Posts posted by zpaf
Αριστερα το setup μου δεξια παλι το ιδιο 2x6950 αλλα σε sandy bridge πλατφορμα για να παρουμε και ενα μετρο συγκρισης x58 vs p67.
O i7-2600k ειναι στα 4500MHz.
Αναμενω και ενα σε 3dmark vantage.
Αsus gtx570 900/4400@1.175v Core i5 2500k@4800Mhz
Δωσε μας και το νουμερακι που πηρες απο την 3dmark για να δουμε εκτος του overall και gpu score.
Full notes:
Catalyst 11.1a Hot-Fix
The latest Catalyst Hot-Fix; (11.1a) offers increased performance brings a slew of new features and should be the driver used for any performance testing. Below are a few of the highlights from this driver:
Performance improvements for the AMD Radeon HD 6800 & HD 6900 series include but not limited to:
AMD Radeon HD 6900 and AMD Radeon HD 6800 Series:
· 3DMark Vantage improves ~7%
· 3DMark06 improves ~3%
· Call of Duty Black Ops improves ~20% at 4xMSAA and up to 35% at 8xMSAA
· Riddick Assault on Dark Athena SSAO performance improves ~20%
· Unigine Heaven OpenGL performance improves ~10% at moderate, 30% at normal and 100% at extreme tessellation levels
· Aliens vs. Predators improves ~9% at 2xMSAA and up to 20% at 4xMSAA
· Batman Arkham Asylum improves ~4%
· Crysis Warhead improves ~2-4%
· Metro 2033 improves ~28% at 4xMSAA
AMD Radeon HD 6900 Series:
· Battleforge DirectX 11 performance improves as much as 6%
· The Catalyst Control Center includes an early prototype of some new tessellation controls. Our goal is to give users full control over the tessellation levels used in applications. The default selection “AMD Optimized” setting allows AMD, on a per application basis, to set the best level of tessellation. The intention is to help users get the maximum visual benefit of Tessellation, while minimizing the impact on performance. Currently no applications have been profiled, so the “AMD Optimized” setting will be non-operational until further notice.
· The “Use Application Settings” option gives applications full control over the Tessellation level. Users can also manually set the maximum tessellation level used by applications with the slider control
· The long term goal for the “AMD Optimized” setting is to use the Catalyst Application Profile mechanism to control the AMD recommended level of tessellation on a per application basis. AMD’s intention is to set the tessellation level such that we will not be reducing image quality in any way that would negatively impact the gaming experience.
να δουλευε και το crossfire (είτε με 8.790.6.2000, είτε με 8.801..) στο f1 2010, ΤΙ ΚΑΛΑ ΠΟΥ ΘΑ ΤΑΝΕ.. (έχω εγκαταστήσει και το τελευταίο cap1), ιδέες/προτάσεις?
trifire μαλλον θες να πεις.
^Τζαμι η καρτουλα ωραιος.
Με τι ταση εισαι σε αυτα τα ρολογια ;
zpaf αν σου είναι εύκολο να τρέξεις ένα 3D Mark11 με τις κάρτες 950\1450 θα σου ήμουν ευγνώμων man!
Thanks!
1
Διαβασα εδω ομως οτι με τον 10.5 παει καλυτερα?
Εννοεί ότι όσοι είναι κολλημένοι με benchmarks αλλάζουν drivers μόνο για αυτό. Π.χ. Βάζεις 10.5 για 3dmark 11 και μετά για να παίξεις ένα καινούργιο παιχνίδι βάζεις πάλι τους 10.11.
Αν έχεις χρόνο για πέταμα το κάνεις...
Οποιος θελει να benchαρει παιρνει ενα 2ο δισκο και παιζει με drivers και οχι μονο χωρις να επηρεαζει σε τιποτε την λειτουργια του master disk.
1
Το HDDErase που προτείνετε πάντως δε μου δουλεύει. Δοκίμασα με το 3.3 που είναι συμβατό με τους intel αλλά όταν φτάνει στο σημείο να διαβάσει τους δίσκους απλά μένει κάγκελο.
Κανε κατι αλλο.
Στο bios εχεις την επιλογη ide και performance enchanced.
Κανε το enchanced standard ή compatible και νομιζω θα εισαι οκ.
3DMark 11 version 1.01 update
1
χάλια μαύρα σε P, περιμένουμε drivers της προκοπής!
Ε δεν το λες και χαλι μαυρο αυτο Result
1
Ε ρεεε κυριλικιαααα
Μια συγκριση απο τους 10.5 μεχρι σημερα.
1
με SLI είναι τα score
Για σου ρε seb καλημεραααααα
Ελπίζω να μη φας το παραμυθι tesselation σε λίγο καιρο (4 μέρες), 3DMark 11 will be released November 30, 2010
Αλεξ τελειωνε και ασε τα πεισματα.
Το φαγες που το φαγες το παραμυθι δωσε νουμερα στον λαο ντεεεεε
edit
Αρχιζουν και με αγχωνουν τα compare Result
δεν εχω καταφερει να το κανω να δουλεψει....
Δοκιμασε με disable aero.
cap4 <-- what is this ?
3DMark 11
In Μετρήσεις & Αποτελέσματα Υπερχρονισμών
Συγνωμη για το off topic.
