Posts posted by wolves
[ame=http://www.youtube.com/watch?v=MR-wBjKvRrE]☼ State of Battlefield - BF4 Fixed? Patch = New game? - YouTube[/ame]
fixedη λέξη για αυτό : 5 μηνες πριν την κυκλοφορια του (6+ αν ισχυει οτι αυτο που παιζετε ειναι 2 build πισω)
[ame=http://www.youtube.com/watch?v=LN0BxwZ-HTU]Battlefield 4 FINAL STAND: Spyder Bow, NEW Knives, and More! - YouTube[/ame]
Παιδια εκανα εγκατασταση παλι το παιχνιδι σημερα να ριξω καμια τουφεκια αλλα δεν παιζει. κολλαει συνεχεια απο το loading μεχρι και μεσα στο παιχνιδι, τι γινεται?
το punkbuster ειναι ενημερωμενο; κανε σε πρωτη φαση update αυτο.
Ανεπίσημα και με κάθε επιφύλαξη.Τα unlocks και ενα τοξο για το Final Stand
Και bypod knife (1o, 2η σειρα)
Δε το προλαβα...
Για οποιον δεν ειχε προλαβει το Golden Joystick Awards και το δωρεαν κλειδι για το XCOM: Enemy Unknown, ξανανοιξε και δινει κλειδια...
https://goldenjoysticks.greenmangaming.com/
However, we can confirm that there are still free game codes available for those who and cast their votes between now and Monday, as well as everyone who's already voted. -
Inside Project CARS Seta Tire Model
Racing, whether it happens in the real or the virtual world, is all about tires. That’s why Project CARS is powered by the revolutionary Seta Tire Model (STM) that plays a key role in making the WMD-powered title the most authentic virtual racing experience.But what exactly does the Seta Tire Model do? Slightly Mad Studios’ physics expert Andrew Weber takes us for a look deep under the hood of the tire technology that drives Project CARS!
Seta Tire Model Described
Seta Tire Model (STM) is a full dynamic tire simulation. Actually, it is three coupled simulations, one for the tire carcass, one for the tire tread and contact patch, and one for heat transfer simulation. It is also modular, where different carcass and tread simulation techniques can be used interchangeably. For example, off road racing may use a different tread simulation.
Carcass Simulation
The carcass simulation used in Project Cars is a finite element simulation with specific computational optimizations specific to real time tire simulation. The carcass is discretized into small connected “elements”, each one flexing and deforming due to forces.
Features:
Elastic behavior changes with speed, temperature, and pressure
Rolling resistance changes with speed, temperature and pressure
Sidewall buckling at low pressure
Bias Ply, Radial, or Hybrid construction
Gyroscopic Effects
Dynamic response such as vibration, telescoping, and twisting
Tread Simulation
The tread simulation used in Project Cars is a finite difference simulation of the contact patch, with the tire tread “flowing” through the contact patch. The whole tread itself is discretized into elements much like the carcass, but the contact patch itself is a finite difference grid.
Features:
Flash Heating, which is the change of temperature in the outermost rubber layer through the contact patch.
Componentized grip model. Each component is affected differently by road surface conditions, wetness, and temperature.
Deformation – the rubber deforming in and around asperities, resisting sliding motion.
Adhesion – the rubber bonding to surface rubber and material.
Tack – the sticky tacky grip you can feel on your shoes when walking a rubbered in track, related to adhesion.
Tearing – the ripping of rubber from the tire
Cut – grip from the geometry, edges, grooves, and siping of the tread, with particular effect in dirt and gravel
Tread channel depth and water handling.
Discretized and temperature sensitive wear
Curing
Temperature sensitive elastic properties
The carcass and tread simulations are coupled such that there is no roughness or “stepping”, while still preserving the detail of both simulations. The contact patch size, shape, and pressure distribution is determined by the carcass simulation and is used by the tread simulation. The forces on the tire from the road surface are simulated in the tread simulation and transferred as external forces to the carcass simulation.
Heat Transfer Simulation
The heat transfer simulation handles heat flow between brakes, wheel well, rim, carcass, and tread layers. The heat transfer amongst tread elements, from tread elements to the road surface, and from the tread elements to the air are handled directly by the tread simulation (including advection and evaporation). The pressure of the tire is maintained by the carcass simulation via the ideal gas law.
Emergent Effects
Most effects just “fall out” of STM without explicit coding for effect:
Fy, Fx, and Mz vs slip angle curves, complete with realistic nuances, such as Mz inversion
Inclination effects such as camber thrust
Complex and sometimes subtle changes in behavior due to load, heat, pressure, and speed.
