  • Guest
    Guest
    Η MSI E350IA-E45 Mini-ITX
    The world renowned mainboard and graphics card manufacturer, MSI, today officially announces the first mainboard Accelerated Processing Unit (APU) powered platform, the MSI E350IA-E45.
    [PRBREAK][/PRBREAK]
    [TABLE]
    [TR]
    [TD=colspan: 2]frame-divider.png[/TD]
    [/TR]
    [TR]
    [TD] [TABLE]
    [TR]
    [TD]all%20solid%20capacitors-01.png[/TD]
    [TD] Japanese made ALL solid CAP
    To provide the best product quality, the E350IA-E45 is equipped with Japanese made All Solid CAP. Solid CAPs have a lifetime of over 12 years under extreme high load. Solid CAPs have a low Equivalent Series Resistance (ESR) meaning they are more efficient and generate less heat, especially the characteristics you want from a small and powerful mainboard.[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [/TR]
    [TR]
    [TD] [TABLE]
    [TR]
    [TD] USB 3.0 and SATA 6 Gbps next-gen data speeds
    To support the ever increasing demand for faster data storage, the E350IA-E45 is equipped with the latest USB 3.0 and SATA 6 Gbps ports. USB 3.0 drives are up to 10x faster than USB 2.0 drives and, like SATA 6 Gbps ensure the quickest possible file transfer speeds with the latest drives.[/TD]
    [TD]usb%203_0-01.png[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [/TR]
    [TR]
    [TD] [TABLE]
    [TR]
    [TD] Multi-media connectivity
    The MSI E350IA-E45 has the flexibility of all the connectivity you need to set up a true Home Entertainment Platform. With HDMI support you can directly connect to your T.V. or Display and enjoy accelerated and enhanced HD video and 7.1 Channel audio. For the true audiophiles the E350IA-E45 features Optical and Coaxial SPDIF connectors for connection to a great audio system.[/TD]
    [TD]features_20100906140036.jpg[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [/TR]
    [TR]
    [TD] [TABLE]
    [TR]
    [TD] Winki 3, the most user-friendly Operating System
    With the latest series of MSI mainboards, MSI offers the user-friendly Winki 3 operating environment, which allows users to surf the Web, create documents, edit photos, send instant messages or chat with Skype without running Windows. In the case of a hard-disk failure, Winki 3’s built-in HDD recovery program can help you to restore or back-up your valuable data.[/TD]
    [TD]winki3.png[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [/TR]
    [TR]
    [TD] [TABLE]
    [TR]
    [TD] i-Charger: Fast USB Charging
    MSI i-Charger technology allows faster USB charging of devices like an iPad. Now you can sync your media with your iPad and quickly charge it to take your personal companion on the road in no-time.[/TD]
    [TD]i-charger.png[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [/TR]
    [TR]
    [TD=colspan: 2]Technical specifications[/TD]
    [/TR]
    [TR]
    [TD] [TABLE]
    [TR]
    [TD]AMD E-350. 1.6 GHz Dual-Core Processor[/TD]
    [/TR]
    [TR]
    [TD]AMD Hudson M1 FCH[/TD]
    [/TR]
    [TR]
    [TD]2 DIMM - support for DDR3-1333/1066/800 MHz up to 8GB max[/TD]
    [/TR]
    [TR]
    [TD]Built-in with an AMD Radeon HD 6310 Graphics Core (HDMI + D-Sub out)[/TD]
    [/TR]
    [TR]
    [TD]8-channel (7.1) HD Audio subsystem with S/PDIF out[/TD]
    [/TR]
    [TR]
    [TD]10/100/1000 Mbps[/TD]
    [/TR]
    [TR]
    [TD]4 x SATA 6Gb/s ports - 2 x USB 3.0 ports - 10 x USB 2.0 ports (6 x external ports, 4 x internal ports)[/TD]
    [/TR]
    [TR]
    [TD=bgcolor: #F0F0F0]1 x PCI Express x16 slot (x4 speed)[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
