sofix
Posts posted by sofix
και μενα πριν μια ωρα που "επαιζα",κανονικα ολα δουλευαν ρολοι...
το επαιζα σε εισαγωγικα διοτι η ΗΟL με εχει φτασει στο αμην....
C:\Users\******>tracert multiplay.co.uk
Tracing route to multiplay.co.uk [85.236.96.22]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.2.1
2 24 ms 22 ms 22 ms loopback2004.med01.dsl.hol.gr [62.38.0.170]
3 21 ms 23 ms 22 ms gigaeth04-00-07-34.adr01.ar.hol.gr [62.38.99.113
4 22 ms 22 ms 23 ms tengigaeth00-00-00-02.adr00.ccr.hol.gr [62.38.96
.25]
5 24 ms * 24 ms tengigaeth00-07-02-00.adr00.brd.hol.gr [62.38.96
.26]
6 173 ms 169 ms 177 ms gigabitethernet2-0-164.ipcolo1.frankfurt1.level3
.net [62.67.38.17]
7 179 ms 158 ms 159 ms ae-2-79.edge5.frankfurt1.level3.net [4.68.23.77]
8 165 ms 166 ms 166 ms tiscali-level3-10g.frankfurt1.level3.net [4.68.6
3.58]
9 387 ms 378 ms 396 ms xe-2-0-0.lon10.ip4.tinet.net [89.149.186.185]
10 468 ms 475 ms 486 ms multiplay-gw-1.ip4.tinet.net [213.200.78.82]
11 495 ms 489 ms 486 ms www1.multiplay.co.uk [85.236.96.22]
Trace complete.Pinging i3d.com [174.120.129.220] with 32 bytes of data:
Reply from 174.120.129.220: bytes=32 time=615ms TTL=53
Reply from 174.120.129.220: bytes=32 time=612ms TTL=53
Reply from 174.120.129.220: bytes=32 time=614ms TTL=53
Reply from 174.120.129.220: bytes=32 time=632ms TTL=53
Ping statistics for 174.120.129.220:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 612ms, Maximum = 632ms, Average = 618msPinging kplay.de [81.3.59.4] with 32 bytes of data:
Reply from 81.3.59.4: bytes=32 time=175ms TTL=54
Reply from 81.3.59.4: bytes=32 time=174ms TTL=54
Reply from 81.3.59.4: bytes=32 time=176ms TTL=54
Reply from 81.3.59.4: bytes=32 time=172ms TTL=54
Ping statistics for 81.3.59.4:
Minimum = 172ms, Maximum = 176ms, Average = 174ms -
περα απο το smooth,παρατηρω οτι τωρα παιζω ολα medium και εχω ιδια fps με το ολα low..
κατι πηρε το ματι μου στα φορα της ea το update περιελαμβανε optimized settings for dual cores...
αν ξαναβρω το λινκ το ποσταρω
φαινεται να εστρωσαν καπως τα γραφικα μετα το χτεσινο update?
γενικα μου φαινεται πιο smooth η κινηση...
ας παω να φτιαξω καφε να λιωσω κανα 2ωρο...
t3hsofos report for duty...c u in the Battlefield
....till Panathianikos time 22:05
χτες ειδα και εγω πρωτη φορα να δουλευει το friend list..επαιξα λιγο με τον tifozi αν θυμαμαι καλα..
κατι παιζει με τους drivers της nvidia...
εβαλα 196.21,εκανα force off vsync+on tripple buff
(ενω ειχα vsync off ingame,παιζει να το εκανε force on η καρτα?)διοτι τωρα ειδα βελτιωση στα fps...