Proper behavior at a standstill and very slow speeds, although due to limitations of consumer force feedback devices, oscillations may still occur.
Many tire models break down at a standstill.
Flatspots
Hydroplaning
Changes in behavior due to surface differences, such as surface roughness, track rubbering in, wetness, and dirt.
[ame=http://www.youtube.com/watch?v=WoGULTnalfY]BF3 vs BF4 Soldier Soldier Animation, Big Difference! - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=ZmuUyq3n77s]Battlefield 4 Mission Log - YouTube[/ame]
Steam lets you play 10 full games for free this weekend • Eurogamer.net
Steam is hosting its largest "free weekend" promotion ever that will allows users to play 10 full games at no charge until Monday.Starting at 10am PST tomorrow (that's 6pm for UK folk), the following games will be completely unlocked at no charge throughout the weekend.
Awesomenauts
Blade Symphony
Company of Heroes 2
Don't Starve
Grid 2
Injustice
Killing Floor
Payday 2
Trine 2
XCOM: Enemy Unknown
[ame=http://www.youtube.com/watch?v=s_ZqcnFRlHQ]Battlefield 4 Oh god, stairs! - YouTube[/ame]
-Fix for an issue that prevented server administrators to edit the amount of required players needed to start a game
-Fix for an issue that caused hit markers not to appear while shooting and hitting enemies with a Main Battle Tank
You can find the documentation for this server version here: http://eaassets-a.akamaihd.net/dice-games/BF4/ServerDocumentation/BF4_PC_Server_R43_ServerAdministrator.zip [eaassets-a.akamaihd.net]
@wolves μηπως επειδή είναι παρόμοιο στυλ με το mordor που έπαιξες πρόσφατα;
Δεν εχω παιξει το mordor...
Καμια, μα καμια, σχεση, τα 2 games.
Το ryse το ξεκινησα, αλλα το βαρεθηκα γρηγορα. Δε με κρατησε καθολου.
Πας τραινακι κανοντας τα ιδια και τα ιδια.
Στην αρχη οι μαχες σε εντυπωσιαζουν αλλα μετα απο λιγο τις βαριεσαι. Και δεν υπαρχει και καποια προκληση σε αυτες.
Και να μην κανεις, για παραδειγμα, στο σωστο timing το combo παλι θα κανει τα executes.
Γενικως πολυ ρηχο στο gameplay ωστε να σε κρατησει το παιχνιδι για καιρο.
Επαναλαμβανω οτι οπτικα ειναι αψογο με φοβερα γραφικα και ωραια απεικονιση της εποχης.
Και το crysis 3 εσπερνε απο γραφικα. Σαν παιχνιδι ηταν γτπ ομως...
PC gamers get Assassin's Creed Rogue early 2015 • Eurogamer.net
[ame=http://www.youtube.com/watch?v=eTbO8ka5uQQ]Assassin’s Creed Rogue | Story Trailer [uK] - YouTube[/ame]Assassin's Creed Rogue launches on PC early 2015, Ubisoft has confirmed.The PlayStation 3 and Xbox 360 versions launch on 14th November 2014.
Rogue is a different game to Assassin's Creed Unity, which also launches on 14th November 2014 but for PC, PlayStation 4 and Xbox One.
It tells the story of how Shay becomes a Templar and fights against his former assassin brothers.
ενταξει, τιποτα το ιδιαιτερο το game (κατι πλεον συνηθισμενο για την crytek)
για bench ειναι καλο με τα ωραια του γραφικα αλλα μεχρι εκει
[ame=http://www.youtube.com/watch?v=9WNTRDNEg6I]Enhancing Resident Evil - producer walkthrough - YouTube[/ame]
To ryse υποστηριζει gamepad ?Ειδικά αυτο του xbox 360 για pc.
ναι, κανονικα.
[ame=http://www.youtube.com/watch?v=qlvqdcFcgwc]Ryse; Son of Rome: Maximum PC Gladiator Gameplay (PC 1080P) - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=OVSUTzbDNK4]Assassin's Creed Unity Single Player Xbox One Gameplay in 1080p - YouTube[/ame]
Evolve (L4D3?)
In PC Gaming
[ame=http://www.youtube.com/watch?v=qvSEQldz3ZM]Evolve – Savage Goliath Trailer (UK) - YouTube[/ame]
