EVGA was missing on the LGA2011 motherboard wall at this year's Computex event in June. EVGA is one of the top brands overclockers and enthusiasts look forward to, for motherboards. As a late[PRBREAK][/PRBREAK] consolation, EVGA gave out a teaser picture of one of its upcoming X79 motherboards a little later in June. At GeForce LAN 6, however, EVGA made full use of the spotlight to unveil its X79 Classified (E799), a top-tier socket LGA2011 motherboard clearly designed for overclockers.
The X79 Classified uses a traditional LGA2011 motherboard layout, but with wide open spaces to make insulating it (against condensation) easier. The CPU power delivery seems to be in the hands of some very high-grade VRM design, it draws power from two 8-pin EPS connectors apart from the 24-pin ATX (that's right-angled). There are just four DDR3 DIMM slots, one per memory channel. A 4-phase memory VRM is deployed. Over the chipset area, a large contiguous heatsink covers most hot components in the central-right region. We don't expect there to be a bridge chip.
