NoDsl
    7.275
  • Ημέρες που κέρδισε
    9
Posts posted by NoDsl
  1. Δεν είχα ξαναδεί από κοντά.. Πολύ ωραίο!
    Και εγώ το έβγαλα φωτό τις προάλλες που είμουν κάτω. Εν τω μεταξύ όπου το πέτυχα ηταν σταθμευμένο. Να το ακούσω μια φορά δεν έτυχε.
    Α ρε καλαμάτα με τα φτωχαδακια σου :giveup:
  2. Φίλτατε n00bάκο Eloxim... έχουμε και λέμε.
    Πρώτον, καιρός γαρ εγγυής.
    Έπειτα:
    παιδες τι ειναι τα :
    Pixel Format
    επιλογες
    Full RGB
    Limited RGB
    LCD Overdrive
    GPU Scaling και ITC Processing.
    Ευχαριστω προκαταβολικα.
    1) http://en.wikipedia.org/wiki/RGB#RGB_arrangements_for_8-bit_indexed_color
    2) Overdrive – Also referred to as Response Time Compensation, this technology is based on applying an over-voltage to the liquid crystals to motivate them into their orientation faster. This process forces them to a full white (inactive) to black (active) transition first. The crystals can then drop back down to the required grey level. This is helpful as the rise time of a crystal was always the slowest part (response time = Tr + Tf).
    3) GPU scaling
    if source =800*600
    then
    {monitor automatically fills screen to its native resolution(>800*600) by stretching it
    If source = 800*600
    then
    {gpu upscales it to the monitors native resolution (by stretching it?)};
    end both ifs :triniti:
    ITC Processing
    Enabling ITC Processing for DTVs
    ITC processing is a feature that enables display processors to use the appropriate pixel data processing algorithms based on specific content type to ensure video quality.
    With ITC processing, the graphics driver enables the display to use its own video quality processing algorithms for movies played in full-screen mode on HDMI™ displays.
    Note: This feature is available only for DTVs connected with HDMI cables and may not be available for all systems.
    From the Graphics Settings tree, expand DTV.
    Click Attributes.
    Select or clear Enable ITC Processing as appropriate.
    Select—Enables ITC processing for HDMI displays that are capable of the feature. When movies are played in full-screen mode, the display’s processors can be used to ensure video quality.
    Clear—Disables ITC processing. Video quality is ensured by the graphics driver for all types of contents displayed.
  3. Καλοί φαίνονται. εχτές που τους έτρεξα σε vista x64 με Q6600@3.6 και 4850@ 750-1150
    είχαν σε crysis 1366*768 / dx10 / x86mode / very high / 33 average(έτρεξα το GPU_test batάκι απο το folder).
    1680*1050 / dx10 / x86mode / very high
    TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
    !TimeDemo Run 0 Finished.
    Play Time: 93.79s, Average FPS: 21.32
    Min FPS: 15.45 at frame 138, Max FPS: 26.36 at frame 859
    Average Tri/Sec: -8622187, Tri/Frame: -404351
    Recorded/Played Tris ratio: -2.27
    !TimeDemo Run 1 Finished.
    Play Time: 89.89s, Average FPS: 22.25
    Min FPS: 15.45 at frame 138, Max FPS: 26.58 at frame 862
    Average Tri/Sec: -8697573, Tri/Frame: -390894
    Recorded/Played Tris ratio: -2.35
    !TimeDemo Run 2 Finished.
    Play Time: 89.83s, Average FPS: 22.26
    Average Tri/Sec: -8682055, Tri/Frame: -389950
    !TimeDemo Run 3 Finished.
    Play Time: 89.78s, Average FPS: 22.28
    Min FPS: 15.45 at frame 138, Max FPS: 27.99 at frame 868
    Average Tri/Sec: -8727109, Tri/Frame: -391754
    Recorded/Played Tris ratio: -2.34
    TimeDemo Play Ended, (4 Runs Performed)
  4. πωωωωωωωω μού'χει σπάσει τα νεύρα το stuttering που κάνει. Τι textures low τι high το ίδιο και το αυτό. 1,5 giga μνήμη θέλει η μλκια... έλεος...
    Ωραίο eye candy όμως το game και σχετικά σταθερή απόδοση. Δεν βλέπεις ας πούμε σκηνές με 1000 fps και σκηνές με 2. Πάιζει απο 60-19 σε τρελές εκρήξεις σε 1680(vsync on).
