Everything posted by kreach
Κορυφαίες ατάκες μελών του TheLab.gr (QuoteLab)
kreach απάντησε στο θέμα του unseen topic στην ενότητα Off topic
"Άν κάπνιζες θα σου έκανα δώρο ένα τασάκι για ποδήλατο..." - Jaco :smoke: http://www.thelab.gr/showpost.php?p=1062621014&postcount=24 -
Official Windows 7 Thread
kreach απάντησε στο θέμα του Melkon topic στην ενότητα Λειτουργικά Windows
Μια είδηση σχετικά με τα Windows 7 It seems unlikely that Microsoft has any major news involving Windows 7 features up its sleeve, but interesting tidbits are still coming out. The latest is today’s news that it’s eliminating the venerable AutoRun feature for USB drives. A blog post at the company’s Engineering Windows 7 blog explains that the Conficker worm used AutoRun (which identifies programs on a removable device and lets users choose to have them run automatically) and AutoPlay (which notices that you’ve inserted a removable storage device and provides a menu of tasks to choose from) to provide an AutoPlay item that looks like it’ll open up a folder but which actually launches Conficker. Windows 7 won’t display AutoRun items in this menu, and Microsoft says it’ll update Windows Vista and Windows XP to behave the same way. Conficker may be devious, but the security hole was pretty gaping all along; it’s surprising that it took this long for it to be publicized and for Microsoft to seal it up. AutoPlay will still display AutoRun items on CDs and DVDs–which are presumably far less likely to carry worms than USB drives–but Microsoft is tweaking the message you get to make it clearer that launching an AutoRun item involves running a program from an external device. Side note: Microsoft’s Security Research and Defense Blog also has an item on the change, in which it says that “AutoPlay will no longer support the AutoRun functionality for non removable optical media” This momentarily confused me–it brought to mind visions of a DVD drive with a single disc sealed up inside the computer–but I’m reasonably sure that it’s a typo and that the poster meant to say “non-optical removable media.” Πηγή: http://technologizer.com/2009/04/28/windows-7-eliminates-autorun-for-usb-drives/ Επίσης να αναφέρω κι εδώ το λεγόμενο Windows XP Mode στο οποίο "Windows XP Mode is specifically designed to help small businesses move to Windows 7. Windows XP Mode provides you with the flexibility to run many older productivity applications on a Windows 7 based PC. " :crazy_pilot: Περισσότερα στο thread που άνοιξα εδώ: http://www.thelab.gr/showthread.php?t=63457 -
Ιστοσελίδες που είδαμε και μας άρεσαν
kreach απάντησε στο θέμα του hayabusa topic στην ενότητα Δίκτυα
www.tinyurl.com "Are you sick of posting URLs in emails only to have it break when sent causing the recipient to have to cut and paste it back together? Then you've come to the right place. By entering in a URL in the text field below, we will create a tiny URL that will not break in email postings and never expires." Εδιτ: Το κουμπάκι edit εξαφανίστηκε πάλι? Δεν κατάφερα να κάνω edit το αρχικό μου ποστ ...- 459 απαντήσεις
Αντιμετώπιση Virus, Spyware, Adware, Dialers, Trojans κλπ [Ver 2.2]
kreach απάντησε στο θέμα του jpavly topic στην ενότητα Antivirus & Security
Ok, ευχαριστώ- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
Ναι το ήξερα, αλλά ουσιαστικά αν και δεν έχεις κανει log in, τα windows δεν έχουν φορτώσει???- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
Καλά, εννοείται, hobby ειναι η ασχολία όλων μας στο TheLab.gr και πάνω από όλα η υγεία και ... μιας και είμαστε σε περίοδο διακοπών ... η διασκέδαση :fun: Τώρα που το έψαξα κι άλλο, σκέφτηκα πως η ασφαλέστερη λύση να είναι το σκανάρισμα να γίνει ούτε καν από το safe mode αλλά από Bootable CD. Βέβαια αυτό αποτελεί extreme case. Πιστεύω πως θα χρειαζόταν μόνο εαν ύστερα από σκανάρισμα σε safe mode δεν σωζόταν η κατάσταση και δεν ήταν δυνατό/επιθυμιτό το format. Βρήκα τουτο που είναι και free και σχετικά ενημερωμένο. Είναι της Kaspersky. Σχετικά bootable anti virus scanners: http://www.freedrweb.com/livecd/ http://www.avast.com/eng/avast_bart_cd.html - To oποίο έχει και ενσωματωμένο reg cleaner κτλ αλλά δεν νομίζω πως είναι και τόσο καλά όσο τα κανονικά reg cleaners. Βασικά και όσοι έχουν αγοράσει από κατάστημα τα anti virus της Norton, Kaspersky κτλ το installation cd είναι bootable. Το κακό με αυτά είναι πως με τον καιρό γίνονται outdated και το έψαξα λίγο (έχω το NIS 2009) και δεν φάνηκε εύκολη η διαδικασία να περάσει κανείς τα καινούρια definitions..- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
