Spire has announced a new GPU cooler, the SkyMax DT. The unit is quite sizable and features three fans, one 90mm and two 80mm. The three fans will be used to keep the cold air blowing over the five copper heat pipes, [PRBREAK][/PRBREAK]offering cooling up to 180W TDP. The fans are capable of moving 36.5 CFM while having a maximum noise factor of 41.5 dBA The cooler will also come with heat sinks to accommodate cooling of the RAM and MOSFETs found on the GPU. The card is compatible with both NVIDIA and AMD cards, with a full list available on the site. The card is available with an MSRP of $59.99.
More: http://www.spire-corp.com/main/product_detail.asp?ProdID=1145
