Posts posted by idonthave
καλημέρες
έτσι να κρύβεστε , ξέρετε ποιοι
- 9
Instead of AGESA 1.0.9.0 (internal) there is now AGESA1.0.0.7a with three important changes
WWW.IGORSLAB.DE
There are always challenges that the company has to overcome in connection with AGESA (AMD Generic Encapsulated Software...ΠαράθεσηThere are always challenges that the company has to overcome in connection with AGESA (AMD Generic Encapsulated Software Architecture). The exact causes of the problems with AGESA 1.0.7.0 are difficult to determine, but are believed to be due to a combination of faulty or inadequately tested code changes and insufficient communication between AMD and motherboard manufacturers.
The last version for the end customers, the AGESA 1.0.0.7, was apparently hectically recalled (I had reported in detail about the internal version 1.0.7.0) and again explicitly supplemented by three points. In the meantime the version AGESA 1.0.9.0 was announced in advance (for internal use by board partners), but at the same time the public version AGESA 1.0.0. 7a was circulated. Exactly for this I have exclusively the excerpts from the ChangeLog for you.
The first two entries are for all Ryzen 7 CPUs, whether with (X3D) or without 3D-V cache (X). Also here, the SOC Voltage was named for AMD's Overdrive (AOD) (as Voltage Input) as well as an extension of the help text was announced:
PLAT-131921: [RPL]and [RPL-X3D] Limit AOD menu setting for SoC voltage input to 1.3V when not in LN2 mode
PLAT-132133: [RPL]and [RPL-X3D] Update AOD menu help text to reference LN2 mode for expanded voltage rangesFor the X3D CPUs there is also a general, internal limitation from 1.4V to 1.3V listed, whose limit also applies outside of AOD – ie in general
[PMFW-13058] Change SOC max Voltage limit in FW to 1.3V from 1.4V--------------------------------------------------------------------------
ASUS Rolls Out AMD AGESA 1.0.0.7a BIOS For AM5 Motherboards But Patch B Already In Works
WCCFTECH.COM
ASUS has now rolled out its second AGESA 1.0.0.7a (Patch A) BIOS firmware for AM5 motherboards following the AMD Ryzen burnout...ΠαράθεσηIt looks like AMD motherboard vendors have missed the initial deadline to roll out the proper BIOS firmware that was meant to introduce PROCHOT Control and PROCHOT Deassertion Ramp Time functions which would have fully eliminated the burnout issues. Although there has been no major report since the SoC voltage was limited to 1.3V by BIOS vendors, the full solution is yet to make its way to AM5 motherboards.
So far, the internal memory and stability issues are causing the delay of these two functions and it looks like it will be some time before we get to see them in a public Non-BETA BIOS. With that said, a Patch B of the AGESA 1.0.0.7 is already in the works and there's also info regarding a Patch C immediately after that.
2 ώρες πριν, το μέλος gdp77 έγραψε:
Αυτό ακριβώς έγραψα: Είναι προσωπική του άποψη! Τον μηδενισμό πού τον είδες?
Προσωπικά ΔΕΝ με ενδιαφέρει η εμφάνιση της μητρικής καθώς μπαίνει σε case που ΔΕΝ είναι "βιτρίνα", όπως είναι η μόδα της εποχής, και κάθεται στο πάτωμα. Με ενδιαφέρουν μόνο τα features, η εγγύηση, η τιμή και η σταθερότητα
Μόδα της εποχής δεν είναι, θυμάμαι πέρναμε τα κουτιά, κόβαμε τα πλαϊνά και βάζαμε πλέξιγκλας.
Σε κάποιους δεν τους ενδιαφέρει αν τα χρώματα στα parts θα είναι τρικολόρ (όπως σωστα λες), κι άλλους τους ενδιαφέρει.
*Μόνο abit θα έπαιρνα σε πολύχρωμη
Μόδα είναι τα rgb παντού
Αν η asrock έβγαζε στην τιμή που κυμαίνεται η legend (με τα specs που έχει) με ουδέτερο theme (σκέτη μάυρη-πίσσα ή και λευκή) θα πουλούσε περισσότερα κομάτια.- 1
2 ώρες πριν, το μέλος TopCLR έγραψε:
Καλησπέρα (καλημέρα καθυστερημένη!).