  5. Αρχική απάντηση από Vasot [Σήμερα, στις 13:45]
    Aμαν ρε σεις ξεκολληστε μερικοι με τα drivers και τα Benchmarks
    Παιξτε και λιγακι το παιχνιδι και μιληστε σχετικα με τα χαρακτηριστικα του παιχνιδιου
    Γιατι αγοραζετε παιχνιδια...για επιδειξη ισχυος του συστηματος σας ??
    Γιατί το crysis θα το πάρεις για το gameplay του;
    Αν θές gameplay παίζεις warsow, MOH:Airborne και συναφή παιχνίδια. Αυτό το φουτουριστικό fps είναι σαν το doom3. Eye candy
    Ρίξε τα πάντα στο game ώστε να κάνεις γραφικά CS 1.6 να δούμε κατα πόσo θα συνεχίσει να είναι αρεστό.
    Καταλήγω στο οτι κάθε παιχνίδι βγαίνει για το δικό του λόγο και όχι απαραίτητα για fun.
  6. Αρχική απάντηση από ngt [Σήμερα, στις 10:51]
    Μεγαλη πλάκα βέβαια εχουν οι γλάροι στον αέρα, καντε εξασκηση σκοποβολής !
    lol και άλλα πτηνά.
    το πλί'μ
  7. Τίποτα. Aπλά μην αλλάζεις τπτ απο το cp. Ντάξει το θέμα αλλάζει και πάλι με beta drivers or whatever αλλά ντάξει τι 20 τι 26fps πάλι unplayable είναι.
    1680*1050 Q6600@3.6 / 2900pro default clocks & drivers. Cat 7.10 official. WinXpPro
  8. Αρχική απάντηση από Athens2004 [Σήμερα, στις 11:45]
    Αν σας ειναι ευκολο παιδες στις gts να ανεφερετε το μεγεθος της μνημης καθως η 640 εχει αρκετη διαφορα με την 320 και θα δημιουργηθουν λαθος εντυπώσεις . ¨)
    Καλημέρα.
    Μήπως να αναφέρουμε και τα settings στους drivers γιατί μεταξύ χρηστών βλέπω μεγάλες διαφορές. ’λλο να κάνεις "bench" με drivers στο performance και άλλο όλα default.
  9. Q6600 @ 3.6 / 2900pro default clocks cat 7.10 win xp / 1280x1024 all high.
    cpu
    gpu
    Αφιερωμένο εξαιρετικά στους αρχάγγελους :flower:
  10. Μιας και συζητάμε για εξαρτήματα dremel πολύ καλή ιδέα θα ηταν, κατα τη γνώμη μου, κάποιος γνώστης του αθλήματος να έκανε ένα guide, ας πούμε, με τα εξαρτήματα dremel και τη χρήση τους. Υλικά, προτεινόμενοι μέθοδοι κλπ.
    Θα ηταν αρκετή δουλειά αλλά θα βοηθούσε υπερβολικά πολύ.
    Π.χ θέλω να φτιάξω κάτι και δεν ξέρω τι εξάρτημα χρειάζομαι για το τάδε υλικό και την τάδε δουλειά.
  11. Καλύματα; Τα κανονικά πλαστικά του κουτιού είναι, βαμένα. Τα drives είναι μαύρα απο κατασκευής τους.
    Τα κοψήματα είναι όλα με τροχό και τα τελειώματα και "λεπτομέριες" με τους δίσκους που δίνει μαζί με το dremel η εταιρία(300 series). Αλλά σπάνε εύκολα οι χαζόδισκοι. Τελικά κατέφυγα στο να βάζω 2 -2 τους δίσκους στο εξάρτημα.
  12. Αρχική απάντηση από kallileo
    Εχει επιρροη στην εξελιξη του παιχνιδιου αν σκωτονουμε τα κοριτσακια ή αν τα ελευθερώνουμε?
    Αρχική απάντηση από jpavly
    Εγώ που τα σώζω όμως πήρα κάτι ωραιότατα δωράκια :D
    Πόσα adam δίνει άμα τα σκοτώσεις βάρβαρε; ’μα τα σώσεις 80.
    Εγω τα σωζω ρε....:D I'm a good man....
    http://arstechnica.com/journals/thumbs.ars/2007/08/30/little-sisters-save-or-harvest-we-break-down-the-best-approach-for-adam
