Central Brain Identifier 7.2.0.6 Beta Build 0808
New features include: ability to change DRAM timings on VIA KT266/A, KT333, KT400/A, KT600 and SiS735 chipsets.
Far Cry Benchmark v1.3.0
IMPORTANT! Install...
  1. Uninstall the old version of HardwareOC Far Cry Benchmark.
  2. Find the fxc.exe file (if it exist) in the Far Cry \Bin32 folder.
  3. Delete.
  4. Install the 1.3.0 version of HardwareOC Far Cry Benchmark.
What's new?
  • Unsupported Far Cry version detection.
  • Added Ultra details (can get any VGA card on it's knees, on average 10-30% performance drop).
  • Minor fixes.
  • Display HUD removed.
  • Updated HLSL Command-Line Compiler version to the official 5.4.0.2904.
  • Added screenshot function.
  • New startup logo.
  • Modified uninstaller.
  • Replies 748
  • Added defragmentation support for test files used by the benchmarks: Sandra will defragment all test files created to ensure the performance measured is not impeded by fragmentation of the test files created. (All versions)
  • Added Intel Pentium 4 and Xeon (Nocona) reference results in Windows x64 edition. Now you can compare and contrast the performance of Intel and AMD solutions in both legacy 32-bit x86 mode and 64-bit x64 (AMD64/EM64T) mode. You can also compare the results with Intel 64-bit IA64 systems. (All versions)
  • Added support for Intel E7520/7320/7525 chipsets; fixed support for Intel 910/915/925 PCI Express chipsets. (x86 and x64 versions)
  • Added support for PCI Express video cards. (All versions)
  • Support for latest Build 1218 of Windows x64 edition. (x86 and x64 versions)
  • Improved reliability of Windows Mobile 2003 and 2003 Second Edition remote information & benchmarking library. (All versions)
  • Added support for Windows CE 4.20 x86 standard editions through additional remote information & benchmarking library. (All versions)
  • Compatibility verified with Windows XP SP2 Release version and Windows 2003, XP 64-bit, XP x64 SP1 Build 1218. (All versions)
download
  • Scan for Artifacts now makes a log entry every 15 minutes.
  • Added and tested X800SE PCI-E overclocking support.
  • When the main window is partly or completely off screen when launched, it will be moved to be visible.
  • Render window requires a hw accelerator + running driver.
  • Disabled maximizing/minimizing of render window.
  • Moved I2C access code into kernel driver.
  • Added option to set video card PCI latency
  • Improved theme support (more like enabled it).
  • Added option to create desktop icon after install.
  • Added RV410 support.
  • Added Video Memory Timings Editor (not in 0.0.21 release but in next dev. build)
  • Added option to disable the tray icon (icon will always be visible while ATITool is initializing).
  • Added Gamma Control
  • Added experimental "Remove 9000/9200/9550/9600 clock lock"
  • Trying to overwrite the default profile now gives an error msg.
  • Added option to limit log file size.
  • Bugfixes to the installer.
  • Added fan control for X800.
  • Added options to disable Direct3D error messages.
  • Added shared memory, other applications can now get ATITool data.
  • Fixed settings window popping up in wrong place.
  • Statically linked version - distribution is now only 820 KB in size!
  • Updated Kernel Mode driver - getting ready to port to 64 Bit.
  • Tray icon is automatically recreated when explorer crashes
  • If the tray icon can't be created (possible during windows startup, explorer is not running yet) just continue loading and create the icon as soon as explorer is ready.
  • Added text field with temperature to main window.
  • Added support for Radeon 9550 - these cards are overclocking locked. Use the softmod drivers.
  • Added support for sending clock/temp. data to MBM
  • Added option to log temperatures
  • Added overclocking/temp. monitoring support for X600.
  • Added temp. monitoring support for 9800 PRO on XT PCB with temp. chip.
  • Profile selection is no longer saved on exit, but on change.
  • room.x now included in executable.
  • Fixed bug where the tray temperature display would get stuck on desktop resize.
  • 3D detection seems to have issues with DirectX 9.0C beta - this will not be addressed until the final version of DX9.0C is out.
  • Fixed bug with temperature detection
  • Fixed bug where find max. would try too high clockrates when clock frequency limits are enabled.
  • Added warning if D3D Debug Runtimes are active.
