Αρχική απάντηση από ΑΝ7 OverClocker [Σήμερα, στις 16:01]
Πώς γίνεται αυτό??????
Settings-->Misc-->Show Card Temperature in Systray
Δεν ξέρω πόσες κάρτες το υποστηρίζουν όμως... πιθανόν σε όσες παίζει το overdrive.
  • Replies 748
OPN64 v0.1.95-Exp
  • OPN64 now supports the following new processors:
  1. Athlon 64 2800+(512KB/1024KB), 3000+(512KB/1024KB), 3200+, 3400+, 3700+ series
  2. Athlon 64 FX 51, 53, 55 series
  3. Opteron 1/2/4/8-Way versions of x40, x42, x44, x46, x48, x50 series
  4. Athlon XP (Thorton) 2000+
  • Major code changes
  1. Code has been reduced by many hundreds of lines of code
  2. Code is now much more stable
OPN-462 v0.8.35-Exp
  • Added experimental Athlon XP-M 2400+ & 2500+ support - With the current popularity of these processors, I have decided to add experimental support for the 2400+ & 2500+ version of this chip.
  • Major code optimisations.
  • Added HTML Output feature(s): - Output now displays the OPN code
  • The favourites section has now become a partner scheme
  • Added partner(s): - News > www.xtremenews.net
  • New 64 bit Windows I/O drivers - now works with Win 2003 Server 64 bit
  • Added AMD64 processor ID check
  • Corrected compatibility issues with MBM5
  • Improved startup directory handling
download
  • Final DirectX 9.0c support for official retail runtime
  • Fixed slow DX9 video capture with anti-aliased games and nvidia 61.76/61.77 drivers
  • Fixed bug outputting lots of 0 and 1 entries at start of FRAPSSEC log
  • Fixed crash when starting video capture in some OpenGL applications
download
  • Added "Artifact Tester" with ability to find maximum values for GPU and MEM. Including an option to heat up main CPU, to simulate game environment.
    Be notified, that procedure to find real maximum clocks is not as simple as you can think. It is a very huge job and I never will create such options in ATI Tray Tools. The given procedure is intended to find clock, when no artifact detected during given time, while rendering a simple scene. (The space ship have about 26 000 triangles.). So it is up to you, how to use this Tester. 8-)
  • Added new Hardware Window. Now you can control PCI Lantency timer for your video card. Automaticaly apply value on start up and restore it after suspend/hibernate modes.
  • Added context sensitive help file (English version)
  • Improved installation. Now you can select Program Menu folder to shortcuts. When installing new version over previous one, new installation will automatically take path for Program Menu from old installation, and use it.
download
  • Added image writer boot disk. Thanks to Adrian Stanciu for contributing this piece of original work.
  • Added QNX Demo Browser V4.00 (network and modem version). Thanks to Tristan Larouanne for suggesting this, and supplying the disk images.
  • Tried switching to CD Shell 2.0.17b, but reverted because bcdw V1.50z does not work with the new version of CD Shell.
  • Switched to using bcdw for booting up Drive Fitness Test. This seems to improve compatibility with older systems.
  • Updated TestDisk to V5.3. Thanks to Christophe Grenier for the update.
  • Added PCISniffer V1.2. Thanks to Reik Keutterling for the suggestion.
  • Added Disk Editor V3.0. Thanks to Domenis Riccardo for the suggestion.
  • Updated Arachne to V1.75. Thanks to Jambin for the update.
  • Updated Intel Processor Frequency ID Utility yo V7.1.20040716. Thanks to SebastienG for the update.
  • Updated Partition Saving to V2.90. Thanks for SebastienG for the update.
  • Added Lucifer V1.0. Thanks to Raphael Högger for the update.
  • Updated Drive Fitness Test to V3.73. Thanks to Rainer Stroebel for the update.
  • Updated Parallel Port Detection and Test Utilities to V1.45. Thanks to Jambin for the update.
  • Updated UniFlash to V1.37. Thanks to Jambin for the update.
  • Updated Astra to V4.21. Thanks to Jambin for the update.
  • Updated SeaTools Desktop to V3.00.06en. Thanks to SebastienG for the update.
