ilgreco1974 Δημοσιεύτηκε Απρίλιος 2, 2009 #1 Κοινοποίηση Δημοσιεύτηκε Απρίλιος 2, 2009 Πουλαω υλικο scsi / SAS / SATA (μερικα hd 10k , 15k , schede pci , pcix e pci-e , καλωδια ) controllers και μερικα καλωδια SAS , controllers sata : Υλικο SCSI : 1) 3 FUJITSU MAW (newest model Fujitsu MAT ) 73gb 10k 10.000 RPM u320 80pin ΝΕW OEM Worldisk 37e /1 !!! 2) 2 FUJITSU MAW (newest mofel Fujitsu MAT ) 147gb 10k 10.000 RPM u320 80pin ΝΕW OEM Worldisk 77e /1!!!! b)2 FUJITSU MAW (newest model Fujitsu MAT ) 147gb 10k 10.000 RPM u320 68pin ΝΕW OEM Worldisk 87e /1 !!! MAW 73 / 147gb : HD 10.000rpm ΑΠΙΣΤΕΥΤΑ ΓΡΗΓΟΡΟ : http://www.storagereview.com/php/benchmark/bench_sort.php (MAT3300) PHYSICAL SPECIFICATIONS Formatted storage capacity 73.5 GB Form Factor 3.5-inch x 1-inch high Mounting screws 6#32UNC Seek time (track to track) Read 0.2 / Write 0.4 milliseconds Seek time (average) 4.5/5.0 milliseconds (read/write) Seek time (full track) 10.0/11.0 milliseconds (read/write) Average latency time 2.99 milliseconds Rotational speed 10,025 RPM Data Buffer Size 8 MB Recording code 32/34 MEEPRML Interface 68 pin (NP Series) U320 SCSI Head positioning method ROTARY VCM Spindle start time 30 seconds typical Spindle stop time 30 seconds typical Power requirement Idle (ready) 9.5 W (typical) Height 25.4 millimetres Width 101.6 millimetres Depth 146.0 millimetres Weight 0.75 kg Ambient temperature (operating) 5 to 55 degrees C Ambient temperature (non-operating) -40 to 70 degrees C Maximum DE surface temperature (operating) 55 max deg. C Gradient 15 degrees C per hour Relative humidity (operating) 5 to 95 % RH (non-condensing) Relative humidity (non-operating) 5 to 95 % RH (non-condensing) Maximum wet bulb 29 degrees C (non-condensing) Vibration (operating) 0.6mm (5 to 20 Hz)/ 1.0G (20 to 300 Hz) Vibration (non-operating) 3.1mm (5 to 20 Hz)/ 5.0G (20 to 300Hz) Shock (operating) 65G Max (2ms) Shock (non-operating) 225G Max (2ms) Altitude (operating) 3,000 metres Altitude (non-operating) 12,000 metres Acoustic noise (at 1 metre idle) 3.4 bels MTBF (Mean Time Between Failures) 1,200,000 power on hours Unrecoverable errors 1 per 10^15 bits read Seek errors 10 per 10^8 seek 4)4 FUJITSU MAX (NEWEST MODEL MAU) 147GB 15K 15.OOO RPM 68 PIN ΝΕW FUJITSU ORIGINAL με manual Οι πιο γρηγοροι δισκοι 15κ ! Fujitsu 147GB 15000 RPM Ultra320 SCSI 68-pin hard drive MAX3147NP, RoHS Compliant. Fujitsu's latest generation of Rohs compliant 15K Enterprise SCSI Hard Disk Drives offer capacities of up to 147GB in a 1-inch high, 3.5-inch form factor. The MAX SCSI series is the latest generation Hard Disk products from Fujitsu offering low profile, high speed and high capacity to high performance enterprise computing applications. The MAX (NP) series comes with a 68-pin interface connector, spindle speed of 15K RPM and capacities of 36, 73 and 147GB. Areal density has doubled and internal drive transfer rates have been increased by 24% to 147 MB/s when compared to the previous MAP series. The drive is also equipped with an 8MB multi-segmented data buffer combined with a 32-bit wide internal data path for faster data access. # Formatted storage capacity 147.0GB # Form Factor 3.5-inch x 1-inch high # Mounting screws 6#32UNC # Seek time (track to track) Read 0.2 / Write 0.4 milliseconds # Seek time (average) 3.3/3.8 milliseconds (read/write) # Seek time (full track) 8.0/9.0 milliseconds (read/write) # Average latency time 2.00 milliseconds # Rotational speed 15,000 RPM # Data Buffer Size 8 MB # Recording code 32/34 MEEPRML # Interface 68 pin (NP Series) U320 SCSI # Head positioning method ROTARY VCM # Spindle start time 30 seconds typical # Spindle stop time 30 seconds typical # Power requirement Idle (ready) 11.5 W (typical) # Height 25.4 millimetres # Width 101.6 millimetres # Depth 146.0 millimetres # Weight 0.75 kg # Ambient temperature (operating) 5 to 55 degrees C # Ambient temperature (non-operating) -40 to 70 degrees C # Maximum DE surface temperature (operating) 55 max deg. C # Gradient 15 degrees C per hour # Relative humidity (operating) 5 to 95 % RH (non-condensing) # Relative humidity (non-operating) 5 to 95 % RH (non-condensing) # Maximum wet bulb 29 degrees C (non-condensing) # Vibration (operating) 0.6mm (5 to 20 Hz)/ 1.0G (20 to 300 Hz) # Vibration (non-operating) 3.1mm (5 to 20 Hz)/ 5.0G (20 to 300Hz) # Shock (operating) 65G Max (2ms) # Shock (non-operating) 250G Max (2ms) # Altitude (operating) 3,000 metres # Acoustic noise (at 1 metre idle) 3.6 bels # MTBF (Mean Time Between Failures) 1,200,000 power on hours # Component life (years) # Unrecoverable errors 1 per 10^15 bits read # Seek errors 10 per 10^8 seeks 125e cad !!! ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 5)4 καλωδια scsi LVD/SE U320 με terminator και 6 connectors 68pin (για 4 hd scsi 68pin ) , καινουργια ! 13,00e το ενα . 6) 3 adapters u320 80-68pin καινουργια 6,00e cad 7) 4 καλωδια round LVD/SE 2 connectors για 1 hd (τελειο για 1 δισκο σε 29160N - 2100s - MR 500) . καινουργια . 6e το ενα 8) 2 καρτες scsi RAID PCI ULTRA160 LSI original megaraid express 500 . Web bios support . 32mb ram , intel cpu , win xp , vista compatible . http://www.lsilogic.com/obsolete/meg...te=1&locale=EN 35e ! 9) 1 CONTROLLER SCSI RAID U160 32MB PCI ADAPTEC 2100S ORIGINAL , 32mb ram , intel cpu , win xp compatibile vista 32bit , il driver x winxp : http://www.adaptec.com/en-US/speed/r...v_v314_exe.htm http://www.adaptec.com/en-US/support...aid/ASR-2100S/ 35e ! 10) 1 karta scsi RAID PCI DUAL ULTRA160 LSI Elite 1600 128 MB + batery , pci 64bit - 32bit , Web bios support 2 ports int. u160 (320mbs total ) , 2 ext. u160 128mbram , intel cpu . Compatible pci 32bit e 64 bit The MegaRAID Elite 1600 half-size adapter employs the latest 64-bit, 66MHz PCI SCSI RAID technology using an Intel I/O processor. With two Ultra160 SCSI channels, the adapter offers ISPs, workgroups, and department server environments unequalled performance and reliability. Features * IA-64 ready * Two Ultra160 SCSI channels * 64-bit, 66 MHz PCI * PCI 2.2 compliant * Up to 128 MB ECC SDRAM cache memory supported - ships with 32 MB or 64 MB ECC SDRAM cache memory * Standard NT® clustering support * Advanced management and configuration utilities * 40 logical drives per controller and 30 physical drives per logical array * Auto resume during array reconstruction * Background initialization for Quick RAID 5 set up * FlexRAID®: Online capacity expansion and online RAID level migration 50.00e 21)CONTROLLER SCSI pci-x (32bit compatibile) ultra320 LSI 20320 HP U320 , 1 port u320 internal , vista -xp ok , new ! 