  • astrolabos
    astrolabos
    Noctua at Computex 2025
    At this year’s Computex Taipei trade show, Noctua displayed a wide range of upcoming products and prototypes. Highlights included a functional prototype of the two-phase thermosiphon cooling solution, an All-In-One liquid cooler, all-black versions of the NH-D15 G2 and 140mm G2 fans, as well as several exciting collaborative projects. Among these were the ASUS RTX 5080 Noctua Edition GPU, the Antec Flux Pro Noctua Edition case, the Seasonic PRIME PX HPD Noctua Edition PSU, and the Pulsar Feinman Noctua Edition gaming mouse.
    Among a broad range of exclusive products and prototypes, the next-generation 120mm NF-A12x25 G2 fan took centre stage, serving as a key component in many of the showcased items. Featuring enhanced performance-to-noise efficiency, the fan incorporates a new Progressive-Bend impeller design made from Sterrox® liquid-crystal polymer. This design pushes air out towards the highest efficiency blade areas, while the Centrifugal Turbulator hub improves flow attachment and optimises fluid distribution across the impeller. These innovations make the fan highly versatile, delivering exceptional performance in both static pressure and airflow-intensive applications. Internal testing revealed improvements of up to 3.5°C on a 120 by 49mm liquid cooling radiator with a 200W heat load, compared to the award-winning NF-A12x25 in noise-normalised conditions. The NF-A12x25 G2 is slated for release in June 2025, with the chromax.black version expected to launch in Q1 2026.
    Another highlight of the show was the update on the development of the two-phase thermosiphon CPU cooler, engineered in collaboration with the Belgian two-phase cooling specialist Calyos. Leveraging the latent heat potential of vaporisation and condensation, the goal of this project is to provide the same performance level and ease of use as all-in-one water coolers without their drawbacks. The showcased prototype included a small window on the evaporator housing, allowing the working fluid to be observed in action as it cooled a modern AMD Ryzen 9 9800X3D CPU running an F1® 24 gameplay demo. The demonstration also highlighted the challenges of developing such a product for the market, including hotspot-centric heat loads generated by CPUs and the dry-out effect this causes on the evaporator plate. Significant progress has been made in development since last year and Noctua remains fully committed to delivering this product to market. However, it will not be featured in the public roadmap, and no estimated release date will be provided until definitive timelines are determined.
    noctua_computex_2025_thermosiphon_develo
    Noctua also unveiled its first prototype of an All-In-One (AIO) CPU liquid cooler with a 360mm radiator. The cooler is based on Asetek’s EMMA (Gen 😎 V2 platform, which offers chart-topping performance and industry-leading reliability. Distinguishing this as a true Noctua product are the premium quality quiet NF-A12x25 G2 fans with a speed offset that helps to avoid periodic humming due to beat frequencies, the SecuFirm2+™ mounting ecosystem that ensures compatibility with past and future sockets, and a pump cover engineered to minimise vibrations and noise through a multi-layered acoustic design. Two layers of open-pore soft acoustic foam target high-frequency noise, while a dense foam layer in between serves as a mass barrier, attenuating low-frequency noise. Additionally, the pump’s top cover is mounted on floating silicone inserts to prevent vibration transfer. Together, these elements function as a tuned mass damper (TMD) with the dense acoustic barrier and outer cover shell serving as the mass nodes. In contrast, the soft acoustic foam and silicone inserts provide the spring and damping functionality of the TMD. The prototype also featured an optional 80mm fan that can be placed on top of the cover using magnets, utilising the Coandă effect and rotational energy conversion to cool nearby socket components (VRMs, RAM, M.2 SSDs, etc.). The plan is to bring these AIOs to the market in the 420, 360 and 240mm form factors with standard 30mm thick radiators with an expected release date in Q1 2026.
    noctua_computex_2025_all_in_one_liquid_c
    The highly anticipated ASUS GeForce RTX 5080 Noctua Edition was also unveiled, featuring not two, but three next-generation NF-A12x25 G2 fans mounted on a custom-engineered heatsink. This design incorporates an extensive vapour chamber and a total of eleven heatpipes, seven measuring 8mm and four measuring 6mm. The PCB is based on the TUF Gaming model, and the upgraded cooling system significantly enhances performance-to-noise efficiency compared to both the TUF Gaming and ROG Astral cards. The card occupies 4 slots (80mm), with dimensions of 385mm in length and 151mm in width, weighing in at 2.6kg. The graphics card is expected to be released in Q3 2025.
