- 27.161 απαντήσεις
- 16
- funny pictures
- memes
(και 5 επιπλέον)
27" ή 32" οθόνη σε 2560x1440 ανάλυση, [ αγορά ]
idonthave απάντησε στο θέμα του idonthave topic στην ενότητα Οθόνες & Projectors
Pulse Width Modulation (PWM) Samsung C32HG70 Review - TFT Central Backlight Dimming and Flicker We tested the screen to establish the methods used to control backlight dimming. Our in depth article talks in more details about a previously very common method used for this which is called Pulse Width Modulation (PWM). This in itself gives cause for concern to some users who have experienced eye strain, headaches and other symptoms as a result of the flickering backlight caused by this technology. We use a photosensor + oscilloscope system to measure backlight dimming control with a high level of accuracy and ease. These tests allow us to establish 1) Whether PWM is being used to control the backlight 2) The frequency and other characteristics at which this operates, if it is used 3) Whether a flicker may be introduced or potentially noticeable at certain settings If PWM is used for backlight dimming, the higher the frequency, the less likely you are to see artefacts and flicker. The duty cycle (the time for which the backlight is on) is also important and the shorter the duty cycle, the more potential there is that you may see flicker. The other factor which can influence flicker is the amplitude of the PWM, measuring the difference in brightness output between the 'on' and 'off' states. Please remember that not every user would notice a flicker from a backlight using PWM, but it is something to be wary of. It is also a hard thing to quantify as it is very subjective when talking about whether a user may or may not experience the side effects. At 100% brightness there is a basically constant voltage applied to the backlight as you might expect. Oddly, despite the screen being advertised as flicker-free we were disappointed to see typical PWM behaviour as you adjusted the brightness setting below 100%. By the time you reach down to 70% brightness there is a full off/on modulation of the backlight. This operated at a fairly low 340Hz frequency (regardless of your active refresh rate). The duty cycle (on time) is reduced as you lower the brightness setting down until you get to 20% brightness setting, and then at the lower end of the range the modulation is also then reduced. That is, the 'on' voltage is reduced to bring about a further reduction in perceived luminance. This use of PWM could potentially cause issues with flicker and eye strain to those sensitive to it. Pulse Width Modulation Used Yes Cycling Frequency 340Hz Possible Flicker at 100% Brightness No 50% Brightness Yes 0% Brightness Yes -
https://www.thelab.gr/forums/topic/175995-27-ή-32-οθόνη-σε-2560x1440-ανάλυση-αγορά/?do=findComment&comment=2635114 -
"RTX 20x0 & 16x0" Turing architecture
idonthave απάντησε στο θέμα του idonthave topic στην ενότητα Κάρτες Γραφικών
next rumor από το '16 άρχισαν οι φήμες Φήμες ξε-φήμες για το 17 μέσα έπεσαν, έγινε του refresh το κάγκελο, ούτε τώρα θα κάτσουν χωρίς να βγάλουν κάτι μέχρι να (όταν)ανακοινωθούν (για να λέμε) 2080 → GDDR6 12/16GB ? 2070(1080Ti) →GDDR5X 11GB(12GB) -
Πείτε Ό,τι Θέλετε v5.0 -
Rumor: Nvidia Ampere might launch as GeForce GTX 2070 and 2080 on April 12th -
