liakjim
    7.703
  • Ημέρες που κέρδισε
    7
Everything posted by liakjim
  1. liakjim
    Assetto Corsa Multiplayer Racing [Greek Gatherings]
    Δεν το βρήκα αστείο.
  2. liakjim
    rFactor 2
    Ημιμάθεια.... Σχεδόν όλα όσα αναφέρεις, εκτός από τον πραγματικό καιρό, υπάρχουν και στο assetto. Λογικά το 2020 , θα το καταλάβεις.
  3. liakjim
    rFactor 2
    Άντε για να χαρεί λίγο : Image Space Incorporated Exclusive Interview
  4. liakjim
    rFactor 2
    Μην κάνουμε κύκλους στις συζητήσεις μας, τα έχουμε ξαναπει. Όποιος κατατάσει το Assetto, σε οτιδήποτε εκτός από sim, είναι παντελώς άσχετος.
  5. liakjim
    rFactor 2
    Είσαι τόσο λάθος που ούτε καν θα τοποθετηθώ (ναι το έχω ξαναπεί).
  6. liakjim
    Automobilista
    A new EARLY ACCESS build of AMS (v.0.8.6r) has been deployed now on Steam. Below are the release notes & main changelog (please make sure to check for some important information regarding the new build): V0.8.6r Improved support for Windows User Account Control - now all user-generated files should be stored in MyDocs\Automobilista folder. Users with UAC on will be prompted to create a new profile (if you disable UAC or run as admin however it will still use game folder) Added option to select PLAYER LEVEL after new profile creation (can be changed later from the difficulty menu) - CASUAL / ADVANCED / HARDCORE: depending on level selected, the default settings will be customized accordingly for various Difficulty / Controls / Display options Several new UI improvements & adjustments + version number added to bottom right corner of main menu Further adjusted tire scrub volume calculation, default settings & added Tire Volume Slider to the AUDIO menu Some DynHUD improvements for better stability (& pedal cursors now optional from the editor) Fixed bug with vehicle labels not working Fixed bug with FFB level selection sometimes not sticking Added a FFB Reset function whenever a session is (re)started (to try prevent issues with users occasionally losing FFB) Implemented advanced transmission code for all cars with dog-type sequential boxes (Marcas, SuperV8, MR18, Lancer RS, Shifter and Superkart) now featuring ignition cut-off (AKA powershift) in upshifts; if engine / drivetrain RPM mismatch is too great, gear change is not accepted Downshift protection also added to prevent engine over-revving in semi-auto boxes; (ζήλιες) Added option for manual gear shift override in cars with autoshift electronic aids (such as F-V10 & Camaro SS) Adjusted flatspotting range (slightly more sensitive than previous version) Fixed bug with Mini autoshift driving aid not working correctly Removed launch control being left mistakenly enabled in F3 & Supertruck Tweaked fast line at chicane in second half of lap of Salvador to minimize cars rolling Fixed foggy cockpit windshield in Lancer RS Fixed bug with Renault Fluence LOD in night lighting Various AI adjustments to generally improve their behavior & performance Added a few missing helmet skins + corrected alpha channels for another lot of them Fixed digital LCDs not working in Indian Momentum F-Extreme cars
  7. liakjim
    Σωστά!!!! Πολύχρονος!!!!
  8. liakjim
    Assetto Corsa
    Μοιάζει με κάτι τέτοιο
  9. liakjim
    rFactor 2
    Οι οδηγικές σου αρετές, συμβαδίζουν με αυτές του... admin....έναν αγώνα δεν αξιώθηκα να τρέξω χε χε χε @panosdimp, τι είδες από τους 12 γύρους?
  10. liakjim
    rFactor 2
    Off topic : Για τον φίλο @rapid_fast, που εντυπωσιάστηκε τα μάλα από το FFB του rF2 , δες εδώ ρυθμίσεις για G25/27 που θα σου δώσει σχεδόν (ένα 95%), το ίδιο feeling.
  11. liakjim
    rFactor 2
    ΟΚ, ειδοποίησε .
  12. liakjim
    rFactor 2
    Θα προσπαθήσω να έρθω.
  13. liakjim
    Assetto Corsa-Mods-Downloads etc.
  14. liakjim
    rFactor 2
    Τσάμπα το skin, έτσι κ αλλιώς κανείς δεν θα το βλέπει χοχοχο
  15. liakjim
    Επιτέλους , update σε ένα από τα καλύτερα mod του Assetto. Οδηγήστε το και θα καταλάβετε!!!!
  16. liakjim
    Στο rF2 είναι αρκετά καλά. Στο AC θέλει πληρωμή.
  17. liakjim
    Ψήνεται. Νομίζω θα κλάψω όταν το οδηγήσω, ούτε θυμάμαι πόσες αφίσες είχα με δαύτο στο δωμάτιό μου . Για μένα το Νο1 αμάξι όλων των εποχών. Ναι αυτά είναι renders... Lancia Delta S4 Gr.B 1985 ..in development..
  18. liakjim
    Kart Kraft
    Μούφα είναι.
  19. liakjim
    Kart Kraft
    Κάτσε να βγει πρώτα.
  20. liakjim
    Assetto Corsa tips and tricks
    Νομίζω καλύτερα εδώ AC Dynamic Track Calculator 2.0 (για τους φίλους μας τους admins)
  21. liakjim
    Μια πολύ ωραία συζήτηση για τα αμορτισέρ. Κάποια τα είχα καταλάβει εντελώς ανάποδα. (πχ ότι τα πιο σκληρά αμορτισέρ, επιταχύνουν την μεταφορά βάρους). Επίσης ρίξτε μια ματιά και εδώ. Shock Absorber Tuning - Our Model for Tuning for Balance with Shocks. και Neil Roberts Article on Shock Tuning
  22. liakjim
    rFactor 2
    Για skins καλοί είστε. Χρόνους δεν βλέπω...
  23. liakjim
    Kart Kraft
    Interview: Black Delta Studios - Developer of the Upcoming KartKraft
  24. liakjim
    Assetto Corsa
    link
  25. Δεν θα μπορέσω να τρέξω σήμερα.
