skepasti21
    413
Everything posted by skepasti21
  1. Γεια σας, Χθες πλήρωσα για ετήσια συνδρομή συν το expansion αλλά δεν με εψήσε. Μπορώ να ακυρώσω και να πάρω τα χρήματα πίσω? Καπου διάβασα για πολιτική επιστροφής 14 ημερών.
  2. skepasti21
    Stream media FROM Windows 10 PC TO my Android 11 phone using VLC.
    Έπρεπε να ενεργοποιήσω το SMB1 στα Windows από τις δυνατότητες των Windows. Αλλά δεν μπορώ να βρω τρόπο να βλέπει τους κοινοχρήστους φακέλους μέσω της υπηρεσίας ροής πολυμέσων εκτός από την επιφάνεια εργασίας και τους υποφακέλους της που βλέπει ήδη.
  3. Hello all, I'm trying to stream my media FROM Windows 10 PC TO my Android 11 phone using VLC. My files are located on my 2nd D drive which I can't see them in my phone. I'm trying to make it work in 2 ways. FIRSTLY, by enabling the ''Media Stream Options'' in which I can only stream shared media files only when they are located in desktop folder. I tried to turn off sharing option for Desktop Folder with no success, also checked in computer management/shared folders/shares and no ''C:\Users\user\Desktop'' is listed for sharing. Probably, somehow, idk, is it a bug of windows maybe? Also, I put media files backwards, I mean....''C:\Users\user'' with sharing enabled, and files are not listed either, I did that in order to check if the files appear on my phone and no they do NOT! They only shown forwards I mean ex. ''C:\Users\user\Desktop/test folder/kids folder'' and so on. Moreover, sharing by right clicking on desktop folder and then shutting down sharing doesn't work, it seems share is off but actually it isn't, it stays shared FOREVER LoL!!! ..... what on earth is going on??? Why I can’t turn off sharing on desktop folder? SECONDLY by enabling sharing in every folder I want to share by fixing all the owners, privilages rights and adding ''everyone'' as a user. No luck! It keeps asking for SMB credentials on VLC. I have turned off ''password protected sharing'' and tried both options of bit encryptions and I’m logged on my computer with local account without setting up any password, I tried to use only my username but it wont work, it keeps asking for SMB credentials. I can’t make it work which makes me furious. In both ways sharing works when try with another computer. Any thoughts? Screenshot PRNT.SC Captured with Lightshot Απαντήστε στα Ελληνικά παίδες.
  4. Στέλνω σε όλη την Ελλάδα
  5. skepasti21
    Αγορά Νέου Laser Πολυμηχανήματος
    το ξερω και γω τον γλυκοκοιταζω αλλα δεν εχει διαθεσιμότητα
  6. Έχω 3 μέρες τώρα που τα ματιά μου έχουν γίνει κουμπιά από το πολύ το διάβασμα... όπως το λέει ο τίτλος... ψάχνω έναν εκτυπωτή πολυμηχάνημα Laser, ας είναι και μονόχρωμος, δεν με πειράζει ότι και να είναι, με φτηνά αναλώσιμα, γνήσια ή συμβατά, ότι εξυπηρετεί. Ένας γνωστός μου με συμβούλεψε να αποφύγω την XEROX διότι δεν φημίζεται για την υποστήριξή της σε drivers και στην εργασία του έχουν XEROX 7ετίας και έχουν προβλήματα με το word, τι φάση? Επίσης με συμβούλεψε να μείνω με στους HP διότι μέχρι τα 200 ευρώ που μπορώ να διαθέσω εγώ είναι τα καλύτερα μηχανήματα. Μου είπε να κλειστά μάτια να πάρω αυτόν αλλά εγώ βέβαια γλυκοκοιτάζω αυτόν. Λογικά κάλο θα είναι το μηχάνημα να έχει wifi και ethernet. ΑΑΑ και να είναι ετοιμοπαράδοτο διότι το επείγομαι.
  7. skepasti21
    Μουλάρωσε/ Νεο μηχάνημα
    Φταιει η ενημερωση KB5000736
  8. Guys τα φώτα σας, έχω έναν HP Deskjet F2280 ο οποίος για κάποιο λόγο(φταίει το update windows?) έχει μουλαρωσει και εκτυπώνει όποτε γουστάρει, δοκίμασα αλλαγή θύρας, απεγκατασταση και ξανά πέρασμα drivers, ομοίως και τα USB controllers, reset τον ίδιο τον εκτυπωτή. Τίποτα ναδα. Κάποια γνώμη?? Επίσης αν είναι να πάρω καινούργιο πολυμηχάνημα θα ήθελα να μου προτείνετε κάποιο αλλά λογικά το καλύτερο θα ήταν κάποιος laser. Κρίνετε σκόπιμο να έχει θύρα Ethernet? Το λέω σαν επιπλέον λύση σύνδεσης, αν κρίνω από τον εκτυπωτή που έχω τώρα
  9. Πόσο επίδομα θέρμανσης δικαιούνται τα διαμερίσματα σε πολυκατοικία? Παίρνουν αυτά τα ποσά ? Δεν αλλάζει το γεγονός αν μένει κάποιος σε πολυκατοικία ή σε μονοκατοικία. Σωστά?
  10. skepasti21
    Αυτοκόλλητα για στήριγμα κινητού.
    Όχι, θέλω να κολλήσω το δαχτυλίδι πάνω στην βάση του κινητού.
  11. Γνωρίζει κάποιος αν υπάρχουν στην ελληνική αγορά αυτοκολλητα διπλής όψης όπως αυτα εδώ ???