Περίεργα τα πράγματα σήμερα.
Μέχρι τώρα έβλεπα ποστ με καλημέρες και από κάτω ποστ με γατιά. Σήμερα στα ποστ με τις καλημέρες έχει και γατιά!
Τι έγινε; Παράτησαν τα γατιά οι "κοκκινοπράσινοι" και τα αναλάβατε εσείς!!!
λέμε τις καλημέρες μας και ταυτόχρονα ανεβάζουμε και την αντίδραση τους για να μην τους κουράζουμε
- 2
13 λεπτά πριν, το μέλος tommybertsen έγραψε:
Α, έχει και led?
Το λουκ της παλιάς μου taichi ήταν κομπλέ. Γκριζομαυρο με ωραίο στυλ (το γρανάζι το προτιμώ από τους δράκους in your face της msi ) .
Έχουν ξεφύγει αυτές βέβαια σε τιμή κ;ο πλέον είναι e-atx...
αυτή είναι κομπλέ αλλά το έχουν μ@...ει με τις τιμέςαπενεργοποιείς τα led και είσαι κομπλέ (και κάνεις πως δεν υπάρχει η χρυσή λωρίδα )
40 λεπτά πριν, το μέλος tommybertsen έγραψε:
Το κάνει και η ASRock με την steel legend σε Ίντελ. Απλά νομίζω έχει gen4 και pcie5. Αλλά και πάλι, στα ~300. Που πολλά είναι αλλά δεν είναι άσους.
Δεν ξέρω τι κάνει για amd βέβαια.
Να δω πως θα στείλω στον αγύριστο την άσους δεν ξέρω..
Το τσίρκο που λες δεν ξέρω από πού προκύπτει. Αν είναι για τα λουκς , είναι υποκειμενικό. Οπότε δεν είναι valid point.
To gen5 για m.2 και pcie μαζί με μελλοντική αναβάθμιση (cpu) χωρίς να αλλάξεις μητρική είναι το κριτήριο που πήγα στο am5, αλλιώς άλλαζα είτε τον επεξεργαστή και έβαζα τον 5800x3d στο b550 που έχω έιτε πήγαινα στους μπλε με τις ddr4 που έχω με κάποιον 13600κ/13700κ.
Όταν ξεκίνησε ο ντόρος με την τάση κοίταξα για τις εναλλακτικές που μπορείς να βρεις που να έχει τα gen5.
Πέρα των x670e tuf, b650e-f, και b650e-e από asus στρατόπαιδο μεταξύ 200€-400€
Για msi έγραψα πορηγουμένως τα συν και πλην, μόνο η tomahawk x670e έχει αλλά άργησε να κυκλοφορήσει.
H asrock είναι κομπλέ στα specs (το τσίρκο ναι το γράφω για τα χρώματα που έχουν επιλέξει, υπάρχει χώρος και για μητρική με black theme)
Την legend την έχω στο pc (b560) της τηλεόρασης (με κλειστά τα led και δεν την βλέπω καν )
31 λεπτά πριν, το μέλος gdp77 έγραψε:
H ειδοποιός διαφορά είναι ότι οι άλλες εταιρείες δεν κάνουν overvoltage που ανατινάζει επεξεργαστή + mobo και μετά κυκλοφορούν "beta" bios που αναφέρει ότι λύνει το πρόβλημα (αν και τελικά δεν το λύνει) γράφοντας στο disclaimer ότι δεν φέρει καμία ευθύνη. Μιλάμε για τραγική κατάσταση.
Όσο για τα επιχειρήματά σου για τις άλλες εταιρείες τύπου "είναι τσίρκο" ή "δεν την πάω καθόλου", καταλαβαίνεις ότι αυτά είναι προσωπικές σου θέσεις και δεν αποτελούν ουσιαστικά επιχειρήματα για να διαλέξει κάποιος μητρική άλλης εταιρείας πλην asus.