ολα medium in game,2x k 8x αντiτοιχα.. Min, Max, Avg
29, 53, 38.117
ολα low in game,2x k 8x αντiστοιχα.. Min, Max, Avg
35, 71, 49.767
Τα fps μετρηθηκαν με fraps ( 1 min benchmark ),περπατωντας την ιδια διαδρομη, σε αδεια πιστα,ξεκινωντας διπλα απο το τανκ των attackers κατεβαινοντας το βουνο απο αριστερα κ φτανοντας μεχρι το Β point.
core2duo 4300@ 3,4,2GB RAM,800GT,196.21 drivers,vista 64bit
Θα βάλω ένα fraps να δω ακριβώς. Πάντως, πολύ το ψυρίζουμε για beta
beta ειναι οκ,αλλα ολοι την ιδια βετα παιζουμε,με τα οποια προβληματα της..εχουμε λοιπον ενα σημειο αναφορας..
αναφεροντας τα fps-setups ,μπορουμε να βγαλουμε καποιο γενικο συμπερασμα,οσο αφορα dual cores bottleneck σε ιδιες καρτες,κτλ..
αν εσυ με 9600 + quad εχεις ιδια fps με μενα με 8800GT+c2d ,σε ιδια αναλυση,ειναι ενα αξιολογο συμπερασμα..
ας ριξω και μια ιδεα για να ελαφρυνει αυτο το θεμα.θα μπορουσε να υπαρχει και ενα νεο θεμα,οπου θα αναφερε ο καθεις μονο:αναλυση-vga-cpu-fps-λειουργικο,ωστε να ειχαμε μια εικονα συγκεντρωτικα..
πραγμα αρκετα χρησιμο Imho, μιας και το game φαινεται να ενδιαφερει πολυ κοσμο και στανταρ αρκετοι ψαχνονται για να βελτιωσουν το γερασμενο ισως hardware τους..
Με 4πύρηνο και την 9600GT παίζω καλά με όλα medium. Από κει και πέρα, παρατήρησα καλύτερη κίνηση σε όλα medium, απ' ότι με όλα Low. AA και AF είναι πάντα off.
define "παιζω καλα" διοτι θα αρχισω να τραβαω τα βυζια μου!!
διοτι εγω με c2d @3.4 και 8800GT,αν δεν τα εριχνα ολα στο low δεν εβλεπα πανω απο 30 fps...
medium = 20-25 fps max
edit
παιζω σε 22'' @ 1680x1050
ο μικρός μου αδερφός ήταν sofix (th3sofos σωστά; ), alexandros1305 το ingame name του... όχι ότι εγώ είμαι κλάσσεις καλύτερος , άλλα αυτό που παρατήρησα είναι ότι εκτός του ότι πάει πέρα δόθε σαν κλασσικό ramboκάτσικο (10 λεπτά στο τέλος είδα που κρατούσατε το Β και ζαλίστηκα ), δεν βλέπει το minimap. Revives, health, πέρα βρέχει... Και το Q μόλις το έμαθε... Άλλα θα μάθει, για αυτό είναι οι μεγάλοι αδελφοί άλλωστε
εχει καλο δασκαλο...δεν ανησυχω! (αν κρινω απο το 2142...)
εκει που κρατουσαμε το Β οντως γινοταν πανικ..ετρεχα σαν το κατσικι κ εγω με το ντι-φριμπιλι στο ενα χερι και το μαχαιρι στο αλλο
σας νοιωθω απολυτα εσας τους απο πανω ^^^
μολις επαιξα 2 rounds με τον Αthanasios2104 και αλλα 2-3 παλικαρια "δικους του" και εγινε της σφαγης..
για αυτο το ριμαδι "teamplay" θα καουμε με το παιχνιδι..:worship:
επισης με το "Q-Bombing" μαζευεις και τα ποντακια σου :spot assist (αρκει να ψοφησει ο αντιπαλος..)
οσο αφορα την ενοικιαση καπου ειδα περι 220/μηνα σε ενα σερβερ που επαιζα..
μην αγχωνεστε,θα λειτουργησει το friend list,ειτε μεσω x-fire και θα μαζευομαστε να παιζουμε...:hi:
με σενα επαιζα το απογευμα? "made7" κατι τετοιο..?
ειχαν σηκωσει οι αντιπαλοι :giveup::giveup:
:dance3:
αρχιζω και μαθαινω,εφτιαξε και το ratio...παμε τωρα για >1
btw,το dart οντως ειναι uber unlock..εκανα χαβαλε πριν 2 πιστες μονο με dart κ RPG...