  12. skepasti21
    Εσωτερική καλωδίωση σε πολυκατοικία
    Έφερα τεχνικό, μου μέτρησε το καλώδιο και διαπίστωσε κάποιο θέμα, με την αύριο κάλεσα την COSMOTE για να στείλουν τεχνικό δικό τους, και ξαφνικά κατά ένα μαγικό λόγο πιάνω 90. Αυτα... Με την πρώτη ευκαιρία θα το ρίξω στα 50.
  13. skepasti21
    Τσεκαρετε την φωτό και πεστε μου πως στο καλό θα περάσει το καλώδιο?
  14. skepasti21
    Όχι δεν νοικιάζω, είναι δικό μου. Διάβασα 3 φορές το καταστατικό της πολυκατοικίας και δεν είδα να λέει κάπου για καλωδίωση τηλεφώνου. Αλλά δεν παύει να είναι καλώδια της οικοδομής όμως, όχι?
  15. Χαίρετε κύριοι και κυρίες.... Σήμερα με επισκέφθηκε ο τεχνικός από την COSMOTE διότι είχα θέμα με την γραμμή μου και κατέληξε στο συμπέρασμα ότι χρειάζεται να φέρω ηλεκτρολόγο (δικτύων?) να μου φτιάξει την εσωτερική καλωδίωση. Και ερωτώ... Αυτό πάει στα έξοδα της πολυκατοικία ή τα επωμιζομαι εγώ?
  16. skepasti21
    Stimulus check impact payment
    Τέλεια
  17. skepasti21
    Είμαι Αμερικανός πολίτης και μένω μόνιμα στην Ελλάδα, ήρθα στην Ελλάδα όταν ήμουν παιδι. Όταν αρχισε να δίνεται το βοήθημα, εγώ συνειδητοποίησα ότι δεν έχω το SSN, πήγα στην πρεσβεία και έκανα αίτηση για απόκτηση του SSN. Χθές ήρθε, και προσπαθω να μάθω πως γίνεται η διαδικασία και δεν μπορώ να βγαλω άκρη. Αυτό που νομίζω ότι έχω καταλάβει είναι ότι ο τρόπος που δόθηκαν τα χρήματα στην αρχή ήταν για τους NON FILLERS που λογικά σημαίνει ότι ήταν γι' αυτους που δεν κάνουν φορολογική δήλωση στις ΗΠΑ, αλλα πλεον αυτον ο τρόπος δεν ισχύει και αυτο που μπορείς να κάνεις είναι μέσω του Recovery Rebate Credit που δεν έχω καταλάβει τι είναι. Λογικά ειναι φορολογική δήλωση και οι γνώσεις και η σκέψη μου πανε μέχρι εκεί. Εννοήται δεν έχω κάνει ποτέ φορολογική δήλωση στην Αμερική.
  18. Υπάρχει κάποιος που να γνωρίζει ή να έχει κάνει την διαδικασία για το βοήθημα 1200 λόγω covid από Αμερική?
  19. skepasti21
    Δαπάνη για σύστημα παροχής νερού
    Σας ευχαριστώ όλους για τις απαντήσεις σας, για κάποιον μπορεί να ήταν μια χαζή ερώτηση αλλά ως γνωστόν δεν υπάρχουν χαζές ερωτήσεις. Και πάλι ευχαριστώ πολύ ?
  20. skepasti21
    Αυτο λεω ποιο απο ολα?
  21. Γεια σας, ζω σε πολυτκατοικία οπού έχει παρουσιαστεί βλάβη στο σύστημα παροχής νερού , μοτέρ/φούσκα και μετά απο ενημέρωση τεχνικού θα γίνει προμήθεια νέου συστήματος και θα ήθελα να ρωτήσω η κατανομή κόστους πρεπεί να γίνει επί ίσα μέρη ανα διαμέρισμα ή ανάλογα τα χιλιοστά του κάθε διαμερίσματος? Και αν εν τέλει είναι ανα χιλιοστά, ποιά χιλιοστά πρέπει να χρησιμοποιηθούν? Κοινοχρήστων, ανελκυστήρα ή θέρμανσής?Σας Ευχαριστώ.
  22. skepasti21
    Παραγγελία από Eglobal central eu
    παραγγελια 22/12/20 , παρελαβα απο ελτα κουριερ 01/02/21
  23. Γεια σας, έχω τα 153 επεισόδια του Dragon Ball 1 και για το λόγο ότι η εισαγωγή είναι στα τζαπανικά και θα ειναι ειναι λίγο χαζό για το γιό μου να μην καταλαβαίνει, θέλω να αντικαταστίσω την εισαγωγή με την ελληνική που υπάρχει στο YouTube. Υπαρχει καποιος ανώδυνος τρόπος να γίνει? Δοκίμασα με το Adobe Premiere Pro άλλα μέχρι να τα κανω όλα εκεί, θα γίνω παππούς. Τα πιο εύκολο που βρήκα μέχρι στιγμής ειναι το video editor των windows 10 αλλα και παλι καθυστερεί πολυ και το χειρότερο είναι ότι δεν μπορεις να επιλεξεις συγκεκριμένη χρονική στιγμή. (εκατοστά του δευτερολέπτου) Άραγε υπάρχει κατι να τα βάλω ολα μαζι και να γίνουν? Γνώμες?
  24. skepasti21
    Κλήση Τροχαίας
    Αυτό λέω όμως, δεν έχει στοιχεία οχήματος!
  25. skepasti21
    Κλήση Τροχαίας
    Δεν είναι όμως ότι δεν έγραψε τίποτα στα στοιχεία του οχήματος, αλλά ότι έγραψε "ΑΠΩΝ"! ΑΥΤΟ λεω, να δεν έγραφε τίποτα απολύτως εκεί δεν θα το έκανα θέμα.