45e 11)1 LSI MEGARAID 320-2 128mb + Battery (2 ports int , 2 ports ext ) PCI 32-64bit -PCIX ,u320 LVD http://www.lsi.com/storage_home/prod...202/index.html LSI SCSI RAID 5 PCIX , CHIPSET INTEL GC80302, 64MB ECC UP TO 256 ,DUAL CHANNEL,U320,SUPPORTS RAID0/1/0+1/5/10/50/IF:2XIN 2XOUT 100.00e oem KAINOYΡΓIA !!! 12)1 LSI MEGARAID 320-1 64mb (1 port int , 1 port ext ) u320 LVD (NO DELL-LSI ORIGINAL) , PCI 32-64bit ( ok ALSO FOR PCIX) , σφραγισμενη στο σακουλακι της με cd & manual !!! 80e http://www.lsi.com/storage_home/prod...201/index.html Product Description MegaRAID SCSI 320-1 With support for 64-bit addressing and a full RAID feature set, the MegaRAID® SCSI 320-1 delivers unsurpassed data throughput and fault tolerance for your mid-range server or performance workstation. Quick installation and setup capabilities along with easy-to-use management utilities make the MegaRAID SCSI 320-1 the first choice of OEMs, system integrators, and value added resellers (VARs) worldwide. Designed around LSI next-generation I/O technology (Fusion-MPT™), the MegaRAID SCSI 320-1 leverages a streamlined firmware-level programming interface and advanced hardware designs to offer unequalled I/O efficiency and performance. The MegaRAID SCSI 320-1 also incorporates a space-saving MD2 (low-profile PCI) form factor, increasing available space, even in the most limited server and workstation enclosures. Features * One single-channel LSI53C1020 Ultra320 SCSI controller * IA-64 ready * Intel® GC80302 integrated I/O processor * 64-bit, 66 MHz PCI * PCI 2.2 compliant * Integrated 64MB ECC SDRAM cache memory * Advanced management and configuration utilities * Supports up to 40 logical drives per controller * Auto resume during array reconstruction * Background initialization for Quick RAID 5 setup * FlexRAID®: o Online capacity expansion o Online RAID level migration Benefits * Fast Ultra320 performance * Intelligent IOP-powered RAID solution * Array availability in minutes * FlexRAID support * Battery backup unit available * Low profile form factor * http://www.lsi.com/storage_home/products_home/internal_raid/megaraid_scsi/megaraid_scsi_3201/index.html 80e !!!!! 13)2 ADAPTEC 29160 u160 ,τελεια για 1-2 δισκους 10κ/15k σε οποιαδηποτε MOBO !!!!! 25e 15)1 DELL LSI MEGARAID 320-2e pci-express 128mb baterυ on board ,winxp-vista ready . Καινουργιο στο κουτι του ! Πολυ γρηγορος controller raid , pci express , οτι καλυτερο σε pci-e για scsi !!! μπαινει σε οποιαδηποτε ΜΒ με ενα pci-e για καρτες γραφικων ελευθερο ! MEGARAID LSI CONSOLE PLUS COMPATIBILE ! 180 euro ! 16)1 LSI 320-2x pci-x u320 256mb + BBU 135e !! ! LSI MEGARAID 320-2X + BBU ( BATTERY MODULE) pci 64bit PCIX 133mhz ( no pci 32 bit !!! ) 400MHZ Intel® Xscale® IOP321 integrated I/O processor BULK ORIGINAL LSI CARD MEGARAID 320-2x 256mb DDR ECC REG BATTERIA INCLUSA VISTA 32bit / 64bit compatibile , non occorrono drivers Controller memorizzazione dati (RAID) 2 Canali u320 interni , 2 u320 canali esterni Ultra320 SCSI - PCIX - 2x 320 MBps - RAID 0, 1, 5, 10, 50 http://www.lsi.com/storage_home/products_home/internal_raid/megaraid_scsi/megaraid_scsi_3202x/index.html http://www.lsi.com/files/docs/marketing_docs/storage_stand_prod/raid/MR_320-2X_PB-Final.pdf MATERIALE SAS/SATA 17)1 controller DELL PERC 