Καινούργιες εκδόσεις (Haya)
PGM
  • Replies 2,4k
Miranda 0.9.41
# Bugfixes:
– Fix boot ini processing logic
– Gadu-Gadu: Fixed ignoring rich text messages
– Gadu-Gadu: Improved blocking/ignoring system
– Jabber: Minor fix for the Jabber account item
– MSN: Fixed connecting state issue
Google Chrome 18.0.1003.1 Beta
# All
* Updated V8 - 3.8.4.1
* Fixed several crashes
* When a profile is synced, use GAIA name + GAIA photo for avatar - Use Google OAuth userinfo API to get profile information
* Added support for manifest_version attribute for extensions
* Eliminate drawing glitch on WebUI radio controls.
* Fixed regression with extension omnibox API where whitespace would get trimmed
* Fix page zoom for plug-in documents
* Fix race condition in extension service that causes extensions installed
* Folders in the wrench menu and application menu are greyed out
* Better error handling in audio wave out.
* Made URL filter for web request API mandatory
* Reject weak RSA and DSA keys when validating certificate chains for HTTPS; related UI
# Windows
* Popups opened from a maximized window should now be unmaximized
* Hide panels in presence of full screen app for windows.
* Provide windows notification of thread termination
* Abort in-flight load tasks if the DB has been closed.
Adobe Reader 10.1.2
# Bug fixes
* On printing a PDF file to a PCL printer via Acrobat or Reader, the italic output in the printout is not correct.
* Mouseover events in interactive PDF form fields do not work properly (Applicable only to Acrobat/Reader 10.1.1).
* 3D PDFs may crash when viewed in VMWare.
* Policy protected file keeps incrementing *.DAT file in ...\Acrobat\10.0\Security and results in Reader X crashing when closing the file.
* When converting a webpage having a scrollable inline frame only the visible content is converted and content seen on scrolling down is dropped.
* Plug-in takes long time to load in the browser when rendering dynamic form on Windows XP.
* Form submission performance is slow with ZCI on Reader 10.1.
* Product view generated in Catia hides some elements when converted to prw/pdf.
* Repeatedly opening and closing PDFs in one browser session may cause a freeze or crash.
* Custom-encoded font glyphs truncated in Acrobat 10 on Windows.
* Form goes into unresponsive state when signing form.
PowerArchiver 12.10
* Added IMG support – added support for IMG files to PA, shell, burner, virtual drive.
* Improved Office/Modern interface – Improvements to the look/feel of (optional) Office/Modern ribbon interface.
* Improved ISO, RAR, 7z, TAR, BZ2 support – Various improvements for many of our compression engines.
* Improved ZIP AES – Better compatibility with older versions of PowerArchiver as well as files larger than 4 GB. Updated FIPS 140-2 mode.
* Added more Enterprise options – Administrators can disable shell access inside PowerArchiver.
* Improvements in UAC support – Better support for automatic UAC elevation in various occasions, other various improvements.
* Added Danish translation – Added Danish and improved other translations.
* Updated FTP engine – Updated FTP engine, Faster SFTP operation other improvements.
* Updated Burner engine – Updated Burner engine adding support for more devices.
* Reduced installer by 1 MB – Reduced installer size by 1 MB via our own compression optimizations.
* Other improvements, tweaks, fixes – Over 50 improvements implemented.
Wireshark 1.6.5 (32-bit)
# The following bugs have been fixed:
* "Closing File!" Dialog Hangs.
* Sub-fields of data field should appear in exported PDML as children of the data field instead of as siblings to it.
* Incorrect time differences displayed with time reference set.
* Wrong packet type association of SNMP trap after TFTP transfer.
* SSL/TLS decryption needs wireshark to be rebooted.
* Export HTTP Objects -> save all crashes Wireshark.
* Wireshark Netflow dissector complains there is no template found though the template is exported.
* DCERPC EPM tower UUID must be interpreted always as little endian.
* Crash if no recent files.
* IPv6 frame containing routing header with 0 segments left calculates wrong UDP checksum.
* IPv4 UDP/TCP Checksum incorrect if routing header present.
* Incorrect Parsing of SCPS Capabilities Option introduced in response to bug 6194.
* Various crashes after loading NetMon2.x capture file.
* Fixed compilation of dumpcap on some systems (when MUST_DO_SELECT is defined).
* SIGSEGV in SVN 40046.
* Wireshark dissects TCP option 25 as an "April 1" option.
* ZigBee ZCL Dissector reports invalid status.
* ICMPv6 DNSSL option malformed on padding.
* Wrong tvb_get_bits function call in packet-csn1.c.
* [uDP] - Length Field of Pseudo Header while computing CheckSum is not correct.
* pcapio.c: bug in libpcap_write_interface_description_block.
* Memory leaks in various dissectors.
* Bytes highlighted in wrong Byte pane when field selected in Details pane.
# Updated Protocol Support
* BGP, BMC CSN1, DCERPC EPM, DCP(ETSI) DMP DTLS GSM Management, H245 HPTEAM, ICMPv6, IEEE 802.15.4 IPSEC IPv4, IPv6, ISAKMP KERBEROS LDSS NFS RLC, RPC-NETLOGON RRC RTMPT SIGCOMP SSL SYSLOG TCP, UDP, XML ZigBee ZCL
# New and Updated Capture File Support
* Accellent 5Views, AIX iptrace, HP-UX nettl, I4B, Microsoft Network Monitor, Novell LANalyzer, PacketLogger, Pcap-ng, Sniffer, Tektronix K12, WildPackets {Airo,Ether}Peek.
Origin Beta 8.4.1.208
* Users can now change their Origin ID from the Settings menu.
* Password security has been improved. Users with less secure passwords will be asked to choose a new password.
* Required updates can now be delayed without disrupting access to Origin’s offline mode.
* A number of small bug fixes have been made.
