Posts posted by LocoDiceGR
AMD Radeon Software Crimson 16.7.3
DRIVER BUILD
16.30.2311
SUPPORTED SYSTEMS
Windows 10 32-bit/64-bit
Windows 8.1 32-bit/64-bit
Windows 7 32-bit/64-bit
HIGHLIGHTS
Performance Improvements:
Rise of the Tomb Raider™ performance increase up to 10% versus Radeon Software Crimson Edition 16.7.2 on Radeon™ RX 480 graphics
FIXED ISSUES
Overwatch™ may experience an application crash on some Radeon™ RX 480 configurations when using AMD Crossfire mode.
Vulkan™ information in the Radeon Settings software information tab may display an incorrect version.
Radeon WattMan may retain settings of an overclock after it has failed. If you have failed an overclock with a system hang or reboot.
Hitman™ may experience graphical corruption when the game is set to use DirectX®12 API and using zoom with weapons.
Total War™: Warhammer may experience minor graphical corruption in some map textures on AMD Radeon R9 380.
Flickering may be observed in Rise of the Tomb Raider™ on some AMD Crossfire configurations using the DirectX®11 API.
Changing settings in Dragon Age Inquisition™ with the Mantle API may result in an application crash or driver recovery.
DiRT™ Rally may experience flickering terrain in some races when the advanced blending option is enabled in the games settings page.
Display may exhibit a minor flicker on Radeon RX 480 when Freesync is enabled on a games launch or exit.
Shadows may experience rendering issues in DOTA2™ when using the Vulkan™ API.
Textures may experience holes or gaps in DOOM™ when using the OpenGL API and three display AMD Eyefinity configurations.
Need for Speed™ may experience flickering on some light sources in AMD Crossfire mode.
Performing a task switch with two cloned displays during full screen gaming may cause flickering on the extended display.
KNOWN ISSUES
A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
DOTA2™ may experience an application hang when using the Vulkan™ API and changing resolution or game/quality settings.
DiRT™ Rally may experience rain drop flickering in some races when using AMD Crossfire mode.
Displays may fail to revert to previous configuration on exit when using a profiled application launched with Radeon Settings and "Launch with AMD Eyefinity" toggled on.
Assassin's Creed® Syndicate may experience a game crash or hang when in game settings are set to high or greater.
Low frame rate or stutter may be experienced Wolfenstein®: The Old Blood™ on Radeon™ RX 480.
Radeon RX 480 graphics may experience minor flickering in SteamVR benchmark when using AMD Crossfire mode.
Corruption may be experienced in Rise of the Tomb Raider using the DirectX®12 API on some Hybrid Graphics configurations when performing a task switch.
Shader Cache may remain be enabled when set to "off" in Radeon Settings on some Hybrid Graphics configurations.
Radeon RX 480 graphics may experience intermittent stuttering in The Division™ when high game settings are used and vsync is enabled.
Battlefield™ 4 may experience intermittent crashes when using Mantle. As a work around users are suggested to switch to DirectX®11.
Creating two or three display portrait Eyefinity groups in Radeon Settings "quick setup" and then clicking "arranging displays" may cause an error.
Radeon Pro Duo may experience a black screen in Total War™: Warhammer with the games API set to DirectX®12 and V-Sync enabled.
World of Tanks™ may experience stuttering after performing a task switch in AMD Crossfire mode.
Rocket League™ may experience flickering when in AMD Crossfire mode.
DOTA2™ may experience lower than expected performance when in AMD Crossfire mode.
Ashes of the Singularity™ may experience an application crash with "crazy" in game settings and Multi-GPU enabled.-
1
1 hour ago, FrOsT said:
Για να βάλω μια reference rx480 στην dvi only οθόνη μου τι ανταπρορα θα χρειαστώ;
Νομιζω πως εχει μεσα ανταπτορα η συσκευασια...
Γιατι reference?
Dexter?? Ειναι καλο/πολυ καλο/must watch?
Εχω αργησει το ξερω..
2
Γιατι βαζουν τοσο αθλια μουσικη μερικα καναλια,
3
3 minutes ago, greenforce13 said:
Τα κλειδάκια δόθηκαν
Thanks!!!!!!
1
Απο την στιγμη που η μητρικη μου 1156 δεν εχει θεμα,
ουτε εσυ θα εχεις.
*Εχουμε ιδια γενια επεξεργαστη/μητρικη (εσενα ειναι καλυτερα).
12 minutes ago, greenforce13 said:
χαριζονται κλειδάκια για:
1) The Darksness ll
2) Duke Nukem Forever
εγω για το 1ο
Thanks!
Λογικα: 470 καλυτερη απο 380Χ,
και 460 καλυτερη απο 370?
45 minutes ago, giorgos2187 said:
Many????
χαχα, ε με αυτα που βαζει και λεει ο panosmambax τι να πω.....
2
4 hours ago, PANOSMAMBAX said:
Παιδια μην το τραβάτε άλλο η 1060 θαβει την RX 480 απο παντου.Παρτε την Nvidia αυτην να εχετε το κεφαλι σας ήσυχο
οτι να ναι φιλε μου!
