LocoDiceGR
    1.593
Posts posted by LocoDiceGR
  1. Τωρα τελευταια ψαχνομαι λιγο για να αγορασω μια καμερα (μονο απο κωτσοβολο δυστυχως)...
    Η πρωτη μου θα ειναι, λοιπον:
    1) http://www.kotsovolos.gr/site/imaging/digital-cameras/dslr/178294-canon-eos-1300d-18-55dc-iii-value-up-kit
    2) http://www.kotsovolos.gr/site/imaging/digital-cameras/dslr/169817-nikon-d3400-afp-18-55mm-black
    3) http://www.kotsovolos.gr/site/imaging/digital-cameras/fotografikes-mirrorless/175533-olympus-e-m10-mark-ii-14-42mm-iir-black   <-- Ερωτας αλλα ξεφευγει λιγο, το θεμα ειναι αν αξιζει?
    Γνωμες?
  2. Radeon Software Crimson ReLive Edition 17.9.3
    Support For
    • Total War: WARHAMMER™ II
      • Radeon Chill profile added
      • Multi GPU support enabled
    • Forza™ Motorsport 7
    Fixed Issues
    • The drop-down option to enable Enhanced Sync may be missing in Radeon Settings on Radeon RX Vega Series Graphics Products.
    • ReLive may cause higher idle clocks on the secondary Radeon RX Vega Series Graphics Product in a multi-GPU configuration on certain AMD Ryzen based systems.
    • Negative scaling in F1™ 2017 may be observed on Radeon RX 580 Series Graphics products in multi-GPU system configurations.
    Known Issues
    • Unstable Radeon WattMan profiles may not be restored to default after a system hang. A workaround is to launch Radeon WattMan after reboot and restore settings to default.
    • Wattman may fail to apply user adjusted voltage values on certain configurations.
    • Radeon Settings may not populate game profiles after Radeon Software's initial install.
    • Overwatch™ may experience a random or intermittent hang on some system configurations.
    • GPU Scaling may fail to work on some DirectX®11 applications.
    • Secondary displays may show corruption or green screen when the display/system enters sleep or hibernate with content playing.
    • Bezel compensation in mixed mode Eyefinity cannot be applied.
    • When recording with Radeon ReLive on Radeon RX Vega Series graphics products GPU usage and clocks may remain in high states.
    • Like 3
  3. 25 minutes ago, sotiris said:
    Στο skroutz.gr:
    1080: 530
    7700κ: 330
    corsair 750: 90
    Χωρίς τίποτα άλλο αυτά είναι 1000 ευρώ.
    Οπότε τα 1600 για κουτιά μνήμες μητρική στην περίπτωση που έχει και οθόνη μέσα είναι οκ.
    Ας μην υπερβάλλουμε λοιπόν με το όλα τα παραπάνω 850€, εκτός αν έχεις κάποιο συγκεκριμένο κατάστημα στο μυαλό σου. Πες το και σε μας να ξέρουμε!
    Συνήθως δεν ασχολούμαι με χτισίματα αλλά με έβαλαν πρόσφατα να φτιάξω ένα σύστημα στα 700 ευρώ και η καλύτερη επιλογή που βρήκα ήταν στο MediaMarkt έτοιμο lenovo με 699 και i7-6700. Το να χτίσεις σύστημα δεν είναι τόσο φτηνό, με αντίστοιχα χρήματα σε Πλαίσιο έπαιρνες i3-7100 (πολύ πιο ισορροπημένο μεν, αλλά το άλλο έχει το potential με μια gpu κι έναν ssd να πηγαίνει σφαίρα).
    Επίσης επειδή έχω δουλέψει λίγο την V8 GTS (την είχα αγοράσει για μένα αλλά τελικά την έδωσα στον αδερφό μου) μου φαίνεται πολύ καλή σε απόδοση. Δεν την είχα πάρει 90, αλλά γύρω στα 50-60 σε crazy, και στα χρήματα αυτά δεν νομίζω ότι υπάρχει κάτι πολύ καλύτερο. Εξαιρετικά αθόρυβη και πολύ καλές θερμοκρασίες.
    Με 700 ευρω,  φτιαχνεις πολυ δυνατο συστημα κομματι-κομματι, και πολυ καλυτερο απο αυτα τα ''ετοιμα''.
  4. 1 hour ago, therock said:
    Το βαλα manual απο 2,5-3Gb και η αληθεια ειναι οτι δεν εχει χτυπησει in game αλλα σε ενα control alt del που κανα για να βγαλω taskmanager να δω αν τα νουμερα συμφωνουν με afterburner και εχασε focus βαρεσε παλι ενα out of memory error
    αλλα σου λεμε, αλλα κανεις. :p
  5. Download Link: http://support.amd.com/en-us/kb-art...mson-ReLive-Edition-17.9.2-Release-Notes.aspx
    Radeon Software Crimson ReLive Edition 17.9.2 Highlights
    Support For
    • Radeon RX Vega Series
      • Up to 2x Multi GPU support
    • Project CARS 2™
      • Multi GPU profile support added
    Fixed Issues
    • Hearts of Iron IV™ may experience a system hang when the campaign scenario is launched.
    • Radeon Software may display an erroneous "1603 Error" after installing Radeon Software. This error will not affect your Radeon Software installation.
    Known Issues
    • The drop-down option to enable Enhanced Sync may be missing in Radeon Settings on Radeon RX Vega Series Graphics Products. A clean install of Radeon Software can prevent this issue.
    • Radeon Settings may nor populate game profiles after Radeon Software's initial install.
    • Like 3
  6. 2 hours ago, therock said:
    Με 12GB Ram δε θεωρησα οτι θελω pagefile και επειδη ο ssd μου ειναι μονο 128GB και γεμιζει με λιγες εγκαταστασεις παιχνιδιων το απενεργοποιησα να μη τρωω ασκοπο χωρο.
    Οκ ασ κανω μια δοκιμη. Ποσο μεγεθος να το ορισω
    το βαζεις default/αυτοματο οπως σου ειπε και ο Eddie.
  7. 2 hours ago, devaggos said:
    Επειδή έχω χάσει λίγο τη μπάλα, τα 3rd party programs όπως Afterburner, Trixx κλπ. συνεχίζουν να μην δουλευουν με τα νέα Drivers?
    Γιατί έχω ξεμείνει στη 17.6.1 ..... αλλά φοβάμαι να κάνω update γιατί έχω undervolt profile στο trixx και με εχει βολεψει πιο πολυ από το wattman
    Με 17.9.1 το afterburner beta 16 δουλευει απο οσο ξερω. (ερχεται και καινουριο beta σε 2 βδομαδες)
    To trixx και τα υπολοιπα οχι γιατι δεν εχουν παρει update.
    Αμα δεν εχεις προβλημα μεινε οπως εισαι, μεχρι δεκεμβρη στο μεγαλο update.