  • Updated MemTest86+ to V1.20. Thanks to SebastienG for the update.
  • Updated g4u to V1.17.
  • Updated DLG Diagnostic to 5.04c. Thanks to Jeremy Stanton for the update.
  • Updated F-Prot to V3.15. Thanks to Jean-Marc for the update.
  • Updated PCI to V0.49B. Thanks to Jambin for the update.
  • Updated F-Prot virus definitions to 28 Jul 2004.
  • Updated McAfee virus definitions to 28 Jul 2004.
  • Moved PCI to DOSAPPS.
  • Moved CMOS password recovery to DOSAPPS.
δε βάζω download γιατί έχει πολλά mirror πολύ ownage το CDάκι :worship:
Μπορει καποιος να βαλει στο pathfinder το speedfan να το κατεβασω...επειδη απο το αλμιψο συνεχεια δεν λειτουργει...οχι το λινκ...το προγραμμα βγαζει σφαλματα...ευχαριστω...
OmniExtremeEdit FX v1.2
Το πρώτο BIOS editor για
  • 6800/GT/U
  • 5900/XT/U
  • 5700/U
υποστηρίζει αλλαγη timings
download
Process Timer V1.0
Από τον Codered για ακριβή υπολογισμό του χρόνου μια επεξεργασίας (για το SuperPI ;) )
Σιγκλονιστηκα πραγματικα...........Παρτε παιδια την 6800.........
Οι IXBT λενε οτι δουλευει.
Περιμενουμε ποτε θα βγει/
Το βρηκα τυχαια.......δεν εχει βγει ακομα. Και δεν υπαρχει συζητηση.
Απλα το μονο που ξερω οτι στο τελευταιο review τους χρησιμοποιησαν 6800 12pip => 16 και δουλεψε.
New features in this version include:
  • New Memory timings adjusting feature for all supported chipsets (both in RMMA executable and a stand-alone application)
  • Defaults to VirtualLock memory allocation scheme
  • New supported chipsets: Intel 440LX/EX, 440BX/ZX, 440GX, i830, i852GM/GMV, i855GM/GME, i855PM, i915/i925, nVidia nForce2 (experimental)
  • New CPU Database Entries
  • Minor bugfix in Quick Tests feature
download
Αλλαγη timings απο τα Windows, ε!!!!!
Corrections:
  • Advanced disk test now checks the total disk test file size across all test threads before starting any test.
  • Unformatted key drive handling.
  • 2D graphics test now produces linear results based on test duration.
  • Graphs now display 10 different colors for each test thread (instead of 5).
  • Windows 98/ME corrections to:
  1. Unable to complete Advanced Disk Test.
  2. File->Export results for Web option does not allow choosing of a cascading style sheet.
  3. Baseline Information option doesn't show Disk information.
  4. Tooltips do not work on top menu bar
  5. When running 2D -> "Fonts and Text" Test under Win98SE, an error box will pop up and the user cannot click on the "Yes" or "No button.
  • Installation now warns of existing directory.
  • Advanced 3D test error messages are no longer 'Hidden'.
  • A specific error message has been added when a user tries to install an already installed baseline.
  • It is now indicated in the Baseline information window whether onboard device and system slot information is unavailable.
  • When a PC comes out of Sleep mode, under all certain circumstances the status bar is now correctly redrawn.
  • Average WAW in the advanced disk test has been corrected.
  • Viewing a graph when there are valid results for 10 or more threads is now correctly handled.
  • Menu item ellipses (...) have been updated.
  • The setting box in the advanced 3D options no longer becomes incorrectly ungrayed.
  • When the user stops the Advanced disk test, the progress bar is immediately set back to the start, rather than when the test is next started.
  • The cascading style sheet is now correctly applied when exporting a "file to the web" to all directories, not just the installation directory.
  • The "Office" cascading style sheet has been removed, as it was the same as the "Default" cascading style sheet.
  • When the advanced disk test is stopped by the user, the status now indicates stopped rather than completed.
  • The PerformanceTest folder is now removed in all cases after uninstalling the program.
  • The existing testing utilizing Hyperthreading enabled computers improved.
  • Rounding precision improved in the display of free disk space on the with baseline information window.
download
Καλο!!!!