5/i RAID Controller PCI-E SCSI SAS SATA 256MB CON STAFFA D' AGGANCIO !!!!!!!!! OEM VERSION OF LSI SAS CARD , SUPPORTA IL SOFTWARE DELLA LSI MEGARAID STORAGE MANAGER : Highlights * Offers support for RAID levels 0, 1, 5, 10, and 50 * Works with OpenManage Server Assistant to enable online configuration and monitoring of many servers * Provides maximum bandwidth of 12 Gbps per SAS connector * OpenManage Server Administrator facilitates monitoring of a single server and online configuration Overview Enterprise class PROTECTION and PERFORMANCE The Dell™ PERC 5/i RAID Controller Card is a PCI Express® based Serial Attached SCSI RAID controller that provides ultimate performance, data protection and scalability for external SAS RAID applications. With support for RAID levels 0, 1, 5, 10, and 50; the PERC 5/i provides multiple protection options to suit a wide range of applications and non-critical data. It features a high-bandwidth x8 PCI-Express® host interface, 256 MB DDR2 Transportable Battery Backed cache, and 3 Gbps SAS technology. PCI Express® provides a high performance point-to-point link for interconnecting devices and transmitting data. It includes a powerful Intel® IOP333 processor with XScale® Microarchitecture along with a 256 MB DDR2 memory for read and write cache. This product has been tested and validated on Dell™ systems. It is supported by Dell™ Technical Support when used with a Dell™ system. Tech Specs Interface Type Port(s) Total ( Free ) / Connector Type x8 PCI Express® 2 (external SAS x4) RAID Level Slot(s) Required 0, 1, 5, 10, 50 PCI Express® Cache / Buffer Size Data Transfer Rate 256 MB Up to 3 Gbps Device Type RAID Controller Card DRIVERS ( winxp , vista, linux ) / SOFTWARE DELL : http://search.dell.com/results.aspx?cat=sup&subcat=dyd&c=us&l=en&s=gen&k=DELL%20PERC%205/i >>> 132,00e !!!! <<<< 18a) 2 καλωδια SAS PER SATA HD (για 4 hd sata ) 16e 18b) 3 καλωδια sas per dischi sas/sata (για 4 hd sas/sata ) 21e cad 18c)2 BBU BATERυ per il PERC 5/I NUOVE 27E CAD 19) 7 HARD DISK SAS MAX 36,6gb 15k ,νεο model fujitsu 15k , απιστευτος δισκος , ελαχιστα χρησιμοποιημενοι , 48e ο ενας !!!!!!! 36GB MAX3036RC SAS Internal Hard Drive With the latest advances in interface technology, the MAX3036RC series provides a cost effective storage solution that meets even the most demanding enterprise storage requirements. * Serial Attached SCSI connector * 3.3ms Average seek time / Up to 15000rpm performance * Spindle speed is 15000rpm / Buffer size is 16MB cache Fujitsu's 36GB MAX3036RC is the latest of compliant 15K enterpirse hard disk drives, offering capicities of up 36GB, and increased transfer rates. The MAX3036RC's interface (Serial Attach SCSI (SAS)) series is the latest generation Hard Disk products from Fujitsu offering low profile, high speed and high capacity to high performance enterprise computing applications. The MAX (RC) series comes with a dual ported hot-swap SAS interface connector and spindle speeds of 15K RPM. Areal density has doubled and the drive is also equipped with an 8MB multi-segmented data buffer combined with a 32-bit wide internal data path for faster data access. 