  • Screensaver will be disabled during 'find max' and 'scan for artifacts'
  • Added 'add to start menu' all users/current user
  • Tweaked 3D detection, will now work with UT2K4's d3d9 renderer
  • Added option to change font/color of temperature in systray
  • Added temperature monitoring for ASUS cards, thanks Peter
  • Added extra checks to low-level hardware code
download
  • Disc Quality Test:Added support for AOpen DVD1648/AAP, AOpen 48x and 52x Combo drives and drives with a Ricoh chipset (click here for a detailed list).
  • Added option to show Disc Type or Book Type on main screen
  • Improved reading type detection
  • Improved write performance for external USB drives
  • Many small improvements and bug fixes
download
Bench'emAll! 2.59
21.08.04, version 2.59
- Doom3 support added.
- 640x480 resolution added for 3dMark03, SeriousSam, Vulpine GL Mark, Quake3.
- SeriousSam: Fixed a pause with "information" message.
- UT2004: Fixed a 1600x1200 resolution issue: now 1600x1024 and 1600x1200 are available.
- AquaMark3 Pro Plus supported.
- RightMark Video Analyzer: 800x600 resolution result parsing fixed.
- Custom command line added for FarCry.
- Half-Life 2 support added.
DOWNLOAD
  • Now timings can be loaded at start up. You must select which profile will be loaded at start up time, insteed of selecting clocks values.
  • Added 2 new hot keys , very usefull for mobile computer users. Will work on desktop system only if your monitor support this interface.
  1. Turn Monitor Off
  2. Turn Monitor On
  • Now color settings will not be reset if you change resolution
  • Added option to automaticaly overclock your card if any application required 3D Api (OpenGL/Direct3D)
    How it works.
    If you enable 2d/3d overclocking you must set which profile shoukd be loaded when application enter 3d mode and which profile load after this application finished. ATT some times can not detect when game use 3d mode. If you find such kind of game, create profile for it.
    Also you can create the list of application which should be excluded from auto 2d/3d detecting. Some of the applications already excluded internaly by ATT and never will be monitored.
    explorer.exe
    atitray.exe
    atitool.exe
    nvmixer.exe
  • Changes in game profiles
    For Game profiles now you can set 3 options:
  1. Take no action - ATT will do nothing even if you enable 2d/3d overclocking and game use 3d mode.
  2. Custom overclocking - If you set this option ATT will use overclocking profile you provided for this game only. even if 2d/3d overclocking is enabled.
  3. Use auto 2d/3d - This option tells ATT to use global 2d/3d profiles. This option has no effect if you disable 2d/3d overclocking. But if you set this option (with global 2d/3d detection enabled) and your application does not require 3D mode, 3D profile anyway will be loaded.
  • Screensave will be disabled while 3D Render window is active.
  1. Removed "Autodetect Starting Games". Now this option is part of auto 2d/3d overclocking and always ON. It can not be disabled.
  2. Removed "With CPU Heat" function from Artifact tester. Now tester itself can heat main CPU.
download
  • extended DRAM latencies control for nVidia nForce2
  • ability to detect and change the values of tCL, tRAS, tRCD-R, tRCD-W, tRC and tRFC
  • now it is possible to set 1.5T for CAS Latency on VIA KT400/A/KT600 and to change the latency of tRC on SiS746/746FX/748 chipsets
  • full support for AMD Sempron processors (Socket 754)
  • bugfixes
download
Enabling 16 Pipelines On Your GeForce 6800
We recently reported that Alexey Nikolaychuk, the author of RivaTuner, has found the mechanism, which NVIDIA cards use to set 12 or 16 pipelines on GeForce 6800 and 6800GT/Ultra, respectively. Of course, if a card has 4 offline pipelines defective, it will produce artefacts and we can't guarantee that any GeForce 6800 can be remade into a 6800GT!
Well Digit-Life reports the new version of RivaTuner that will allow NV40 pipeline management and will provide information about active pipelines amount is expected early in September.
http://www.warp2search.org/modules.php?name=News&file=article&sid=19606&mode=thread&order=0&thold=-1
Alexey (RivaTuner programmer)
Yesterday I've received new MSI 6800 instead of old Leadtek 6800, which died during unsuccessfull BIOS flash (Thanks a lot to Andrew Worobiew for providing new one). So I was able to continue NV4x internals exploration and found some extremely interesting facts.
