gbak
    5.530
Everything posted by gbak
  1. gbak
    Supercars & Dreamcars Thread
    φαντασου να βγαλεις βαρης κορωπιου αυτο το ζωο με 10 ποντους χιονι τι εχει να γινει..θα κλεισει η κυκλοφορια.. @ΑΝ7 OverClocker μαμει το mclaren και γω το παω με χιλια
  2. gbak
    unknown θα σε αρρωστησω σημερα δεν την γλυτωνεις
  3. gbak
    τι να επηρεασει ρε σιγα..σιγα μην μασησει το μ3 απο αλλαγη οφφσετ με τοσα αλογα και τετοιο στησιμο..ισα ισα θα χει ακομα καλυτερα μπασιματα αλλη μια απο Schnitzer
  4. gbak
    κοιταχτε εδω μια μπεμπa απο HAMANN
  5. gbak
    βασικα ειναι η εκδοση τετοια ρε συ... κοιταξτε εδω λεπτομερεια στην ζαντα...
  6. gbak
    αντε αλλες δυο φωτο PPI Audi R8 Razor Debuts
  7. gbak
    ετσι! Since 1992, red LEDs have been used increasingly for high-level brake lights, as well for tail lights and regular brake lights. Audi became the first manufacturer to feature peripheral white LEDs as daytime running lights, first on the Audi A8 W12 in 2004 and then on the Audi S6, Audi R8 and Audi A5/S5 from 2006. Audi is now premiering the first and only headlight unit in the world to deploy LEDs for all of the front lighting functions. Apart from the daytime running lights, these functions comprise the turn signals and the dipped beam and main beam headlights. Various groups of LEDs, known as arrays, produce the correct light distribution and brightness. Each headlight unit has a total of 54 LED light sources. The outstanding benefits of LED technology include its low energy consumption (50 watts for the dipped beam headlights, 6 watts for the daytime running lights), a colour that is similar to daylight for enhanced contrast and more pleasant visual perception, the non-wearing design, lower voltage requirements, compact dimensions and the increased freedom of design. A special permit from the EU has paved the way for incorporating front-lighting LED technology into series production ahead of schedule. This is because the corresponding EU regulation is not expected to come into force before 2008. Audi is a founding member of the working party that was set up in 2003 to bring about speedy approval for advanced and powerful lighting technology. Innovations in the field of lighting technology are often based on the development of new light sources. Halogen bulbs were followed by xenon headlights, which were subsequently expanded to include cornering and static turning lights. Thanks to the rapid advances being made in LED technology, it will soon be possible to reproduce the same functions with these semiconductor elements too. Each light unit consists of a housing, a chip or chip array, a circuit board and a heat sink. Electric ventilators ensure effective heat dissipation and also defrost the headlight units. The LED headlight that will in future be available as an option for the Audi R8 is made up of the following components: LED dipped beam headlights as the primary function. Here, basic light distribution is taken care of by LED arrays, each consisting of four chips, which shine out of free-form reflectors. A further three two-chip LED arrays for light in the region of the light-dark boundary and for the headlight range are located behind the lens. Directly adjacent to this is the main beam headlight comprising one four-chip LED array inside each of the two reflector shells. The 24 white LEDs for the daytime running lights are distinctively positioned along the bottom edge of the headlight unit, giving it a three-dimensional and sophisticated appearance. The turn signal with its eight yellow high-brightness LEDs is placed on the top edge of the headlight unit pointing towards the single-frame grille, where it combines with the strip of LED daytime running lights to form a frame around the headlight. LED technology in Audi concept studies: As long ago as the start of 2003 that Audi first unveiled an operational, slat-shaped LED fog light in its Pikes Peak show car at the Detroit Motor Show. An initial concept for an all-LED headlight was presented in the Audi Nuvolari quattro at the Geneva Motor Show in that same year, and in September the Le Mans quattro turned up on the eve of the Frankfurt Motor Show with LED headlights. The dipped beam light distribution already met the statutory requirements at this point. A fully functional LED headlight with lenses made from aluminium tools was featured on the allroad quattro concept car back in 2005. The Shooting Brake concept car then showcased an LED headlight with a bionic design, whose form resembled a pine cone. This same basic idea has now been transferred to the new series-production solution for the R8. The Audi Q7 V12 TDI (Detroit 2007) has already provided a preview of the next generation. Audi Technology ABC LED: light-emitting diode. Semiconductor light source which emits cold light at low voltages of 3 to 4 volts. The revolutionary new LED arrays in the Audi headlight produce a luminous flux of 400 lumen at a current strength of 1 A. Such luminous efficiency is unprecedented for LEDs. Lumen: the unit of luminous flux. Describes the luminous power emitted by a light source. Source: Audi AG
  8. gbak
    δεν καταλαβες δεν ειναι πινελια ειναι το καινουργιο headlight led της audi...αλλα ακομα και στο καινουργιο A4 εμενα μου αρεσει...ειναι πολυ hitech
  9. gbak
    εγω το θεμα με τα καινουργια led φαναρια το βρισκω πολυ hitech και ωραιο...το χω δει και στο δρομο απο πισω μου και δειχνει απιστευτα ομορφο και εντυπωσιακο
  10. gbak
    πρωτη φορα ακουω καγκουραμαξο στα 104.000ευρω...για μενα μαμαει το αουντακι
  11. gbak
    οχι και καρναβαλι το R8 για να συγκεντρωθουμε πρωι-πρωι....τι στο καλο πιωμενοι ειστε ρε
  12. gbak
    επειδη ψαχνεσε για ανθρακονημα οριστε και μια καλη με το πισω σποιλερ..λoγικα και τα αλλα ειναι carbon..