36GB MAX3036RC SAS Internal Hard Drive Connectivity Connector Serial Attached SCSI Connector Type SAS General Enclosure Type Internal Form Factor 3.5" Target Use Computer Performance Average Seek Time 3.3 ms Buffer Size, Cache 16 MB Data Transfer Rate 3 Gbps Storage Hard Drive Capacity 36.7 GB Spindle Speed 15000 rpm Contents hard drive, documentation Physical Dimensions 1" h x 4" w x 5.8" d Ports/Connectors SAS / Serial Attached SCSI 3.0Gb/s port Power Notes Power Requirements: Voltage: 5 V ± 5%, 12 V ± 5% Spin-up: 12 V ± 5% @ 2.5 A (peak) 5 V ± 5% @ 0.7 A (peak) Idle (typ.) 11.5 W 48e cad !!!!!!! 21) 4 HD sas 2,5" 10k 36,7gb καινουργια, 38e cad !!!!! Απιστευτα 10000rpm HD SAS !!!!! Fujitsu MAY SAS Series Overview As a point-to-point connection, Fujitsu SAS hard disk drives help enterprises develop new solutions and maintain flexibility. The RoHS compliant, 2.5-inch hard disk drives offer up to 73.5GB of storage and 10K RPM - a perfect combination for high-end, mission-critical applications residing on database servers, storage arrays, and NAS and SAN systems. With the 2.5-inch form factor, a greater number of SAS drives can be installed in the space previously occupied by conventional 3.5-inch enterprise hard disk drives, resulting in improved input-output (IO) performance. Additionally, lower power consumption helps systems maintain reduced heat levels. The drives are also hot pluggable, so they can be inserted or removed without harming the data or the system while the entire system is still powered on. The 3Gb SAS interface of the Fujitsu hard disk drives allows customers to take advantage of the increased performance associated with serial attached SCSI, while providing lower heat dissipation and lower acoustics.State-of-the-art hard disk drives for your most demanding enterprise applications * 2.5-inch RoHS compliant Enterprise Hard Disk Drives offer 10K RPM spindle speed and feature storage capacities up to 73 GB * Mean-time-between-failure (MTBF) of 1,400,000 power-on hours * The industry's first 2.5-inch small form factor Serial Attached SCSI (SAS) interface * Native Command Queuing (NCQ), providing faster execution of operation commands * Uses smaller connectors and cables than U320, a benefit acknowledged by the SCSI Trade Association (STA) Drive Features * Small Form Factor HDD: The adoption of 2.5" form factor to enterprise HDD, the required space is reduced up to 73% in comparison with previous 3.5" form factor enterprise HDD. This enables the installation of more number of HDDs into same area space. * High Performance: It is possible to install more number of HDD in comparison with 3.5" HDD in same space, IO performance (*1) is improved under the system configuration. * High Speed Interface: Serial Attached SCSI which is the New serial interface enables the High Speed Interface capability up to 3Gbits per second. * Low Power Consumption: Power consumption requirement has reduced to 4.5 Watts (Idle). It achieves up to 53% lower power consumption in comparison with 3.5" HDD. (The comparison with Fujitsu products) * Improvement for Shock Tolerance: FDB (Fluid Dynamic Bearing) spindle motor (*2) and Head Load/Unload mechanism (*3) enable in high shock torelance. The drives withstand up to 400Go-p (duration 1ms) non-operating shock and up to 100Go-p (duration 1ms) operating shock. * RoHS Compliance (MAY series only): This HDD is designed to meet the