1) Ναι, αλλά ο Administrator λογικά μπορεί να τα δει όλα, άσχετα από τις ρυθμίσεις των user, σωστά? 2) Οκ 3) Sphinx εννοείς το Vista Firewall σωστά? Της sphinx software είναι, εξού και η υπόθεση που έκανα Nαι, το θέμα του χρόνου είναι όντως ένα θέμα Ελπίζω να ξελασκάρουν τα πράγματα για σένα αυτό το Πάσχα Ok θα το ποστάρω στα bugs- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
jpavly, MΠΡΑΒΟ* άλλη μια φορά για τον οδηγό σου ! Βλέπω έχει πάει στο v2.2 *Διπλό καθώς με διόρθωσες το τυπογραφικό Μερικές ερωτήσεις/παρατηρήσεις: "Αφαίρεση passwords από Users Αφαιρούμε ΟΛΑ τα passwords εντελώς από όσους χρήστες έχουν. Αλλιώς τα αρχεία μας στους system folders τους μπορεί να είναι κλειδωμένα. " Αυτό προϋποθέτει ότι είμαστε Administrators, σωστά? Ο Administrator πως και δεν έχει πρόσβαση στα αρχεία των users ... ? Επίσης σκέφτηκα πως δεν ξέρω πραγματικά τι θα πει "immunizer" και να φανταστώ όπως και αρκετοί άλλο. Έτσι είπα να ποστάρω μια επεξήγηση γιατί οι όροι virus, spyware, adaware, rootkit έχουν αναλυθεί αρκετές φορές στο φορουμ. ---- "How does Malware Immunizer works? Malware Immunizer is a very simple tool that only create files and folders on your hard disk drive! So how does it prevent the installation of malware? Actually when you execute a executable file or installer, it may unload or create files on your hard disk drive. Let said a virus want to create a file named virus.exe on C: (C:\virus.exe), however if a folder named virus.exe already exists on C: (C:\virus.exe), the malicious file will not be written or overwrite the folder. Malware Immunizer make use of this behavior to prevent installation of malware by creating folders of known malware filename with path used by the malware. Note that it mostly only prevent installation of the core files that will be run every time the system boot up, meaning that when a malware is executed it may create other malicious files that must be cleaned using antivirus program. Likewise files will be used to prevent the creation of malicious folders which can contain harmful files. *...* How effective is Malware Immunizer? First, I would say it is not effective if a malware creates a file on the hard disk with random file or folder name. Some malware maybe smart enough to remove existing file and folder created by Malware Immunizer prior to creating the files/folders. But from what I see, I haven't see such a malware. Malware Immunizer WILL NOT remove any existing malware and it is NOT a replacement for antivirus program or other scanners. Malware Immunizer may be useful when a malware attacks and your antivirus is disabled or destroyed, provided that Malware Immunizer does protect against the malware items. Malware Immunizer can prevent malware with filename like lsass.exe from installing in the windows directory, which is same as the filename of a system file in the windows system directory, this is often a trick used so that the user will not notice any suspicious process in the Windows Task Manager. In short, you will still need antivirus and antispyware programs to fully eliminate the malware and you are recommended to enable their real-time monitoring function. Malware Immunizer only contains definition of some wide spread malware, it is impossible to add every malware into it, so from time to time, old items will be removed when they are no longer a threat. It can also prevent against some of the spyware/adware installations." Πηγή: Εδώ. Να σημειώσω πως η σελίδα