Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
Zoom Player Home FREE 8.10
# New :
* The default Onyx skin has been enhanced:
- Contrast, Brightness and Saturation are now adjustable through the expandable toolbar.
- The expandable toolbar is now accessible through a button on the user interface instead of pressing F5 or F9 using the keyboard.
- The volume, balance, play rate and equalizer bars have been redesigned.
- Less framing around buttons.
* The F4-F9 skin modes used by the Default Onyx skin have changed, the new modes are:
- F4 : Default mode.
- F5 : Smaller user interface.
- F6 : Minimal user interface.
- F7 : No user interface.
- F8 : Show/Hide Top Bar.
- F9 : Show/Hide Bottom Bar.
* The Audio and Subtitle stream selection interface has been rewritten. The new 'Stream Selection' right-click sub-menu groups all streams into clearly labeled 'Audio' and 'Subtitle' groups.
* The back-end for the Audio track cycle function (Ctrl+"A") used to switch between multiple audio tracks has been rewritten. Audio tracks from internal and external sources are now switched seamlessly.
* The back-end for the Subtitle stream cycle function (Ctrl+"B") used to switch between multiple subtitle steams has been rewritten. Subtitle streams from embedded and external sources are now switched seamlessly.
* Zoom Player now has integrated LIRC support. LIRC transmits and receives remote control signals. This allows computer control using almost any remote control. Using the LIRC section of the options dialog, you can directly assign remote control buttons to Zoom Player Standard, Extended and Navigation functions.
* New Setting (Adv. Options / Interface), that controls how to display the right-click "Stream Selection" sub-menu. With "Show all filters in Stream Selection sub-menu" enabled, all filters exposing a stream select interface are displayed in a sub-menu, cleaning up the dialog. With this setting disabled, only detected Subtitle, Audio and Video streams from known sources are listed.
* New Setting (Adv. Options / Interface / Control Bar), that prevents the Control Bar and Timeline context menu from opening. Useful if you have kids and you don't want a control bar setting changed by accident.
* Two new "On Playlist Complete" modes (Adv. Options / Playback) :
- Random play a media file from the playing directory.
- Random play a file with the same extension from the playing directory.
* New Setting (Adv. Options / Playback / Video / Subtitles), that resets the Subtitle Renderer's filter subtitle synchronization value, ensuring that the default value is restored when opening a new media after manually adjusting subtitle synchronization. Enabled by default.
* New Setting (Adv. Options / Playback / Video / Subtitles), that forces automatic stream selection to work only with external subtitle files.
* New Setting (Adv. Options / Playback / Video / Subtitles), that specifies whether to enable the first embedded or external subtitle stream if no automatic stream selection match is found (or if the auto stream selection is disabled).
* New "/CONNECTTCP:[address or IP]:[port]" command line parameter. By default, The TCP/IP interface works as a server by waiting for 3rd party applications to connect to Zoom Player. With the "/CONNECTTCP" parameter, Zoom Player initiates the connection itself with a local or remote server right as it launches. A server must be listening on the specified address and port for a connection from Zoom Player. Example: "c:\program files\zplayer\zplayer.exe" /CONNECTTCP:127.0.0.1:4770
* New extended function "exSkinMode", which activates the F4-F9 skin modes.
* Five new functions "fnResetBright", "fnResetContrast", "fnResetGamma", "fnResetHue" and "fnResetSatur" that reset the Brightness, Contrast, Gamma Hue and Saturation to their default values.
* The skin script code has been extended with "StartAndGroup" and "EndAndGroup" blocks that allow skin script authors to limit sections of the script to specific combination of active groups.
* When connecting to the TCP/IP control interface, Zoom Player automatically issues a "3000" notification message if an error dialog was visible prior to establishing the TCP/IP connection.
* Zoom Player now notifies you of known buggy filters when running a new version of Zoom Player for the first time.
* New Smart Play profile for embedded Apple Lossless Audio (ALAC).
* New Comm API message #1090, used to get the current timeline text, including the current position and any other value specified in the options dialog under "Adv. Options / Interface / Control Bar / Timeline Area".
# Changes :
* The F4-F9 keys no longer modify skin groups, but rather activate Skin modes which are programmable directly from the skin script, providing greater flexibility and control to skin designers.
* When using the default onyx skin in F6 or F7 mode, a smaller control bar is now used.
* The Zoom Player Install Center now notifies to close any active media playback software.
# Fixes :
* Dynamic aspect ratio changes are now supported when using EVR as the video renderer.
* Running on Windows 7 with the windows shell set to an application other than "explorer.exe" would cause Zoom Player to crash.
