ASRock's socket LGA2011 motherboard lineup doesn't end with X79 Extreme7 as thought before, the company thinks there's scope for an even more loaded model that's literally bursting with connectivity and[PRBREAK][/PRBREAK] expansion features. Enter the X79 Extreme9. This board uses high-grade digital PWM circuitry to power the CPU. It draws power for the CPU VRM from two 8-pin EPS connectors. Unlike the X79 Extreme7, this board features eight DDR3 DIMM slots, two per memory channel. Expansion slots include five PCI-Express 3.0 x16, and a PCIe x1.
Since it completely ran out of room on the main PCB, ASRock put two important connectivity features on a separate (included) addon card, called the ASRock "Game Blaster". This card occupies the PCIe x1 slot, it packs a next-generation Creative SoundCore audio processor (more advanced than X-Fi), and a low-overhead/low-latency gigabit Ethernet connection. It's not exactly known if this connection is driven by a Killer 2100 or a more common PCIe GbE PHY backed by ASRock's proprietary packet prioritization software (XLAN).