requirements of the European Union's RoHS directive. FUNCTIONAL SPECIFICATIONS Model MAY2036RC MAY2073RC Functional Specifications Storage capacity (formatted) 36.7GB 73.5GB Disks 1 2 Heads (read/write) 2 4 Bytes/Sector 512 Seek time Track to track Read: 0.2 ms (typ) / Write: 0.4 ms (typ) Average Read: 4.0 ms (typ) / Write: 4.5 ms (typ) Full stroke Read: 8.0 ms (typ) / Write: 9.0 ms (typ) Average latency 2.99 ms Rotational speed (RPM) 10,025 rpm Areal density 70.2 Gbits/sq. in. (max.) Data transfer rate 3Gbps Recording code 32/34 MEEPRML Interface SAS Head positioning method Rotary VCM Start time 15 s (typ) Stop time 15 s (typ) Buffer size 16 MB 38e cad !!!!! MATERIALE SATA : 22)1 controller sata RAID 6x SATA HP ADAPTEC 2610SA καινουργιο σφραγισμενο στο κουτι του DESCRIPTION: This is a 6 channel Serial ATA RAID controller card that supports a variety of configurations including 0, 1, 5, 10, and JBOD. Functionally and operationally, it is identical to the Adaptec 2410SA, except it gives you 2 EXTRA ports (or a 2810SA with 2 less ports). It is running the latest firmware, and is supported by both Adaptec 2x10SA drivers, and HP drivers. All recent versions of Linux natively support this as an "afa" device. Works in HP& non-HP systems equally well. Highlights * Intel Intelligent I/O processor * 64MB Cache * RAID 0, 1, 10, 5 and JBOD * Online Capacity Expansion * RAID Level Migration * 48-bit LBA supports large drives & Multi Terabyte Arrays TECHNICAL SPECIFICATION: Supported Operating Systems * Microsoft Windows XP Professional * Microsoft Windows XP Home Edition * Microsoft Windows 2000 Advanced Server * Microsoft Windows 2000 Server * Microsoft Windows 2000 Professional * Microsoft Windows Server 2003 * NetWare 6.5 SP 1.1A * Red Hat Linux * SuSE Linux * SCO UnixWare * Caldera OpenUnix Benefits * Advanced RAID features for high-end workstations and entry-level SATA servers. Key Differentiators * Optimized Disk Utilization * RAID Level Migration * Online capacity expansion * Background initialization (for immediate RAID availability) * Enclosure Management ready * Hot-swap disk drive support for easy replacement * Hot-spare disk support with automatic rebuild * Supports bootable arrays Customer Needs * Ideal for workstations as well as entry-level servers requiring advanced RAID features and supporting up to four Serial ATA drives System Environment * Desktop Cache Memory * 64 MByte (onboard) RAID Levels * 0, 1, 5, 10, JBOD Key RAID Features * Optimized disk utilization * Online RAID Level Migration * Online capacity expansion * Immediate RAID availability (background initialization) * S.M.A.R.T. support Number of Devices * Up to 6 Serial ATA drives Bus System Interface Type * 64-bit/66MHz PCI Internal Connectors * Six Serial ATA ports Data Transfer Rate * Up to 1.5 Gbits/sec System Requirements * Available PCI slot meeting PCI 2.2 specification 100,00 euro !!!!! ΟΛΟ ΤΟ ΥΛΙΚΟ (USED/NEW) ΔΕΝ ΕΙΝΑΙ ΣΕ ΕΓΓΥΗΣΗ , ΔΕΝ ΠΑΡΕΧΩ ΑΠΟΔΕΙΞΗ ΑΓΟΡΑΣ , αλλα ΟΙ ΤΙΜΕΣ ΣΤΑ ΠΕΡΙΣΣΟΤΕΡΑ ΕΙΝΑΙ ΤΟΥΛΑΧΙΣΤΟΝ ΕΞΕΥΤΕΛΙΣΤΙΚΕΣ , ριξτε μια ματια στο web για να καταλαβετε PM , Γιαννης Link to comment Share on other sites More sharing options...
ilgreco1974 Μάϊος 10, 2009 Author #2 Κοινοποίηση Μάϊος 10, 2009 up Link to comment Share on other sites More sharing options...