    noctua_computex_2025_asus_geforce_rtx_50
    Following the success of the first ultra-quiet Seasonic Noctua Edition power supply, the next generation PRIME PX HPD (High Power Density) models are already in development. This new lineup of Platinum energy efficiency power supplies, offering 92% efficiency at 50% load, is set to launch in 850W, 1000W, and 1200W variants. All of them will feature a remarkably compact design, measuring just 125mm in length. The new series will incorporate the upcoming NF-A12x25 G2 fan alongside the custom-engineered, highly optimised fan grill that was introduced with the TX-1600 Noctua Edition model. With semi-passive operation, the fan remains off during typical loads and ambient temperatures, ensuring virtually silent performance, and activates only as load levels increase. Additional features include compliance with ATX 3.1 and PCIe 5.1 standards, 12V-2×6 connectors for high-end graphics cards, and fully modular cables with Noctua's signature colourway. The Noctua Edition Seasonic PRIME PX HPD series is scheduled for release in Q2 2026.
    noctua_computex_2025_seasonic_prime_px_h
    One of the most eye-catching products on display was the planned collaboration project with Pulsar, a high-end gaming peripheral brand well-known in the esports landscape. The project centres around their flagship Feinman FO1 gaming mouse, which features an ultra-lightweight design built with a magnesium alloy exoskeleton that houses an XS-1 32,000 DPI sensor with an 8KHz polling rate. In addition to the unique styling in the signature Noctua colourway, the mouse incorporates a highly energy-efficient Noctua NF-A4x10 5V PWM fan with minimal power consumption, providing quiet airflow to the palm, reducing hand sweat and improving grip during intense gaming sessions. The current estimated release date from Pulsar is November 2025.
    noctua_computex_2025_pulsar_feinman_noct
    Another standout collaboration at this year's Computex was the Antec Flux Pro Noctua Edition case. This model builds upon the award-winning Antec Flux Pro chassis, known for its exceptionally low airflow resistance, by incorporating four state-of-the-art Noctua NF-A14x25 G2 and two NF-A12x25 G2 fans, and a high-quality NA-FH1 fan hub for synchronized fan control. To minimize periodic humming or vibrations caused by beat frequencies, the adjacent fans are offset in speed. Extensive laboratory testing has been conducted to optimise cooling performance and reduce noise levels compared to the case's standard fan setup. Designed for ultra-quiet, high-performance systems, the case also features a distinctive brown-and-black aesthetic, highlighting its Noctua Edition branding. The Antec Flux Pro Noctua Edition case is expected to be released in late Q4 of 2025.
    noctua_computex_2025_antec_flux_pro_noct
    All-black counterparts of the award-winning NH-D15 G2 CPU cooler and NF-A14x25(r) G2 140mm fans were also showcased, signalling their arrival in September 2025. The high thermal-conductivity black coating on the heatsink guarantees thermal performance comparable to the standard version of the cooler and will be available exclusively in the standard, medium base convexity version, excluding the LBC and HBC models.
    noctua_computex_2025_nh_d15_g2_chromax.b noctua_computex_2025_nf_a14x25_r_g2_chro noctua_computex_2025_nf_a12x25_g2.black.
    The Noctua HOME product line is also set to undergo an expansion with the introduction of a 140mm desk fan, featuring the next-generation NF-A14x25 G2 fan paired with the NV-AA1-14 airflow amplifier. This combination delivers exceptional ventilation efficiency while maintaining remarkably quiet operation. The product will retain its sturdy, steel-constructed NV-FM1 pivoting fan mount, which allows flexible angle adjustments and the included integrated magnets, screw holes, and zip-tie slots offer versatile mounting options. The new fan will be USB-powered and the package will come with a NV-EC4 1m extension cable, providing a total cable length of 2m, along with a pre-installed NA-FG1 fan grill for added safety. Additionally, the new inline USB fan controller cable enables users to adjust the fan from maximum airflow performance to near-silent operation using physical buttons and it also supports monitoring, controlling, and programming through the Virtual COM Port (VCP) serial interface, ensuring compatibility with Microsoft Windows, macOS, and Linux operating systems. The inline USB fan controller extension cable will also be available as a standalone product within the Noctua HOME product line.
    noctua_computex_2025_140mm_size_desk_fan noctua_computex_2025_usb_inline_fan_cont
    The entire lineup of novelties received highly positive feedback and several products were distinguished with awards at the show. Based on their preliminary sample testing, the team at TechPowerUp awarded the ASUS GeForce RTX 5080 Noctua Edition the Best of Computex 2025 honour. The prototype AIO CPU cooler garnered both the Avrona’s Choice Computex 2025 award and the eTeknix Best of Computex 2025 award. Geekpedia.pl expressed strong anticipation for the Noctua Edition Seasonic PRIME PX HPD series, granting it their Best of Computex 2025 award. TechTesters were equally impressed by the performance metrics of the next-generation NF-A12x25 G2, deeming it worthy of a Best of Computex 2025 award as well.
    Aside from the busy show floor, the NF-A14x25 G2 was recognized as the best fan series, while the NH-D15 G2 earned the title of best CPU air cooler of the year from the European Hardware Association.