Για το vsoc από την στιγμή που έχει δώσει γραμμή η amd κόφτη στο 1.3 θα το τσεκάρεις και ο ίδιος μετά, δεν το αφήνεις στην τύχη του απ'την στιγμή που ξέρεις ότι υπάρχει θέμα και το χαμηλώνεις αν χρειάζεται, επίσης για το beta το βάζεις με δική σου ευθύνη όλες το αναφέρουν.
Το τσίρκο έγραψα (για μένα προσωπικά αν και νομίζω κι άλλοι την θεωρούν ) της asrock και αναφέρομαι για την legend (αλλά και η livemix ) που αν δεν είχε τα λευκά γκρι +τα λεντάκια θα την είχα πάρει ήδη..
Αν θα έπαιρνα κάποια μητρική αυτή την στιγμή θα ήταν είτε το τσίρκο x670e legend, είτε την msi x670e tomahawk (αλλά η msi τσιγκουνεύτηκε κάποιες έξτρα θύρες στο rear panel και ψύξη ston m.2) με πρώτη επιλογή την msi.
καλημέρες
- 5
Όσον αφορά τα bios, μπήκα και τσέακαρα στους υπόλοιπους κατασκευαστές, τα stable bios που έχουν (non beta) είναι 27-28/4 όπως και της asus όπου έχουν τον κόφτη για το vsoc.
Το agesa 1.0.0.7 επίσημα θα έβγαινε 6/5 και μόνο η asus το περιέλαβε (ως beta) οι υπόλοιπες έχουν μείνει στο παλιότερο (28/4) bios ,
στο OCN (αν θυμάμαι σωστά) είχα διαβάσει το stable θα βγει σήμερα 12/6.Όσον αφορά τα beta bios (και ίσχυε/ει πάντα) όλοι πάνω κάτω το ίδιο γράφουν έμμεσα ( δεν φέρουν ευθύνη αν γίνει κάτι)
απλά η asus to πήγε παραπέρα και λέει άμεσα δεν σας καλύπτωΣτο 2ο video του GN συμφωνώ στο τέλος σχετικά με την προσέγγιση που θα έπρεπε να είχε η asus και να είχε τα @@ να βγει μπροστα και να πει
για ότι συμβει θα σας καλύψω (όπως είναι η evga στο θέμα support).
Σχετικά με τις υπόλοιπες μητρικές από τις άλλες εταιρείς επειδή τις έχω δει σχεδόν όλες 450€ και κάτω
- gigabyte δεν πάω με την καμία
- msi
για να έχεις τουλάχσιτον ένα gen5 m.2 και pci-e gen 5 έχει μόνο η x670e tomahawk την οποία δεν την βρισκες τόσο καιρό και πάιζει στα ~360€
αλλά το rear panel είναι φτωχό συγκριτικά με το αντίστοιχο b650 (αλλά δεν έχει τα gen5).
για να πάρεις κάτι καλό πρέπει να ανέβεις στα 500€ (χ670ε κάρμπον), όλες οι υπόλοιπες δεν..
- asrock όσον αφορά τα specs με και τα chipsets είναι οι πιο νορμάλ σου δίνει τα gen5 m.2 και pci-e gen 5 αλλά είναι τσίρκο
- asus έχεις και τα specs και δεν είναι τσίρκο για αυτό και την επιλέγουν οι περισσότεροι (αλλά στα voltage soy λέει πάρε λίγο παραπάνω )
Οπότε αν δεν μπορείς να έχεις gen5 m.2 και pci-e gen 5 στην am5 πλατφόρμα σε "λογικό" κόστος, και ο λόγος που την επιλέγεις
είναι για να μπορέσεις να κουμπώσεις τους 8000/9000 μελοντικά χωρίς αλλαγή μητρικής, ε τότε άντε γεια..... πας στους μπλεΚαλημέρες
καλημέρες
- 6
- 3
1 ώρα πριν, το μέλος BloodMage έγραψε:
πραγματικα δεν υπαρχει. παιρνει 2 360αρια, ενα πανω και ενα κατω, τι αλλο να ζητησεις
σε τι υπερτερει το Ο11 μινι?? προσωπικα προτιμω το σχημα του 201. το Ο11 φαινεται πιο ογκώδες
σε χώρους, ότι δεν θα είναι πιο στριμοκwλα τα παράγματα και θα κάνεις πιο έυκολη την ζωή σου
επίσης το πίσω μέρος είναι modular και μπροείς να το διαμορφώσεις όπως θέλεις ανάλογα με την μητρική που έχεις
και να κουμπώσεις υδρόψυξη όπου θέλεις πάνω κάτω, στο πλάι μπροστά 2πλό,τριπλό κλπ κλπ
21 λεπτά πριν, το μέλος kpetros έγραψε:
TG πλαινο υπαρχει ?
