Posts posted by LocoDiceGR
Οσοι εχετε προβλημα σε MPC-HC+MadVR καντε ενα update το MadVR,
Επισης υπαρχει memory leak στο dota (vulkan),
Αυτα για τωρα.
AMD Radeon Software Crimson 16.5.3
DRIVER BUILD
16.20.1013
SUPPORTED SYSTEMS
Windows 10 32-bit/64-bit
Windows 8.1 32-bit/64-bit
Windows 7 32-bit/64-bit
HIGHLIGHTS
Support for:
Total War: Warhammer™
Overwatch™
Dota™2 (with Vulkan™ API)
New AMD Crossfire profile available for:
Overwatch™
RESOLVED ISSUES
Fallout 4™ may experience minor stuttering in AMD Crossfire™ technology mode
Radeon Settings may be removed from the system if the Radeon Software installer is launched while Radeon Settings is open.
Radeon Settings "Additional Settings" option may intermittently fail to launch.
Users in Quad AMD Crossfire technology configurations may be unable to re-enable AMD Crossfire mode when using the global AMD Crossfire option in the "Gaming" tab and toggling it from on to off.
Some game textures in The Division™ exhibit flickering in AMD Crossfire™ mode.
Intermittent stability issues with Intel Skull Canyon NUC (NUC6i7KYK) using AMD XConnect™ Technology are no longer observed.
Safe unplugging for AMD XConnect™ Technology no longer results in a random BSOD.
KNOWN ISSUES
A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
Total War: Warhammer™ may experience stuttering in AMD Crossfire™ technology mode if the AMD Gaming Evolved App or Plays.Tv is running in the background. A workaround is to disable the AMD Gaming Evolved and Plays.Tv applications.
The Division™ may hang when using Quad AMD Crossfire™ technology. As a workaround users are recommended to disable AMD Crossfire™ technology mode.
Heroes of the Storm™ may experience flickering in AMD Crossfire™ technology mode.
The AMD Crossfire™ technology mode options in Radeon Settings may not take effect on Origin or Uplay applications.
Forza Motorsport 6: Apex™ may exhibit brightness flickering when using AMD FreeSync™ technology.
Frame Rate Target Control gaming profiles may fail to enable for some games.
Catalyst Install Manager unable to detect the display driver while uninstallation.-
1
http://videocardz.com/60253/amd-radeon-r9-480-3dmark11-benchmarks
Νομιζω πως ειναι καλα τα νεα γειτονα @yanni.
1
Ερχεται ο MAINSTREAM οδοστρωτηρας, ο C.Ronaldo των GPU,
Ελπιζω να το πιασατε το αστειο.
1
Πουληστε 980ti δεν κανει ειναι για τα σκουπιδια πλεον
1 hour ago, Shaman said:
Μολις τωρα το ειδα, σε ευχαριστω παρα πολυ!!!
6 minutes ago, ARMAGEDDON said:
μες στην βδομάδα αν νε πια μέρα γιατί δεν βοηθάει και το reddit ?
26 - 29 May. Φημες.
5 minutes ago, ARMAGEDDON said:
σιγά το leak
αφού 31 Μαΐου - 1 Ιουνίου έτσι και αλλιώς θα κάνει ανακοινώσεις η amd στην computex 2016
δεν ειναι για 31-1 το leak, ειναι για πιο νωρις...macau event.
1
3 minutes ago, yanni said:
Το ειδα χτες-προχτες, ουτε να απαντησει δεν ξερει, κολλησε.
19 minutes ago, giorgos2187 said:
@LocoDiceGR Να βρουμε και εναν πινακα αντιστοιχο οταν θα κυκλοφορησουν οι polaris. To οτι η AMD ουσιαστικα εχει να βγαλει drivers μονο για μια αρχιτεκτονικη γινεται γαργαρα φυσικα και ετσι αυθαιρετα σημαινει οτι η AMD ειναι τιμια και η nvidia καταρακωνει τα παλια μοντελα επιτηδες. Ισως και να ισχυει, δε λεω. Αλλα να δουμε και το ποσο θα καταφερει η AMD να υποστηριξει το ιδιο παλια και νεα αρχιτεκτονικη και να το ξανασυζητησουμε.