On 7/21/2016 at 7:14 AM, giorgos2187 said:
Κ#@Λ%^ΦΑΡΔΕ!!
Να ξερεις παντως οτι η καρτα σου δεν ειναι Φιουτσεπρουφ.. σε μερικες μερες σε βλεπω να θες καινουρια!
Μερικες μερες? Χθες ανακοινωθηκε η Titan, παει εγινε παρελθον η καρτα του
Πλακα κανω, για οποιον δεν καταλαβαινει by the way...
Μεγιες η καρτουλα @tommybertsen.
1
8 hours ago, Lazy Dog said:
Δυναμη το ansel!!
1
Εδω βλεπουμε τι boost παιρνουν οι καρτουλες τις AMD.
Και ποσο ΛΙΓΟ boost παιρνουν οι nvidia καρτες.
Δεν χρειαζεται να εχουμε κανενα πτυχιο για να το δουμε αυτο.
ΑΛΛΑ ΟΧΙ, ΕΙΝΑΙ ΨΕΜΑΤΑ, φερτε τα φτυαριααααα!
ερχεται η 1060 η οποια ειναι καλυτερη και απο 1090 Τi και θα την αγορασουν επειδη ειναι nvidia.
η 480 ειναι χωμα ουτε μια 970 δεν φτανει...
Τι, οχι?
I'm out!
4
12 minutes ago, tommybertsen said:
@LocoDiceGR εσυ εισαι ο valantisMP ? Παλι δικο σου το παιχνιδακι
lol, τι γινεται.
με ειπες τεντιμποη για αυτο
Ευχαριστωω!!
1
Ναι καλυτερα να μην το περασει καν αυτο...
Να κατεβασει το PlaysTV το κανονικο η με obs studio.
Vulkan / DX12 ευνοουν την AMD και φαινεται στα νουμερα...
Και ακομα ειναι στο πρωτο σταδιο, αργοτερα ''λογικα'' παντα θα γινει καλυτερο optimize.
Eισαι ωραιος!!! Μεγιες η καρτουλα!!
Θα ρωταγα για θερμοκρασιες και θορυβο αλλα με καλυψες!
Καλο mining & gaming
Αν δεν βαριεσαι δοκιμασε να δεις και τι κανει στο recording (playsTV - OBS Studio)
2
Απο διπλανο φορουμ:
Devil 480 - 13 july
XFX DD - 11-15 july (tommorow look for reviews)
Sapphire Nitro+ - 12 july
3
Radeon Software Crimson Edition 16.7.2 Highlights
- The "compatibility mode" UI toggle was designed to reduce total power with minimal performance impact on AMD Radeon™ RX480 reference boards and has been made available to users in the Global Settings menu of Radeon Settings (first introduced in the previous Radeon Software Crimson Edition 16.7.1 driver). This toggle is in "off" by default.
Fixed Issues
- In the previous Radeon Software Crimson Edition 16.7.1 driver the "Restore Factory Defaults" option under Preferences of Radeon Settings Software would not set the "Compatibility Mode" UI toggle to its default "OFF" value. This is fixed in the Radeon Software Crimson Edition 16.7.2 driver. The "Restore Factory Defaults" options resets all Radeon Settings to their factory default values.
Known Issues
- A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
- Radeon™ Pro Duo may experience a black screen in Total War™: Warhammer with the games API set to DirectX®12 and V-Sync enabled.
- DiRT™ Rally may experience flickering terrain in some races when the advanced blending option is enabled in the games settings page.
- Some Overdrive settings may not appear in Radeon Settings for Radeon™ Fury X when in AMD Crossfire mode.
- Dota™2 may crash when using the Vulkan™ API and the user changes resolutions or quality settings.
- Battlefield™ 4 may experience crashes when using Mantle. As a work around users are suggested to switch to DirectX®11.
- Need for Speed™ may experience flickering on some light sources in AMD Crossfire mode.
- Frame Rate Target Control gaming profiles may fail to enable for some games.
- Radeon Wattman may retain settings of an overclock after it has failed. If you have failed an overclock with a system hang or reboot make sure to use the "Reset" option in the Radeon WattMan settings page when the system has rebooted.
- Low frame rate or stutter may be experienced Wolfenstein®: The Old Blood™ on Radeon™ RX 480.
- Assassin's Creed® Syndicate may experience a game crash or hang when in game settings are set to high or greater.
- Disabling AMD Crossfire mode on Radeon™ RX 480 may disable the device in Windows® Device Manager. A workaround is to reboot the system to re-enable the device.
Τον Απρίλιο η αποκάλυψη, το καλοκαίρι η κυκλοφορία, για τις Pascal της Νvidia
In Κάρτες Γραφικών
· Έγινε επεξεργασία από LocoDiceGR
http://www.nvidia.com/page/legacy.html
Η σειρα 900 και αυτη πλεον ''legacy'' , οτι και αν σημαινει αυτο...