μου φαινεται θα ξαναβαλω xfire..
για θυμιστε μου,τα nicknames τα κανει import απο το game ή οχι?
απογοητευση...122 ms με i3d
Tracing route to 91.198.152.234 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.2.1
2 22 ms 21 ms 22 ms loopback2004.med01.dsl.hol.gr [62.38.0.170]
3 21 ms 21 ms 21 ms gigaeth04-00-05-32.adr01.ar.hol.gr [62.38.99.121
4 21 ms 22 ms 21 ms tengigaeth00-00-00-02.adr00.ccr.hol.gr [62.38.96
.25]
5 21 ms 21 ms 21 ms 212.162.9.42
6 121 ms 226 ms 122 ms GigabitEthernet2-0-164.ipcolo1.frankfurt1.level3
.net [62.67.38.17]
7 121 ms * 123 ms ae-4-99.edge7.Frankfurt1.Level3.net [4.68.23.207
8 121 ms 123 ms 123 ms 195.16.160.66
9 124 ms 122 ms 122 ms 91.198.152.234υποτιθεται η ΗΟL το Mαρτη θα ξεμπουκωσει με νεες γραμμουλες για εξωτερικο..(πηγη: γνωστο adsl forum...)
αν μεχρι τοτε δεν ξεμπουκωσει θα γυρισουμε ολοι εκει που φτυναμε τοσα χρονια..
υπομονη..
ρε αφηστε τα ποστ και παμε να φραγκαρουμε λιγο...:happy2:
αθανασιε,
εγω προσωπικα πρωτη φορα παιζω beta:flag:
μεχρι τωρα,demo ή game σε τελικη μορφη ειχα ακουμπησει, και ποτε beta...
οπότε τα βλεπω ολα λιγο καπως..
αντε ενας μηνας ειναι θα περασει...:happy2:
edit
υπαρχει κανας teamspeak server να μπαινουμε να χαβαλεδιαζουμε ολοι μαζι,γιατι με το friend list της EA δεν βλεπω προκοπη..
αρχιζω και ξενερωνω με ολους τους νουμπαδες εκει εξω...να παιξουμε επιτελους και λιγο ομαδικα..
Καλουτσικο ειναι αλλα μου θυμιζει Battlefield2142.
εμενα παλι, γιατι δεν μου θυμιζει τιποτα απο 2142 ?
και κατι ασχετο...
αν κρατησω το υπαρχον pc(c2d 4300@3.4) και απλα αλλαξω την 8800GT με καποια αλλη, θα παιζει smooth σε 1680χ1050? και ποια θα ηταν μια καλη υποψηφια καρτα να αντικαταστησει την 8800GT χωρις να ξοδεψουμε πολλα?
χτες πρωτη φορα πετυχα friend και παιξαμε μαζι για λιγο..
η λιστα εξακολουθουσε να μου γραφει 0 online..
εχετε βρει εσεις κανενα και να μπορεσετε να κανετε Join στον server που επαιζε?
θα συμφωνησω με jaco και τα γενικα σχολια..
και εγω στο 2142 επαιζα medic μονο και τωρα με ψιλοξενερωνει.. στη beta και παλι το ιδιο παιζω ,με καποιες παυσεις ως engineer ..
τους βλακες καμπεραδες sniper που αντι για επιθεση αραζουν στο βουνο και χανουν καθε φορα στο round,τους αντιπαθω και δεν εχω παιξει καθολου με τετοιο soldier..
παντως σε κανονικο game-map,θες ομαδικη δουλεια,αλλιως δεν κερδιζεις το map με τιποτα..
χωρις να εχω παιξει αλλο bf εκτος του 2142,εξακολουθω να μην μπορω να πεταξω το ελικοπτερο πανω απο 2 λεπτα...μιλαμε παει το epic fail συννεφο!
το red dot απο οταν το πηρα,αρχισαν να φτιαχνουν τα στατιστικα μου κατα πολυ..πριν βαραγα σαν noobas κατα ριπας...
