lefteriz Δημοσιεύτηκε Σεπτέμβριος 19, 2014 #1 Κοινοποίηση Δημοσιεύτηκε Σεπτέμβριος 19, 2014 5.1 AC3 DTS Audio Gear Digital Sound Decoder SPDIF PS3 Decode Features: Signal to Noise: 120db Degree of separation: 85db Frequency Response: (20Hz-20 KHz) +/- 0.5db Max Output Volt: 2.2V Power supply DV/5V 1A, (outlay 110V-240V broadband convert Convert DTS/AC3 source digital audio to analog 5.1 audio or stereo audio output. The analog stereo (L / R) signals convert to analog 5.1 channel output. Multi-channel audio input (SPDIF , Coaxial, Stereo) 2 x SPDIF input, 1 x Coaxial Input, 1 x Stereo Analog 5.1-channel or Stereo output Dimension (mm): 106x74x25cm Digital Audio Decoder: Used 24-bit audio DSP, 96 KHz digital receivers, and 192 KHz/24bit ADC and DAC. Support Dolby Digital AC-3 Dolby Pro Logic, DTS, PCM and other digital audio format source decode, a variety of sound field and the replay results of two listening modes, 5.1 analog audio output, will auto work with different amplifier and speakers to get different sound effects, easy to connect many entertainment devices which with optical and coaxial digital signal and analog output signals (such as: set-top boxes, HD players, Blu-ray DVD, PS2, PS3, XBOX360). 25 ευρώ Amplitude iRig The iRig is a revolutionary product that allows you to connect your guitar/bass to your iOS device. From there, your signal travels through the wonderful world of AmpliTube iOS software to give your guitar sound life and meaning. To use the iRig, you simply plug the 3.5mm TRRS end into the headphone jack of your iOS device. Then plug your guitar into the 1/4" jack using a standard guitar cable. To monitor your sound, plug your headphones/line out into the 3.5 mm headphone jack on the iRig. That's all there is to it. Now you're ready to Jam. 15 ευρώ. Τα πράγματα ειναι αχρησιμοποίητα. Κατάθεση και αποστολή παντού. Link to comment Share on other sites More sharing options...
