Posts posted by John@John
A few words about Assetto Corsa’s physics limitations.
Modern openwheelers can be very stiff … i mean extremely stiff, springs and ARBs (dampers as well)! and Assetto Corsa has engine limitations that doesn’t allow using high suspension rates (causes weird bugs)!
Interactive aerodynamics physics is a must for an openwheeler, rear aero depends on what’s happening at the front and the rear not only the rear! and vice versa (interaction between front wing and diffuser for example)
Tyre model is not well explained and needs more variables to be added, to get realistic grip and temperatures/pressure behaviour! You can’t cook accurate slicks with it.
Lack of setup options possibilities in general.
“ The physics of Assetto Corsa are not of simulation value, when you compare it to the way a racing driver and racing team and even vehicle manufacturers can use rFactor and rFactor 2’s physics to develop their cars and their drivers in a way that provides accurate data which they can rely on to use at races.
To give you an example. All our race team clients and even our series clients, they don’t only use rFactor for track familiarization. They also use it to test setup data before they go to an event, they use it to test potential new part data, by developing new brakes or new engine performances and testing it in the game before they actually commit to building it in real life. rF1 and rF2 provide far higher accuracy for those things than any other simulation on the market. When it comes to Assetto Corsa, their game is marketed for a set audience which covers the Semi-Arcade side. When I drive rF1 or rF2, I’m always in a serious state of mind, I can’t just go out on the track and run a few laps. It is too simulation based and I treat it as such. I work on my setups, I push to find every tenth I can throughout a lap. I analyze too much. When I play Assetto Corsa, I can easily go in, pick a car and track, chill back and drive When using my Xbox360 controller and not give a care. The physics seem very much like Forza Motorsport 5, a console game physics HOWEVER, Kunos has done a great job for the simcade fans, but cut down to the wire, rFactor 2’s physics engine is by far the most simulation based physics engine using real life aero and physical data that no other title has come close to.
Assetto Corsa is developed by Italian studio Kunos Simulazion – Released last year for Windows, the game will be coming to PS4 and Xbox One next year, it does cede a little more ground to the notion that ‘game’ isn’t such a dirty word.
According to James Dover, the game can be happily played with a controller. But while the game does deliver in terms of graphics, James reckons its physics engine “lacks seriousness”.
A few words about Assetto Corsa’s physics limitations.Modern openwheelers can be very stiff … i mean extremely stiff, springs and ARBs (dampers as well)! and Assetto Corsa has engine limitations that doesn’t allow using high suspension rates (causes weird bugs)!
Lack of setup options possibilities in general. ”
2
πριν 3 λεπτά, το μέλος mad_dog έγραψε:
Kαλά ρε Γιάννη...τόσα χρόνια γνωριζόμαστε...με δίνεις στεγνά στους οχτρούς ???
Har har har
Οχτρούς ??? Μα εσυ ειχες teamate και εγω ημουν μονος,ασε που ετρεχα με αλλη εταιρια
πριν 7 λεπτά, το μέλος liakjim έγραψε:
Μπράβο, βλέπω 1.5δευτ κάτω από τον Senna. Γ@μώ τις εξομοιώσεις...
Πέρασα μια βολτίτσα, ο εγκέφαλος πήγε να ξεράσει από αυτά που έβλεπαν τα μάτια μου , το FFB όπως πάντα φοβερό, οι ήχοι καλούτσικοι αλλά όταν άρχισα τα κολίδια λέω οκ , καιρός να την κάνουμε.
1ον)μπορεις να κατεβεις και κατω απο το Senna γιατι δεν ρισκαρεις την ζωη σου και τρεχεις εκ του ασφαλους
και 2ον) για τα κολιδια ,η κανε κανα σεταπ της προκοπης η απλα μαθε να οδηγας..........
1
πριν 3 ώρες, το μέλος troffeo έγραψε:
Βέβαια περιμένω από τα γνωστά alien @John@John @panosdimp @rapid_fast και σια
, να τους φτάσουν εύκολα τους χρόνους αυτούς!