* With "Aggressively Hide Mouse Cursor" (Adv. Options / Interface / Mouse / Settings) enabled, the mouse cursor no longer re-appears when opening a fullscreen navigation interface.
* The "/SKINDVD" command line parameter used to set the DVD skin actually set the audio mode skin by accident.
* The Video icon was being shown for Blu-Ray movie index files instead of the Blu-Ray icon.
* ID3v2 unicode tags are now supported automatically without specifying a country code.
* Fixed ID3v2 URL tags that are marked as Unicode but in actuality are ASCII.
* Auto-Save media chapters (".ZPCHP" files) was automatically creating chapter files when playing media files with embedded chapters (such as matroska ".MKV" files). Now, the chapter files are created only if you edit the chapters.
* The option to disable natural language sorting is fixed.
* Maintaining fast-play between playlist items is fixed.
* Fixed a few small cosmetic glitches.
* Pop-up OSD messages are now truncated to fit the video display area.
* Pressing F11 to reset color control values while the color control fullscreen navigation interface was visible, did not update the color control navigation interface.
* Selecting the Microsoft image source no longer notifies you that the filter is unregistered. Note that the microsoft image source filter is limited to 2000x2000 resolution, so it's not recommended for anything other than animated GIF files.
CDBurnerXP 4.4.0.2905
--wait-for-disc command
! Fixed a FormatException in the property dialog
! Fixed: Window size of data/audio window is not preserved correctly when closed in minimized state
! Fixed an ArgumentException in the video DVD burning dialog (path enclosed in quotes)
! Fixed: Handle exceptions for "save as" / audio compilations
! Fixed a StackOverflowException when cancelling
! Fixed: Incorrect error message when making multiple copies with same source and target device
! Fixed: If only one language is installed, use it as default
! Fixed: The name suggested for burning video DVDs may exceed the maximum length
! Fixed error "Incorrect BASS.DLL version (2.3 is required)" if an old version of bass_aac.dll has been copied to a Windows system folder
UltraDefrag 5.0.1 (32-bit)
- few important bugs in disk processing routines were fixed
- few bugs in MFT optimizer were fixed
- one bug causing boot time interface freeze after "Good bye..." message was fixed
- the following translations were updated:
> Finnish, Indonesian, Italian
- some additions to the tips, FAQ and GUI sections of the documentation
FileZilla 3.5.3
# New features:
* Ctrl+Shift+O can be used to toggle between modification time and filesize based directory comparison
# Bugfixes and minor changes:
* It is now possible to use custom passwords if using "anonymous" as user name
* After un-hiding toolbar, update toolbar button states
* Fix TLS compatibility issues with TLS 1.2 servers
* MSW: Unset hidden attribute on FileZilla's settings files
* Building FileZilla from source now requires wxWidgets 2.8.12 or higher.
Total Commander 8.00 beta 15
- Added: wincmd.ini [Configuration] CopyDirsAsAdmin=1: When a directory cannot be copied, then: 0: skip it, 1: ask user, 2: always try as administrator (32/64)
- Added: Copy function: Show error when a directory cannot be entered, allow to use "As admin" and "All as admin" functions (32/64)
- Fixed: Search function: Infinite loop detection was not working (it worked in other functions like "calculate occupied space") (32/64)
- Fixed: cd c:\path\file.zip did not place cursor on "file.zip" if the file wasn't a valid archive although it had an archive extension (32/64)
- Fixed: Internal ZIP and TAR packer: Do not stop packing when moving files to archives, one archive per file/folder, and at least one file is write protected. Instead, report error after packing all files (32/64)
- Fixed: When minimizing and restoring TC while the cursor was on the last file, the last line became only partially visible (64)
- Fixed: Menu hotkeys displayed in the main menu could be slightly cut on Windows Vista/7 (where they are right-aligned) (32/64)
- Fixed: Reduced flickering when loading Lister (caused by ShowInTaskbar:=stAlways) (64)
- Fixed: Inplace rename: option "Select only the file name when renaming" not working when invoked via right click menu or command cm_renameonly - use a timer because something(?) is re-selecting the entire name (64)
- Fixed: Try not to handle mouse move messages while context menu is open (problem only affects tablet PCs with SingleClickStart mode - untested) (32/64)
- Fixed: FTP connection details: Keep surrounding quotes around remote directory if user enters them (32/64)
- Fixed: Default beep when closing master password dialog with ENTER also when secure input was disabled (64)
- Fixed: Always release mouse capture when moving mouse over list window while left button not pressed, otherwise clicking in other panel may fail (64)
