620w:θα μου φτάσουν?
MasterCommander
και το corsair τελικά έχει μια 12άρα και καλή:banging: :
http://forums.extremeoverclocking.com/showthread.php?t=136602
Please note that the Seasonic built Corsairs & Antecs (HE & Trio) are, regardless of advertising,
Single +12V Rail PSU's, in that there is no per-rail current limiting, meaning that any +12V rail can pull whatever +12V amperage is available. This is also true of the Seasonic M-12's.
The Corsairs are built to higher standards than the Antecs.
τελικά δεν άντεξα και πήγα και το πήρα:hehe:
θα το βάλω στο σύστημα της υπογραφής,και όταν φτιάξω το καινούριο σύστημα θα ανακαλύψω στην πράξη αν μου φτάνει ή όχι:...:
το corsair έχει 3 12άρες αλλά εννοείται ότι είναι μια χαρά psu. Αυτά που έχουν μία 12ara είναι VX που δεν βγαίνει στα 620
Αρχική απάντηση από MasterCommander
....θα το βάλω στο σύστημα της υπογραφής,και όταν φτιάξω το καινούριο σύστημα θα ανακαλύψω στην πράξη αν μου φτάνει ή όχι:...:
Mια χαρα θα εισαι απο τη στιγμη που δεν θα εχεις sli/crossfire και ο/c.
Kαλοδουλευτο...
Looking at the Seasonic main PCB inside the Corsair PSU reveals only two rails, labeled 12V1 and 12V2. There is no third rail. This is illustrated well at Hardware Secrets. Although I can not say that these rails are or are not somehow electronically separated in the PSU's circuitry somewhere, I did find that there was no OCP (over current protection or "limiter") on either of these rails as I was able to load any given connector up 30 to 40A with no drop in voltage, system shut down, etc.
So it is my opinion that we essentially have a single 12V rail PSU here. Certainly there is nothing wrong with this given the problems high end video cards have had with getting enough power from a single 12V rail when the OCP is set to the typical 240VA limit. But we do lose the advantages of multiple rails such as protection from damage to one rail from a short on another and the simple "filtration" of noise introduced from one rail to another.
http://www.jonnyguru.com/review_details.php?id=32&page_num=2
δεν ξέρω αν κταλαβαίνω έγω κάτι λάθος επειδη είμαι noobas,αλλά εδώ δε λέει ότι το corsair έχει μία 12άρα?
Αρχική απάντηση από effect [Σήμερα, στις 14:14]
Addendum:
edit: με προλαβε ο Μαστερ :)
Αρχική απάντηση από MasterCommander [03-10-2007 13:10]
[*]6 δωδεκάρια case fans
Τι στο καλο θές 6 fans?
Λάθος δικό μου από βιασύνη....αλλά αν υπολογίσεις ότι το antec έχει 3 12αρια και έναν μεγάλο 20άρι,και μπορείς να προσθέσεις και στο μέλλον και άλλα δυο..
+1 Για το Corsair. Πραγματικό σκυλί. :)
Αυτό έχω και εγω αν και δεν το εχω πιεσει ακομα πολυ.
Τα legitreviews ομως τα λενε όλα. +Είναι κορυφή απο πλευράς θορύβου.
Να πω ακόμα ότι ουσιαστικά μιλάμε για το μοντελο της seasonic m12-700 χωρις τον ένα απο τους 2 ανεμιστηρες. ( Η seasonic κατασκευαζει το corsair και διατηρει τις κατασκευαστικες αρχες των σειρών m12 και s12)
Και τα 5 χρονια εγγυση που τα βάζεις;
Edit
Τωρα είδα οτι το πήρες. Καλορίζικο!
Εγώ πάντως δεν νομίζω να φτάσουν. Να έχει κα λίγο αέρα να μην δουλεύει στην τσίτα το PSU...
Εφόσον δεν θα βάλεις sli/crossfire και δεν είσαι fan του overcloking θα σου φτάσουν και θα σου περισσέψουν κιολας