To Chart ειναι απο NeoGaf btw: http://www.neogaf.com/forum/showthread.php?t=1220928
Και οταν βγουν οι polaris σιγα σιγα θα βελτιωνονται με τον καιρο...οπως γινεται ακομα με την 7970. (διαβαζω αναφορες στο guru για βελτιωσεις ακομα και τωρα).
Αλλα που κολλανε με την φωτογραφια?
29 minutes ago, Trooper said:
Ήμουν παλαιότερα fan της amd λόγω καλών τιμών και γενικά προιόντων που άξιζαν τα λεφτά τους. Τελευταίο καλό προιόν που έιχα πάρει έχοντας περάσει απο πολλές σειρές AMD ήταν η 5970 με τα 2GB τότε. Μέχρι και 290Χ είχα πάρει που έιχε τότε 600! ευρώ....
Απο κεί και πέρα όμως ούτε gsync είχανε οι amd, ούτε το τοπ performance. Αρα όταν μιλάμε για το καλύτερο θα πας σε nvidia. Ας μη μιλήσω για τους drivers της amd.
Δεν υπαρχει fanboyσμος, κοιτάω τα πράγματα όπως έχουν. Είναι ακριβή η 1080 ? Σίγουρα. Έχει καπέλο? ναι.. Αν μπορώ και έχω τα λεφτα θα την παρω αλλιώς θα μείνω με την παλαιότερη μέχρι να κρίνω οτι αξίζει η αλλαγή.
Οι drivers της amd τωρα, ειναι μια χαρα..εχουν bugs εννοειται αλλα βρισκονται σε πολυ καλη κατασταση με συνεχομενα updates.
1 minute ago, Spirosssss said:Ακόμα μιλάμε για VS σε drivers;;;
Καθολου αστειο νομιζω
2
Polaris στα 250 ευρουλακια, και ασε τους αλλους να κοιτανε ποιος την εχει μεγαλυτερη.
Και με αντοχη στον χρονο, οχι θαψιμο οπως η nvidia.
1 minute ago, tommybertsen said:
Ποιος περιμενει ομως ειναι το θεμα. Ετσι και αλλιως θα περιμενω να σταθεροποιηθουν οι τιμες, ισως να χει βγει και αυτο εως τοτε να εχω επιλογες. Αλλα επειδη κοιταζω 3ετιας βαθος, δε ξερω τι θα προτιμησω. Συμφωνα με τους υπολογισμους μου , και τα συνηθισμενα μου τα τελευταια χρονια, θα αλλαξω pc κατα τα χριστουγεννα του 18.
Ας ερθουν με το καλο και βλεπουμε
Μεσα στον Ιουνιο.
Αμα κοιτας για 3 χρονια πας σε amd δαγκωτο.
Οχι νταξει θα φτασουν . Υπολογιζοντας 750€ το καθε ενα , στα 3Κ € εισαι. Ουσιαστικα το 500ρικο ειναι για τα σουβλακια που θα ψηνεις στο 4-way sli : P
Polaris με 300-350 και καθαρισες.
10 minutes ago, Nemesis89 said:
Μακάρι να είναι έτσι τα πράγματα γιατι ίσως ξεχνάμε ότι δεν μιλάμε για reference αλλά για founders editor που είναι +100$ πάνω από την ref
founders = reference.
Οποτε το +100 καπελο που βαζει η nvidia ειναι γιατι ετσι θελει.
36 minutes ago, GeoF1 said:
Κρατα γερα TITAN X!!!
1000 ευρω σκρουτζ, μια χαρα κραταει γερα.
Δεν αντεχουν τα ματια μου αλλο... ελεος.. @icy20 και τι εγινε; Αφου θα τα θεριζει ολα η πρασινη. Μονη της. Χωρις ανταγωνισμο. Με 750+ €... Ολα καλα λοιπον
ειρωνια?
http://wccftech.com/nvidia-gtx-1060-256-bit-bus-vr-price/ χμμμμμμμμμμμμμμμμμμμ
Εχει κατι περιεργα bugs ο crimson με chrome/MadVR (mpc-hc),
καντε ποστ στο official forum (απανταει το stuff της amd εκει 80%),
5-10 λεπτακια υπο8εση ειναι.
AMD Radeon Software support & discussion (No legacy support)
In Κάρτες Γραφικών