  13. gbak
    για κρατηθειτε... AUDI R8 ABT
  14. gbak
    δεν μιλαμε ποτε ετσι για τα σκουμπι...ιεροσυλια...ακου κει λεον..και οπελ.. εμενα racer μου αρεσει πολυ αλλα δεν το σκεφτομαι...σκεφτομαι αλλα ομως..
  15. gbak
    αχχ και να ξερες μικρε τι τσαγακια εχουν κερασει αυτοι οι ροτορες σε πιστονια διπλασιας αξιας και κυβισμου.... εντωμεταξυ ΝTG αυτο που βαλες φερνει αρκετα σε TVR
  16. gbak
    αμα σας πω οτι δεν μου αρεσει σχεδιαστικα..προτιμω το Lexus LF-A
  17. gbak
    αυτο εκανα το τελευταιο που ειπες φορεσα ενα tie wrap στο σημειο που τσακιζει και ηρθε στα ισια του σχετικα...το θεμα ειναι οτι απο θερμοκρασιες nb ειμαι πολυ καλα οποτε θα δω προς στιγμης το αφηνω ετσι...
  18. gbak
    δεν λεει γι αυτο ρε λεει για το υπαρχον cf που παιζει σε 3870 μονες...το νεο θα λεγεται CROSSFIREX
  19. gbak
    Performance Improvements Performance improvements with this release of Catalyst includes Company of Heroes DX10 frame rates increasing as much as 20% across all of the ATI Radeon HD 2x00 series of products and on all ATI Radeon HD 3x00 series of products. These performance improvements are even larger (up to 30%) for CrossFire configurations.
  20. gbak
    αντεε γιατι δειχνει λιγο μπουκωμενη η διπυρηνη μου
  21. gbak
    ειναι ελεγχομενο τσακισμα ρε.. το χω σου λεω..
  22. gbak
    ΑΝ7 OverClocker με γεια η μπεμπα ρε δικο σου ειναι?? τουμπανο λεμε πολυ ομορφη πρωτη φορα μου αρεσει τοσο πολυ μπεμπα...αν και δεν θα λεγα οχι και στην προηγουμενη...
  23. gbak
    βασικα το κανα ετσι για να γλυτωσω χρονο...δηλαδη τροποποιησα μονο μια σωληνα...κατα τα αλλα η ροη στο κυκλωμα δειχνει μια χαρα...λιγο στην εξαρεωση με παιδεψε αλλα ειναι οκ...ισως σκεφτω κατι αλλο μελλοντικα που θα χω χρονο και με αλλο κουτακι ισως...
  24. gbak
    αλλη μια απο μενα εβαλα στο νερο και την μαξιμους εχθες το βραδυ με εντυπωσιακο drop στην θερμοκρασια απο 50c επεσε στους 32c
  25. gbak
    πωρε πολυ μπιχλα το μοτερι..αλλα εργοστασιο..v6 twin turbo χαμος λεμε... θα ρθω να σε βρω ρε αφου ξερω το στεκι σου...απλα θα μαστε σε private mode...γιατι θα χουμε σοβαρη συζητηση...
