Posts posted by NoDsl
Εδώ στην Καλαμάτα ένας έχει πάρει Gallardo Spyder για να κυκλοφορεί στην πόλη..
Και κάποιος έχει πάρει και ένα nissan GT-R του κουτιου σε γραφίτη. Α μωρή καλαμάτα.
Califronia έχουμε καταντήσει με τόσες cayenne, φεράρι και slk200/M3...
Φίλτατε n00bάκο Eloxim... έχουμε και λέμε.
Πρώτον, καιρός γαρ εγγυής.
Έπειτα:
παιδες τι ειναι τα :Pixel Format
επιλογες
Full RGB
Limited RGB
LCD Overdrive
GPU Scaling και ITC Processing.
Ευχαριστω προκαταβολικα.
1) http://en.wikipedia.org/wiki/RGB#RGB_arrangements_for_8-bit_indexed_color
2) Overdrive – Also referred to as Response Time Compensation, this technology is based on applying an over-voltage to the liquid crystals to motivate them into their orientation faster. This process forces them to a full white (inactive) to black (active) transition first. The crystals can then drop back down to the required grey level. This is helpful as the rise time of a crystal was always the slowest part (response time = Tr + Tf).
3) GPU scaling
if source =800*600
then
{monitor automatically fills screen to its native resolution(>800*600) by stretching it
If source = 800*600
then
{gpu upscales it to the monitors native resolution (by stretching it?)};
end both ifs :triniti:
ITC Processing
Enabling ITC Processing for DTVsITC processing is a feature that enables display processors to use the appropriate pixel data processing algorithms based on specific content type to ensure video quality.
With ITC processing, the graphics driver enables the display to use its own video quality processing algorithms for movies played in full-screen mode on HDMI™ displays.
Note: This feature is available only for DTVs connected with HDMI cables and may not be available for all systems.
From the Graphics Settings tree, expand DTV.
Click Attributes.
Select or clear Enable ITC Processing as appropriate.
Select—Enables ITC processing for HDMI displays that are capable of the feature. When movies are played in full-screen mode, the display’s processors can be used to ensure video quality.
Clear—Disables ITC processing. Video quality is ensured by the graphics driver for all types of contents displayed.
- 2
Καλοί φαίνονται. εχτές που τους έτρεξα σε vista x64 με Q6600@3.6 και 4850@ 750-1150
είχαν σε crysis 1366*768 / dx10 / x86mode / very high / 33 average(έτρεξα το GPU_test batάκι απο το folder).
1680*1050 / dx10 / x86mode / very high
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 93.79s, Average FPS: 21.32
Min FPS: 15.45 at frame 138, Max FPS: 26.36 at frame 859
Average Tri/Sec: -8622187, Tri/Frame: -404351
Recorded/Played Tris ratio: -2.27
!TimeDemo Run 1 Finished.
Play Time: 89.89s, Average FPS: 22.25
Min FPS: 15.45 at frame 138, Max FPS: 26.58 at frame 862
Average Tri/Sec: -8697573, Tri/Frame: -390894
Recorded/Played Tris ratio: -2.35
!TimeDemo Run 2 Finished.
Play Time: 89.83s, Average FPS: 22.26
Average Tri/Sec: -8682055, Tri/Frame: -389950
!TimeDemo Run 3 Finished.
Play Time: 89.78s, Average FPS: 22.28
Min FPS: 15.45 at frame 138, Max FPS: 27.99 at frame 868
Average Tri/Sec: -8727109, Tri/Frame: -391754
Recorded/Played Tris ratio: -2.34
TimeDemo Play Ended, (4 Runs Performed)
Συγνώμη που μου τη σπάνε τα "έμεσα" promos.
SAPPHIRE ATI X1800XT 512MB PCI-E Κύριοι! Πάρτε Κύριοι!
Καποιες διαπιστώσεις σε vista x64.. (nvidia drivers beta (προς gamma..) 180.84)
Eίτε έχεις τον 920 στα 3ghz είτε στα 4ghz η διαφορά είναι απειροελάχιστη (σχεδόν μηδενική)
cpu usage έχω 35-38%..
Σε Ε2180 και ati 2600xt σε vista x86 sp1 απο 2.4 που είχα το cpu σε 3(μνήμες σταθερά 800 με 5άρια-αλλαζε διαιρέτης-), σε 800*600 απο 19fps πήγε στα 34...Οπότε σε παρόμοια μηχανήματα, θέλει και cpu.
