Alpenfohn is aiming at the performance crown under the CPU coolers with the K2. For this, Alpenfohn is employing two cooling towers and ships the unit with two, potent Wing Boost fans. The middle fan with[PRBREAK][/PRBREAK] 140 mm is intended to keep the air flow at a maximum, while the smaller 120 mm unit in front is meant to offer maximal compatibility to modern mainboards, while still providing impressive air flow. Those wanting to go even further may install a third fan in the rear of the cooler. The Alpenfohn K2 CPU cooler is available immediately at Caseking.
The cooler utilizes an incredible amount of materials with a massive weight of 1050 grams. Using more mass does not simply equate to greater performance, as only an intelligent use of such will make for a great cooler and this is something the Alpenf