First, our assumption about dyad based pipeline control seems to be wrong. Pipelines are still masked at quad level rather than on dyad level. So RT's pipeline control tab is redesigned and will look a bit different comparing to the screenshots walking in the net.
Second (and the most interesting), I've found the way to detect and enable/disable active vertex units on NV40 boards. The most surprising fact is that _ALL_ 6800 non-Ultra boards I've seen have at least one disabled (bad?) vertex processor too, so just 5 or less of them are active instead of 6 in Ultra models. Like quads, vertex processors can be also disabled at both software and hardware levels, so RT will help you to unlock them only in the first case. Currently we're collecting 6800GT statistics to understand if these processors are full 6800U analogues or they also have ripped configuration due to disabled vertex processors. Also, we hope that NVIDIA will clarify specs for 6800NU/6800LE/6800GT boards, because currently we see the boards with different amount of disabled vertex units sold as regular 6800 model.
That is why I'd like to warn everybody going to buy non-Ultra 6800. We've already detected $350+ OEM Leadtek 6800 boards in Russia, which have 2 disabled quads and 2 disabled vertex processors. So if you're going to buy such board, we strictly recommend you to wait for new RT release and to verify the board before (or immediately after) purchasing. Otherwise you may get a regular 6800LE for a fabulous price.
Stay tuned.
New Features
  • Added advanced dectection for E7500/E7501
  • Added support for FSB533 LGA775 CPU
  • Added support for DDR2-600 mode on i915/925.
  • Added detection for Xeon DP/MP
  • Added detection for AMD K8 Sempron
  • Added detection for SiS 661
  • Added a new .EXE distribution file for USB Key
Bug Fixes
  • Bug Fixes with i915/925X memory ratio
  • Rewrite the buggy E7500/E7501 ECC Polling code
  • Fixed the KT133/266 freeze bug (again)
  • Fixed crash with ATi RS300 & Pentium M
  • Some bugs fixes & code optimization
download
Atitool 0.22
* Fixes to card detection on some ATI chipsets
* Fixed "When setting the speed in the log the selected speed is shown not the actual speed it is set to." (#38)
* Added infobox about possible problems when FRAPS is running
* Removed fan control tab for 9600.
* Some fixes to "try to keep gpu temp at". It will only work while ATITool is running. If you close ATITool fan speeds are set to ATI's defaults
* Fixed temp. reading error which showed 20° on 9800s with high load sometimes
* Disabled creation of file C:\Atitool detection log.txt
* Fixed excessive log entries generated during Find Max (#29)
* Fixed 3D detection for XP SP2 + AMD64 (#25)
* Forced 3D detection on for all executables starting with "bf_vietnam" (Battlefield: Vietname) until a proper fix is found
* Forced 3D detection on for all executables starting with "nwmain" (Neverwinter Nights) until a proper fix is found
* Fixed rounding error in fan speed settings (#16)
* Fixed rounding error in font size display in temp. settings (#23)
* Added current fan speed display to fan speed settings (#22)
* Memory timings editor is active now
* values are not permanent and are reset at reboot. USE AT YOUR OWN RISK.
* Gamma settings are reapplied when display mode is changed (#14)
* Gamma settings panel shows numbers (#14)
* Added fan control option "Try to keep GPU temp. at xx°C"
* this option is only available if temp. monitoring is enabled
* Added mini stats to temp. monitoring settings page
* Several speed optimized artifact detection code
* Dump bios button disabled on 9200 until a fix is found
* Replace temp. remote / local by "GPU" / "GPU environment"
* Fixed cosmetic bug in temp. settings panel (#15)
* Fixed bug with log file max. size .. the value was interpreted as Bytes (#13)
* Added include list for 3D detection
* No "scan running" message to log file right after start
* Fixed crash in 3D detection for 3dmark2001 and probably other apps
* Gamma hotkeys are disabled when gamma control is disabled
* Lots of fixes based on the great feedback after the 0.0.21 release, critical fixes are already incorporated into the 0.0.21 download
* Added option to scanning settings: "disable screensaver while scanning"
* Fixed ATI fan control. for some reason ATI defaults result in fan speeds > 100% to be programmed. This means that any fan speed >75% is actually 100% (can't run the fan faster than 100%). ATITool fixes this by setting the right register on the temp. chip.
* Moved fan speed registry key so its not lost every time you reinstall ATITool
download
