Cyber_Cookie
    16.036
  • Ημέρες που κέρδισε
    310
Everything posted by Cyber_Cookie
  1. Cyber_Cookie
    World of Tanks
    @panoc Δε ξερω αν το ειδες, Update 9.18 has the improved matchmaker, which tries to create a 3/5/7 template. That means it'll put together matches with no more than three high-tier tanks, five middle-tier tanks, and seven low-tier tanks on each side. If too many of one tier are stuck in the queue, then it'll setup one-off matches that, for instance, pit an even number of high- and middle-tier combatants together, or perhaps and all low-tier match. Another major point of Update 9.18 is an all-around revision to SPGs (that's the long-range support fire vehicle, the sniper, the artillery, otherwise known as "arty"). Getting one-shotted by arty will not be happening anymore. Arty will do less damage, but they'll also be more accurate and reload faster. They've also got a new stun which is going to hose your aiming and movement for a bit. There's also a new targeting view which fits somewhere between the arty's usual top-down map view and the usual over-the-shoulder tank view. And the final big point of Update 9.18 is the stretching of light tanks into the top tier (Tier X). The new Tier X light tanks are faster, more maneuverable, and pack more of a punch than the previous Tier VII ceiling. Their guns put them just below medium tanks' firepower
  2. Cyber_Cookie
    World of Tanks
    Ποιος είπε οτι είναι οτιδήποτε άλλο.???? Στο ranked ολοι οι pedobears / statpaders χωρίς καν 10αρι εκτός εξαρχής, ολα τα bot μετα τις πρώτες 5 μάχες εκτός και μένουν όσοι θέλουν να τις μετρήσουνε. Απο κει και πέρα ιδού η ρόδος...-
  3. Cyber_Cookie
    World of Tanks
    Free for all PVP είναι σε φορματ 2 ομάδων γιατι να νoιαζονται για τον Raziel ή τον Rusty ή τον Quickybaby? Aφού το λέει ο ποιητής : The ultimate measurement of your personal skill. Οχι measurement of how team dependant you are. Ή measurement of how well you can farm damage from redline while your team tries to win and tank the enemy fire for you. Ναι είναι Elo hell αλλά έτσι έιναι σε όλα τα game. Τραβα στο LoL που εκει μετράει το αν χάνεις/νικάς στα ranked να δεις πως πετας PC σε φωταγωγούς. Εδω για πλάκα ανεβαίνεις σε κάθε μαχη. Απλά δε καταλαβαίνω γιατι σε καρκινιασε τόσο
  4. Cyber_Cookie
    World of Tanks
    ΙS4, alley rush prokorovka με ενα πτώμα Strv σαν ασπίδα στο frontal plate μου. ΗΕΑΤ blackhole. Ξαναλέω, αν το σκεφτεις, τα XP βγαίνουν απο πόσο αποτελεσματικές είναι οι ενέργειές στου στη μάχη. Δηλαδή το πόσο καλός παίκτης είσαι και πόσο επηρεαζεις την εκβαση. Mπορεί είσαι τοπ ΧΡ με 0 shots fired. Τα δε καρκινο-καμπερια ποτε δεν είναι τοπ σε ΧΡ γιατι το active engagement δινει παντα πιο πολλα.
  5. Cyber_Cookie
    World of Tanks
    Μα τα ΧΡ μετράνε. Οχι το DMG. Αυτό ειναι το καλό. Σε ηττα, 1500 dmg, 3500 σποτ, 5000 blocked. Πρώτος σε ΧΡ, ανέβηκα ρανκ κανονικά. Ενω το Leo που εκοβε απ το σποτ μου πηρε τα @@ του.
  6. Cyber_Cookie
    World of Tanks
    Nαι στα μισα για rank 4 Είμαι. χθες εβγαλα απο καθαρα credit απο ranked 700κ. Οι αντιπαλοι είναι έτσι γιατι ξεκινάνε όλοι απ το 0 προφανώς. Placement σε κάνει το συστημα και μετα σε πεταει με του συναφιού σου. Για το WN8 ως ε-πενις μεζουρμεντ τουλ λέω. Oτι και να λέτε, αν καποιος είναι τόσο καλός όσο λέει, δεν έχει λόγο αν μην είναι gold league. Αν δεν είναι, τοτε δεν είναι τόσο καλός τελικά και φοβάται να εκτεθεί. Απλά δεν υπάρχει δικαιολογία.