Allien απο που και ωσπου ωρε Γιωργη??Ασε που με 10 χρονια ραλλυ στην πλατη σε αυτα τα γυρω-γυρω ολοι μην πω οτι ειμαι και λιγο αργος...( κατσε ακομα αρχη ειναι........
πριν 2 ώρες, το μέλος mad_dog έγραψε:Δεσμεύομαι να ξεκινήσω τον αγώνα με 300kg ballast για να μπορέσει να υπάρξει ανταγωνισμός.
Δεν χτυπάω ακόμη χρόνους γιατί δεν θέλω να φύγει ο κόσμος από το πρωταθληματάκι που κάναμε. Την Κυριακή θα τιμωρήσω τους επικριτές μου.
Εσενα τι σε ταιζει η Μιτσουμπιση και δεν πετας τη σαβουρα ακομα δεν ξερω..........................μου θες και χρονους με το τσιρκο εκπληξη
5
On 6/17/2016 at 3:06 ΜΜ, το μέλος mad_dog έγραψε:
To skin όπως σου είπα θα το κάνεις.
Το χελωνάκι στο καπό.
Φωτιές στο πλαι.
Το mad dog και αυτό στο πλαι κάπου να φαίνεται ωραία.
Πίσω να γράφει "Τα λέμε στον τερματισμό σαλιγκάρια".
Επάνω βάλε κάτι που να ταιριάζει στο όλο...
Το θέλω σύντομα να μπω στην πίστα να σπείρω τον πανικό !!!
On 6/17/2016 at 0:15 ΜΜ, το μέλος mad_dog έγραψε:Λοιπόν...Γιάννη για το skin
Το θέλω όλο το χρώμα μπλε. Στο καπό θα βάλεις την χελώνα όπως βλέπεις την εικόνα παραπάνω.
Πίσω στο καπό θα γράψεις: Τα λέμε στον τερματισμό σαλιγκάρια
Στο πλαι θέλω φωτιές.
Το βάψιμο θα το κάνεις ολο μπλε και μετά θα ξεκινήσεις να βάζεις τα παραπάνω.
Στο καπό θα βάλεις και 2 γραμμές λευκές να ξεκινάνε, να συνεχίζουν στην οροφή και να φτάνουν μέχρι το τέλος.
Διαφημιστικά βάλε στο τζάμι το pcgamingforum.net
Βάλε μετά κανά αυτοκόλλητο από Shell κ.τ.λ. και ότι άλλο νομίζεις εσύ.
πριν 27 λεπτά, το μέλος mad_dog έγραψε:Τι λε ρε μάγκα...
Έκανες τέτοιο skin στην καθυστέρηση και σε εμάς έδωσες το τσίρκο ???
Μπράβο ρε...ωραίος είσαι
Kαι με αυτα τα μυαλα,,,,θες να κερδισεις και αγωνα???????
2
πριν 7 λεπτά, το μέλος Anthemius έγραψε:
Ευχαριστώ και σορρυ για το off topic και πάλι :-P
off topic ?εδω εισαι στο σωστο μερος περι rf2,το γραφει και η επικεφαλιδα που καποιο απο τα εξιδεικευμενα μελη θα σου απαντηση λειαν συντομως,ας τους αλλους να λενε ,τους βαρεσε η ζεστη,,,,και τα κεφτεδακια.Που να'ρθει και ο Αυγουστος,,,,,,,,,,,,
1
rFactor 2
In PC Gaming
" AC has no front end force feedback. Like when you turn the wheel in real life you feel the rubber grip and turn and the wheel kinda moves back because of the grip of the tires. This flat out does not happen in AC and is really disappointing. Stock Car Extreme and rF2 feel like how a real car steers. I thought AC was the best thing until playing Stock Car Extreme and rFactor2. AC feels more like you're only driving the back half of the car. AC also doesn't handle well at lower speeds. I drive a GTI in real life and it feels more nimble than the Ferraris in AC when driving at everyday speeds and they're full of understeer. That's part of the reason it's being called a hotlap simulator, it only feels ok at high speeds when you start taking time off your laps.
Just drive in real life and compare to the games. RF2 is the closest thing to real driving I've played. And I don't mean daily drive, you're not pushing the limits, get some real track time and learn to drive properly then decide what's best. "
