - HA 1 TA 0 - 6.6.0.3
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <CREATIVE CD5233E >Version: 1.00 - HA 1 TA 1 - 6.6.0.3
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1200JB-00DUA3 atapi Port 0 ID 0 DMA: On
DiskPeripheral : IC35L060AVVA07-0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-106D atapi Port 1 ID 0 DMA: On
CdRomPeripheral : CREATIVE CD5233E atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-106D E: CDRom0
CREATIVE CD5233E F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 174MB (178248kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.6.2005
ISO compilation
12:35:09 πμ #1 Text 0 File Isodoc.cpp, Line 6168
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:35:09 πμ #2 Text 0 File Reader.cpp, Line 127
Reader running
12:35:09 πμ #3 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-106D running
12:35:09 πμ #4 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
12:35:09 πμ #5 Text 0 File Burncd.cpp, Line 3151
Turn on Disc-at-once, using DVD media
12:35:09 πμ #6 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 910025 (202:13.50, 1777MB)
12:35:09 πμ #7 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO (enabled: CD)
12:35:09 πμ #8 Text 0 File DlgWaitCD.cpp, Line 2309
Recorder: PIONEER DVD-RW DVR-106D, Media type: DVD+R
Disc Manufacturer ID: YUDEN000, Media Type ID: T02, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
12:35:09 πμ #9 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
12:35:09 πμ #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 910176 (910176) = #910176/202:15.51
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 910176 blocks [PIONEER DVD-RW DVR-106D]
12:35:09 πμ #11 Text 0 File ThreadedTransferInterface.cpp, Line 1040
Prepare recorder [PIONEER DVD-RW DVR-106D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1864040448, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
910176 | lead-out | 1 | 0x41 | 0x00
12:35:09 πμ #12 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5.540 KB/s)
12:35:09 πμ #13 Text 0 File ThreadedTransferInterface.cpp, Line 2596
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:35:09 πμ #14 Text 0 File Cdrdrv.cpp, Line 8315
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Media type ID: T02
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 59 55 44 45 4E - 30 30 30 54 30 32 00 38 ...YUDEN000T02.8
23 54 37 10 02 4E 72 02 - 8C 63 16 16 0B 0B 0A 0A #T7..Nr..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
12:35:09 πμ #15 Text 0 File DVDPlusRW.cpp, Line 608
Start write address at LBA 0
DVD high compatibility mode: Yes
12:35:22 πμ #16 Text 0 File Cdrdrv.cpp, Line 1282
00:35:22.356 - PIONEER DVD-RW DVR-106D\H1 T0 : Queue again later
12:41:03 πμ #17 Text 0 File WriterStatus.cpp, Line 116
<PIONEER DVD-RW DVR-106D> start writing Lead-Out at LBA 910176 (DE360h), lenght 0 blocks
12:41:03 πμ #18 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:51:08 πμ #19 CDR -1122 File ThreadedTransferInterface.cpp, Line 1858
Unable to recover TOC
12:51:08 πμ #20 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1858
Could not perform end of Disc-at-once
12:53:08 πμ #21 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
12:53:08 πμ #22 CDR -1122 File WriterStatus.cpp, Line 167
12:53:08 πμ #23 TRANSFER -24 File WriterStatus.cpp, Line 167
12:53:08 πμ #24 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5.540 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 1:02:00 μμ (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3/8/2004 10:59:44 μμ (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Aπο το log που ποσταρες το μονο συμπερασμα το οποιο μπορω με καποια ασφαλεια να βγαλω ειναι οτι για καποιο λογο δεν του αρεσουν τα συγκεκριμενα μεσα, γεγονος που επαλήθευεται αν το προβλημα δεν υπαρχει χρησιμοποιωντας αλλα Media.
Αφου εχεις δοκιμασει να αναβαθμισεις το Νερο στην τελευταια εκδοση και να χρησιμοποιησεις και το τελευταιο fw για τον οδηγο σου το μονο που θα εκανα παραπανω εγω αν ημουν στη θεση σου ειναι να δοκιμαζα παλαιοτερες εκδοσεις fw και να εγκαθιστουσα τα ASPI 4.6 χωρις να δινω ιδιαιτερες πιθανοτητες ομως βελτιωσης του προβληματος.
Να και κάτι καινούριο!!!! Έφραψα ένα απο αυτά τα δισκάκια σε NEC 3500. Εκεί όλα καλά (write/read) το φέρνω στο δικό μου pc και τσούπ!!!!! Δεν το διαβάζει!!!! Είναι σαν να το έγραψα με το δικό μου!!!! Μια υποψία που έχω είναι πως και το δικό μου τα γράφει κανονικά αλλα στο διάβασμα κολάει!!!! Προβλημα μου βγάζει στο Unable to recover TOC, δηλαδή στο διάβασμα για επιβεβαίωση κατα κάποιο τρόπο!!! Αυτο που μένει λοιπόν είναι να πάω τα "καμμένα" dvds στο ΝΕC και να τσεκάρω αν έχουν γραφτεί!!! Αν ναι τότε έχω κανα 10 αντίγραφα ασφαλείας απο το DVD του μητροπάνου και αλλα 5 με τα images ασφαλείας απο το Play Boy The Mansion!!! Τα θέλει κανείς?
Εχεις παρατηρησει να σου δημιουργει προβλημα στην αναγνωση και με αλλα δισκακια περαν των συγκεκριμενων?
Lol :)
Βασικά μου το είχε ξανακάκεi με ένα +R Philips γραμμενο με το ίδο NEC, αλλα με κανα 2 eject και ένα restart έστρωσε!
Δηλαδή και να πουλήσω τα υπόλυπα σε κανενα γνωστό μου, αν μου γράψει κάτι για εμένα δεν θα μπορώ να το διαβάσω?
Λέτε να κάνω νύξη στο e-shop γαι επιστροφή της συσκευής?