  7. Cyber_Cookie
    World of Tanks
    TOG = Aka δεν εχει λόγο υπαρξης. Εχουνε βγάλει ranked battle. Οποιος νομίζει οτι είναι καλός, παίρνει ένα δεκάρι και παει και παίζει απεναντι σε αλλους. Το matchmaking είναι skill based και δεν εχει σημασία αν νικάς ή χάνεις. Το ladder χωρισμένο σε stages / seasons. Σαν επαθλα έχει gold/πρεμ/credits και consumables και μια νεα μορφή χρημάτων τα bonds με τα οποία αγοράζεις improved equipment. Πχ. vent που δίνουν 7.5% αντι 5, rammer που δίνει 12.5% αντι 10 etc. Επίσης είναι στα σχέδια να αλλάξει το ingame rating και να λαμβάνει υπ οψιν του τα ranked και την τρέχουσα αποτελεσματικότητα του παίκτη, οχι ιστορικά stats.
  8. Cyber_Cookie
    World of Tanks
    Και παλι, αν τις μετραμε με βαση το rank ναι, γιατι πρπει να κάνεις τρελό carry για να φτάσεις ψηλα. Τα αλλα ανεβαίνουν με statpeding. Που μου τυχαινει να καθομαι με arty/td και να παιρνω assistance dmg απο LT unicums
  9. Cyber_Cookie
    World of Tanks
    Aν μιλας για wn8 ειναι οσο current είναι το TOG πλεον. Οποιος ειναι gold league τον παραδεχομαι, οι αλλοι οσο καλο wnx και να χουνε honestly I dont give the slightest f*ck.
  10. Cyber_Cookie
    World of Tanks
    1η μάχη
  11. Cyber_Cookie
    Πείτε Ό,τι Θέλετε v5.0
    This is how we roll.
  12. Cyber_Cookie
    My mood today belike
  13. Cyber_Cookie
    World of Tanks
    Πρώτη κουρτίνα.
  14. Cyber_Cookie
    World of Tanks
    Περισσότερα αυτη τη φορα.
  15. Cyber_Cookie
    World of Tanks
  16. Cyber_Cookie
    World of Tanks
  17. Cyber_Cookie
    World of Tanks
    Το ειχα δει το vid και ειδα και την κλαν προφανώς. Ειναι για λυπηση τέτοιοι τοξικοι statpeders. Sorry κιολας. http://wotlabs.net/eu/player/gtyuo10
  18. Cyber_Cookie
    World of Tanks
    jk/Ranked or uninstall. Δεν υπάρχει τίποτα άλλο/jk
  19. Cyber_Cookie
    World of Tanks
    Στο defeat εμεινα απο σφαίρες.
  20. Cyber_Cookie
    World of Tanks
  21. Cyber_Cookie
    World of Tanks
  22. Cyber_Cookie
    World of Tanks
  23. Cyber_Cookie
    World of Tanks
    Λάθος προσέγγιση ΙΜΟ. Τα πιο ΟΡ τανκ δεν μπορεις να τα αγορασεις με λεφτά. Παρε το πιο τούμπανο πρεμιουμ και βγες σε 9αρι 10αρι. Ουτε στάχτη δε θα μείνει. Απο κει και περα οπως εχω πει και παλαιότερα, το να χώσεις λεφτά πρακτικά εξυπηρετεί μονο στο να παίζεις λιγότερο για φαρμ. Σε τιποτα άλλο. Μερικές εξαιρέσεις ειναι τανκ τυπου pzB2, Valentine 2 κλπ αλλα και παλι η διαφορά ειναι στον παίκτη σε σχεση με το επιπεδο των αντιπάλων οχι στο τανκ. Πχ στο τιερ 4 με τα παιδάκια, οπως εχω 65% νικες σε 300-400 μαχες με Β2 ετσι εχω και με Μatilda κι ας βλεπει και 6αρια. Υ.γ τα μονα τανκ αυτη τη στιγμή που αγοραζοντας τα έχεις καπως αδικο πλεονεκτημα ειναι τα κινεζικα πρεμ lights(typ 62, typ 64).
  24. Cyber_Cookie
    Γι αυτό 1-0.