αυτή είναι μιας εταιρίας που φτιάχνει το πρόγραμμα "Malware Immunizer " . Δεν έχω σκοπό να το διαφημίσω το προϊόν απλά σκέφτηκα πως ο τρόπος λειτουργιας του πρέπει να είναι παρόμοιος με του Spybot S&D (το site της οποίας δεν εξηγεί καλά την διαδικασία του immunize) ----- Eπίσης το CCleaner στην νεότερη βερσιον έχει ενσωματώσει το Wipe Free Space. Επίσης στις ρυθμίσεις μπορεί κάποιος να επιλέξει και μέθοδο secure delete. Υπάρχει περίπτωση ένα κακόβουλο προγραμματάκι να το έχουμε κάνει ένα "κοινό delete" ή διαγραφή από τον κάδο ανακύκλωσης και να εξακολουθήσει να τρέχει? Επειδή διάβαζα πως το delete των windows δεν είναι οριστικό, εκτός κι αν η απειλή από "ψευτο" deleted αρχεία/προγράμματα είναι σενάριο επιστημονικής φαντασίας "Vista Firewall Control Free" Βασικά δεν κατάλαβα, εννοείς πως προτείνεις τους χρήστες xp να τρέχουν Zone Alarm Firewall και των Vista το Vista Firewall Control Free? BTW το comodο το έχεις δοκιμάσει? Στην κατηγορία Δ υπαριθμόν 3 πιστεύω πως θα βοηθούσε να αναφέρεις τρόπους για τους "τρελλούς" :crazy_pilot: Βασικά επειδή δεν μπορώ όταν σερφάρω στο ιντερνετ να περιορίζομαι αποκλειστικά σε ασφαλή site αλλά και έχω την τάση να δοκιμάζω διάφορα προγράμματα να δω τι παίζει, χρησιμοποιώ το sandboxie και το dropmyrights Aυτά που λες :flower: Edit: Γιατί όταν έβαλα bullet points τα γράμματα εμφανίζονται πολύ μικρά ενώ όταν κάνω πλήρη επεξεργασία και ρυθμίζω το μέγεθος σε "2" (κανονικά δηλαδή) βγαίνουν σωστά?- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
Και τα δύο θέλουμε. BTW προσθέτω και αυτό για όσους δεν το έχουν δει- 459 απαντήσεις
Ειδήσεις μαζεμένες (το homepage μου) www.cebil.gr Ιστοσελίδες που μου προτάθηκαν όταν ήμουν νέο μέλος. Περιέχουν πληροφορίες, συγκριτικά τεστ για hardware. www.tomshardware.com www.anandtech.com --- http://torrentpond.com/ - Torrent Search Engine Bασικά έχει τύχει αρκετές φορές να ψάχνω κάτι μέσω αυτού στο πχ thepiratebay και να μην βρίσκω κάτι, και όταν ψάχνω από το thepiratebay το ίδιο να βρίσκω ... To be continued with many edits !- 459 απαντήσεις
Αχ ... είδα οτι εμφανίστηκε το τόπικ και ήλπιζα με κάποιο νέο αλλά τπτ
Smash Bros Melee στο laptop μου :happy2:
- 7.780 απαντήσεις
- games
- new release
(και 2 επιπλέον)
PS3 - Πως κάνουμε το Playstation 3 τον απόλυτο Media Player.
kreach απάντησε στο θέμα του alexis2044 topic στην ενότητα PC Gaming
Mια από τα ίδια :> -
Και το στο funny pictures -
:tongue: Kρίμα γιατι ... πεινούσα (ξέρει ο Άστρο ... :whistling
Ζητώ συγγνώμη για το τελευταίο μου ποστ μου στο ΠΟΘ
Οι γονείς μου χρησιμποιούν υπολογιστές καθημερινά για τη δουλειά τους. Κάνουν και αγορές μέσω ιντερνετ. Το θέμα είναι πως δεν γνωρίζουν πολλά πολλά και δεν θέλουν κάτι που πιθανώς να τους μπερδέψει* ή να θέλει να πειράζεις τα default settings. Σκέφτομαι να τους πάρω το Smart Security της Eset αλλά σκέφτομαι και το Kaspersky Internet Security (όμως μερικά χαρακτηριστικά του δεν λειτουργούν στα vista όπως διάβασα στο wiki). Tόσο καιρό έχω βάλει τα avast και comodo αλλά κάνει κάτι περίεργα το pc λένε και λέω μήπως έχει εισβάλλει κάποιο malware. *Mε το comodo δεν ήταν ευχαριστημένοι γιατί τους έβγαζε πολλά popup και σταμάτησε να λειτουργεί ξαφνικά το ιντερνετ! Όταν τους είπα πως να το απενεργοποιήσουν, όλα καλά! Το comodo έχω κι εγώ και έχω μείνει πλήρως ικανοποιημένος, αλλά αν δεν ξέρεις να το χειρίζεσαι ... Όσον αφορά τα "περίεργα" δεν ξέρω λεπτομέρεις, θα τα δω από κοντά τα χριστούγεννα ! Και να φταίει πως δεν έχουν τρέξει κανα defragment ή το ccleaner ...- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
Ti λέτε για το Online Armor Firewall??? http://www.tallemu.com/free-firewall-protection-software.html Στο http://www.matousec.com/projects/firewall-challenge/results.php λένε πως είναι το δεύτερο στη σειρά με πρώτο το γνωστό Comodo.- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
Οκ κατάλαβα που το πας. Δεν το εννοούσα έτσι ! Απλά καλό είναι ότι λέγεται, να γίνεται μια σούμα σε κάποιο ποστ να μην χανόμαστε. Εϊδη έχουμε 187 ποστ !- 433 απαντήσεις
- a/v
- antispyware
(και 3 επιπλέον)