Το λοιπόν, έχουμε και λέμε έχω αποφασίσει και δεν έχω αποφασίσει Αυτή την στιγμή στο ένα "μωβ"+50€ περίπου παίζει η AOC AG322QXC και η Samsung 27CHG70 - H AOC είναι το δέλεαρ όσον αφορά τα "χαρακτηριστικά" και μέγεθος (32αρα) για την τιμή της. - Η Samsung με όσα έχουν γραφεί παραπάνω είναι πιο γρήγορη σαν οθόνη με καλύτερα χρώματα αλλά 27άρα όπου στα ίδια χρήματα μπορεί να αποκτηθεί η AOC. Έχει πέσει παραγγελία για την samsung και με "περιμένει" να την παραλάβω, τι λέτε προχωράω με την samy ή πάω στην AOC ? Αυτήν τη στιγμή είμαι μ'ένα 1080p LG 27MP68VQ-P πόσο "χάλια" μπορεί να είναι η AOC? μια χαρά παίζω και μ'αυτήν Πριν την lg ήμουν με VA μονιτορ BenQ EW2440L Για βοηθήστε "λίγο" μέσα στην βδομάδα λογικά θα έχω πάρει το monitor, ποιο, δεν ξέρω ακόμα μιας και τα 2 παίζουν ~550€. Υπάρχει κι ένα καινούριο acer που υπάρχει πλέον διαθέσιμο στο εξωτερικό (το έχω αναφέρει σε προηγούμενο post) 750€ μέσα κ τα μεταφορικά, Acer Predator Z321QUbmiphzx με gsync (δεν με απασχολεί και τόσο) δεν έχω βρει κάποιο review ακόμα. Αν αξίζει τότε θα πάω στην acer! -
- 27.161 απαντήσεις
- 15
- funny pictures
- memes
(και 5 επιπλέον)
- 27.161 απαντήσεις
- 16
- funny pictures
- memes
(και 5 επιπλέον)
- 27.161 απαντήσεις
- 13
- funny pictures
- memes
(και 5 επιπλέον)
- 25.485 απαντήσεις
- 3
- 27.161 απαντήσεις
- 7
- funny pictures
- memes
(και 5 επιπλέον)
- 25.485 απαντήσεις
- 2
12 χρόνια πίσω έβαζα κάτι κανάλια σε ένα γραφείο για να κρύψουμε καλωδιώσεις. Είχα κι ένα πολύμπριζο στο οποίο ήθελα να κάνω προέκταση στο καλώδιο. Με τα πολλά ανέβασμα κατέβασμα του γενικού, είχα ξεχάσει τον ρελέ ανοιχτό και από την κούραση είχα το πολύπριζο στην πρίζα. Τραβάω ένα κόψιμο στο καλώδιο, μια που μαύρισε το κοφτάκι, έκανε και κάτι "φωτορυθμικά" ... και μια που "γαντζώθηκα στο ταβάνι" . Αποχωρώ, καληνύχτες
- 25.485 απαντήσεις
- 2
- 27.161 απαντήσεις
- 10
- funny pictures
- memes
(και 5 επιπλέον)
άποψη για τις παρακάτω μνήμες έχουμε? αν είναι samsung b-die? F4-3400C16D-32GTZ CL16-16-16-36 https://gskill.com/en/product/f4-3400c16d-32gtz για τα αντίστοιχα παρακάτω kit (όχι 32gb) βρήκα ότι τα 2x8 είναι b-die - http://www.overclockers.com/g-skill-tridentz-16gb-ddr4-3400-cl16-memory-review/ G.Skill Trident Z 3400 MHz CL16 F4-3400C16D-32GTZ 8Gb Samsung B-Die Dual Double Jedec Info το 2x4 είναι E-die G.Skill Trident Z 3400 MHz CL16 F4-3400C16D-16GTZ 4Gb Samsung E-Die Dual Double Jedec Info έχει κάποιος τις παραπάνω 32gb(2x16)? αξίζουν? ή να πάω για 20€ παραπάνω στις 3200mhz cl14 που είναι σίγουρα b-die ? @TASOS
- 27.161 απαντήσεις
- 10
- funny pictures
- memes
(και 5 επιπλέον)
- 25.485 απαντήσεις
Περιεργα σκηνικα, πειτε γνωμη
idonthave απάντησε στο θέμα του icy20 topic στην ενότητα Κάρτες Γραφικών
Πότε υπολογίζουμε Ελλάδα?!!! -
- 27.161 απαντήσεις
- 7
- funny pictures
- memes
(και 5 επιπλέον)
- 25.485 απαντήσεις
- 3
[ AMD RyZen+ 12nm & X470 motherboards ] τον Απρίλιο
idonthave απάντησε στο θέμα του idonthave topic στην ενότητα AMD Platform
AMD Raven Ridge: First benchmarks for Ryzen 3 2200G and Ryzen 5 2400G -
Αλλαγή modem/router - Ευρυζωνική γραμμή
idonthave απάντησε στο θέμα του idonthave topic στην ενότητα Internet & Τηλεφωνία
αγοράζοντας το tplink δεν χρειάζομαι τίποτα, συνδέεται όπως το τωρινό του οτε. εναλλακτικά (για εγκυκλοπεδικούς λόγους να γνωρίζω): η λύση που γράφεις με το απλό ρούτερ(+θύρα rj11) και το ταφ (για να μπορώ να χρησιμοποιήσω και τις τηλ. συσκευές και το wifi) γίνεται με την σειρά που σου περιγράφω? πρίζα τηλ. → speedport envy 2i → ρούτερ/ταφ -
αν πάρεις κράτησε/ζήτησε μια msi ti επιπλέον, άνοιγμα, έλεγχο και παίρνει το μαρούλι στο τέλος !!