έχει και με TG
ρεεει πάρτε το lian li O11 air mini να σωθείτε
- ian li
- asus→ 205 x 350 x 460 mm
3 ώρες πριν, το μέλος Simon έγραψε:
Μαζεύτηκαν οι πολύχρωμοι να σπαμάρουν το ΠΟΘ..
- 2
- 5
AMD Lists Radeon RX 7950 XTX, Other Unreleased Graphics Cards
ΠαράθεσηAs it turns out, AMD is prepping a bunch of new Radeon RX 7000-series products, including Radeon RX 7950 XTX, 7950 XT, 7800 XT, 7700 XT, 7600 XT, and 7500 XT for desktop computers as well as Radeon RX 7600M XT, 7600M, 7700S, and 7600S for laptops. Several things strike the eye with this list.
- AMD Radeon™ RX 7950 XTX | RDNA3 | gfx1100
- AMD Radeon™ RX 7950 XT | RDNA3 | gfx1100
- AMD Radeon™ RX 7900 XTX | RDNA3 | gfx1100
- AMD Radeon™ RX 7900 XT | RDNA3 | gfx1100
- AMD Radeon™ RX 7800 XT | RDNA3 | gfx1101
- AMD Radeon™ RX 7700 XT | RDNA3 | gfx1102
- AMD Radeon™ RX 7600 XT | RDNA3 | gfx1102
- AMD Radeon™ RX 7500 XT | RDNA3 | gfx1102
- AMD Radeon™ RX 7600M XT | RDNA3 | gfx1102
- AMD Radeon™ RX 7600M | RDNA3 | gfx1102
- AMD Radeon™ RX 7700S | RDNA3 | gfx1102
- AMD Radeon™ RX 7600S | RDNA3 | gfx1102
Έχεις συσκευές πάνω σ'όλες τις usb θύρες ?
Εαν ναι δοκίμασε να αφήσεις μόνο πληκτρολόγιο και ποντίκι (και σε διαφορετικά ζεύγη usb αν συνεχίσει το ίδιο).Επίσης τσέκαρε μήπως έχεις ξεχασμένο usb στικάκι.
Και κάτι ´αλλο που θα δοκίμαζα θα αποσυνδεα τα usb καλώδια (front ports του κουτιού) πάνω από την μητρική.
2 ώρες πριν, το μέλος HotPeanut έγραψε:
Ακόμα ψάχνετε;
απλά δεν προλαβαίνουμε
καλημέρες, καλησπέρες και καληνύχτες
α καλά
Spoilerτώρα είδα ότι άλλαξε σελίδα -απαντήθηκε
- 2
41 λεπτά πριν, το μέλος DEADLAZARUS έγραψε:
Οι χρήστες οι οποίοι δεν ξέρουν τι είναι το bios και θέλουν να πάνε στην am5 πλατφόρμα τι κάνουν; Ήρεμα ρωτάω.
7 λεπτά πριν, το μέλος tommybertsen έγραψε:Με τους χρήστες που νομίζουν ότι η λύση είναι mini itx , τι γίνεται; Ήρεμα ρωτάω (όπου σε βρίσκω θα σε βαράω ρε άτιμε )
τα μισά..
- 3
Ξαφνικό πρόβλημα εκκίνησης!
In AMD Platform
τα 130€ για την noctua είναι πολλά, 120 είχε κι αντι να κατέβει λίγο η τιμή, την ανέβασαν.
εγώ σκέφτομαι να πάρω την παρακάτω
https://www.alpenfoehn.de/produkte/cpu-kuehler/brocken-4-max