εχει σημασια που σημαδευεις..και στο 1 μετρο να ειναι ο αλλος,αν δεν το σημαδεψεις,απλα τσαμπα σφαιρες χαλας και θα σου ριξει knife kill και θα αναρωτιεσαι απο που σου ερχετε..
δυστυχως ομως η HOL και τα 100+ ping ειναι μειονεκτημα για τετοια παιχνιδια...(διαβαζω οτι εχουμε γενικα σαν χωρα προβλημα με το link εκτος Ελλαδας(?) )
χτες φορτωσα και τα προ-θητειας κλοκια,μπας και δω κανενα fps παραπανω.. profile του 4300 στα 3,4γιγα,αλλαξα drivers σε 196.21(να βαλω τους beta 196.34?),κλοκαρα και την 8800GT στα παλια 700-1000 ,ολα medium,εκτος απο shadows low και βλεπω κατι 30-40 fps πλεον...
η θητεια με αφησε λιγο πισω σε hardware...μαλλον ηρθε η ωρα για αναβαθμιση..
edit
το Q μου δουλευει πλεον κανονικα..κανω spotted οχημα και πεζους....απλα σημαδευεις και πατας Q
ελικοπτερο τραγικα δυσκολο..καμια σχεση με του 2142 που εκανα κολοτουμπες..καλο αυτο!
σχετικα με το fov..
οι παλιοτεροι απο το 2142 θα θυμουνται τι κραξιμο ειχε φαει η ea-dice για τη μη υποστηριξη wide αναλυσεων,με τη δικαιολογια οτι οποιος ειχε wide θα ειχε μεγαλυτερο fov = πλεονεκτημα στο multi
ειχαμε wide και παιζαμε με πετσοκομενη οθονη..κομενα ακρα και μαυρες μπαρες..
τελικα υποστηριξη για widescreen ηρθε μετα απο χρονια official στο 1.5 patch( ασχετα αν κυκλοφορουσαν tricks στη θαλασσα καιρο πριν...)
αν καταλαβα καλα eyefinity θα δινει multi-screen support=μεγαλυτερο fov σωστα? (σορυ δεν το κατεχω το eyefinity μπορει να γραφω και pipes,αλλα κατι αναλογο μου μοιαζει με τον τοτε σαλο..)
εγω προσωπικα δεν δινω δεκαρα,αν θα αποκτησει ο αλλος πλεονεκτημα με το μεγαλυτερο fov,αλλά περιμενω με ενδιαφερον τι σταση θα κρατηθει τωρα απο την ΕΑ....
Και εγώ πάντως μόνο το 2142 έχω παίξει από BF. Στη σελίδα διαλέγεις το μετάλλιο του 2142 και συμπληρώνεις soldier name που είχες στο 2142. Μετά το μετάλλιο από θαμπό πρέπει να γίνεται καθαρό και γυαλιστερό .
και καθαρο και γυαλιστερο εγινε..ειναι ενα μεταλλιο με ενα walker αν θυμαμαι καλα:yes4:
το ποιντ μου ειναι,σε βγαζει τωρα η BC2 beta σαν veteran? εμενα οχι...περιμενα να εχει κατι διπλα στο nickame οπως το χαρακτηριστικο κοκκινο " 2 " που ειχε στους veterans του 2142...
ισως απλα το veteran tag να βγει στη τελικη εκδοση του παιχνιδιου μονο..
οχι οτι εχει καμια σημασια,αλλα λεμε τωρα...
κατι ασχετο τωρα: μπορειτε στο server board να κανετε sort by ping? ή γενικα οποιοδηποτε sort(by No of players,host name etc..)?
Official Battlefield - Bad Company 2 Thread.
In PC Gaming
@jaco
αστα φιλε,η κατασταση με το ping ειναι δραμα...
απλα δεν θελω να γυρισω εκει που εφτυνα(πΟΤΕ) μονο και μονο για το gaming...
τωρα το αν θα αντεξω,ειναι αλλο θεμα...