PhysX GPU Acceleration on Radeon HD 3850
http://www.ngohq.com/news/14219-physx-gpu-acceleration-radeon-hd-3850-a.html
Όχι είναι εντελώς διαφορετική η πλακέτα αν και μοντέλο 2003 το δικό μου. Νάσαι καλά πάντως.
Αρχική απάντηση από naz [Χθες, στις 23:59]
nodsl για δωσε στοιχεια δισκου.
40BB
2060-001092-006 REV A
80JB
2060-001189-003 REV A
49 δολλάρια; Δε πάω να πάρω ένα 500άρι;
Εχω μια πλακέτα απο WD40BB και ψάχνω μια πλακέτα απο WD 80JB
Αρχική απάντηση από NoDsl [Χθες, στις 23:28]
E2180
Q745A090
max fsb σε p5k-e με 1.7 vpll
Αρχικα.
ATI Catalyst 8.1 Display Driver for Windows XP Professional/Home Edition
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
πωωωωωωωω μού'χει σπάσει τα νεύρα το stuttering που κάνει. Τι textures low τι high το ίδιο και το αυτό. 1,5 giga μνήμη θέλει η μλκια... έλεος...
Ωραίο eye candy όμως το game και σχετικά σταθερή απόδοση. Δεν βλέπεις ας πούμε σκηνές με 1000 fps και σκηνές με 2. Πάιζει απο 60-19 σε τρελές εκρήξεις σε 1680(vsync on).
Αρχική απάντηση από Vasot [Σήμερα, στις 13:45]
Aμαν ρε σεις ξεκολληστε μερικοι με τα drivers και τα Benchmarks
Παιξτε και λιγακι το παιχνιδι και μιληστε σχετικα με τα χαρακτηριστικα του παιχνιδιου
Γιατι αγοραζετε παιχνιδια...για επιδειξη ισχυος του συστηματος σας ??
Γιατί το crysis θα το πάρεις για το gameplay του;
Αν θές gameplay παίζεις warsow, MOH:Airborne και συναφή παιχνίδια. Αυτό το φουτουριστικό fps είναι σαν το doom3. Eye candy
Ρίξε τα πάντα στο game ώστε να κάνεις γραφικά CS 1.6 να δούμε κατα πόσo θα συνεχίσει να είναι αρεστό.
Καταλήγω στο οτι κάθε παιχνίδι βγαίνει για το δικό του λόγο και όχι απαραίτητα για fun.
και ένα videάκι για τους παραπονιάρηδες.
http://rapidshare.com/files/67505993/crysis_gpu_hd.mp4.html
λολ μολισ παρατήρησα οτι στο τέλος έχει artifacts αλλά είναι τραβηγμένο με ΑΤi γι'αυτό.
Βαριέμαι να το ξανανεβάσω.
Αρχική απάντηση από Athens2004 [Σήμερα, στις 11:45]
Αν σας ειναι ευκολο παιδες στις gts να ανεφερετε το μεγεθος της μνημης καθως η 640 εχει αρκετη διαφορα με την 320 και θα δημιουργηθουν λαθος εντυπώσεις . ¨)
Καλημέρα.
Μήπως να αναφέρουμε και τα settings στους drivers γιατί μεταξύ χρηστών βλέπω μεγάλες διαφορές. ’λλο να κάνεις "bench" με drivers στο performance και άλλο όλα default.
Μιας και συζητάμε για εξαρτήματα dremel πολύ καλή ιδέα θα ηταν, κατα τη γνώμη μου, κάποιος γνώστης του αθλήματος να έκανε ένα guide, ας πούμε, με τα εξαρτήματα dremel και τη χρήση τους. Υλικά, προτεινόμενοι μέθοδοι κλπ.
Θα ηταν αρκετή δουλειά αλλά θα βοηθούσε υπερβολικά πολύ.
Π.χ θέλω να φτιάξω κάτι και δεν ξέρω τι εξάρτημα χρειάζομαι για το τάδε υλικό και την τάδε δουλειά.
Official Cars, Motors, βελτίωση, τρακαρίσματα και οδήγηση Thread (MotorLab)
In Off topic
33, 75? what?
