  • Guest
    Guest
    ColorFire Xstorm HD 6850 Graphics Card Breaks Vantage Record
    ColorFire is a sister-brand of Colorful, which focuses on AMD Radeon-based graphics cards, as Colorful specializes on NVIDIA GeForce ones. Shortly after its introduction, the ColorFire team led by overclocker Carl from China was able to break a 3DMark Vantage record for the Radeon HD 6850. The overclocker achieved P27751 points, some 3810 points ahead of the previous[PRBREAK][/PRBREAK] record-holder. The card sustained overclocked speeds of 1500 MHz core and 1275 MHz (5100 MHz GDDR5 effective) memory, and backed by an Intel Core i7-980X clocked at 5.7 GHz, with the entire setup being cooled by liquid nitrogen. The HWBOT validation can be found here.
    The Xstorm HD 6850 from ColorFire features the same mid-range exorbitance characteristic of Colorful. It features a PCB with a strong VRM, making use of high-quality components; and a large cooler. It features 1 GB of memory, a 4+1 phase VRM, dual-BIOS, OCP unlock switches, and consolidated voltage-measure points. The VRM uses high-grade chokes and POSCAP capacitors. The cooler uses a large (quiet) fan to cool a big heatsink to which heat is conveyed by three heat pipes.
    Source: http://techpowerup.com
