Downtime alert 09/12 @ 19:00-20:00 Αναβαθμίζουμε την υποδομή μας για να προετοιμαστούμε για τις καλημέρες του νέου έτους!! ×
alerts "μικροί" θα υπάρχουν, άλλα (υποθέτω) δεν θα κλειδώνουν την ήπειρο. Όπως είπα δεν έχω πετύχει πχ. Bio Lab alert για να δω τι γίνεται (1 μέρα έιναι κι όλας :D), άλλα για να μπήκαν οι adversarial, υποθέτω το κλείδωμα θα γίνεται μόνο με κατοχή γης πλέον.
Continent Locking
We did some polish and bug fixing. We also added new adversarial alerts.
Adversarial Alerts
  • All existing alerts have been retired and replaced with Adversarial Alerts
  • An Adversarial Alert triggers whenever an empire controls at least 75% of a continent
  • The "attacking" empire who triggered the alert wins by either conquering the continent (by having 85% territory control) or by maintaining their 75% control by the end of the time limit.
  • The "defending" empire wins the alert by gaining 35% territory control
  • The continent locks in the case of an attacker win
  • It is considered a draw if neither the attacker nor defenders meet their win condition
  • All adversarial alerts have a 1 hour time limit
  • The 2 minute countdown to the start of an alert was removed
  • Alerts now have a participation bonus of +30% XP (up from +20%)
Adversarial Alert Rewards
There are 4 possible end conditions and the reward scheme is as follows:
  • Attacker Dominating Victory (attacker territory is equal to or greater than 85%)
Attacker reward = 5000 XP
Defender reward = 500 XP
  • Defender Victory (defender territory is equal to or greater than 35%)
Winning Defender reward = 5000 XP
Losing Defender reward = Portion of 5000 XP (based on their territory control)
Attacker reward = Portion of 5000 XP (based on their territory control)
  • Attacker Victory (attacker territory is greater than or equal to 75% but less than 85%)
  • Draw (attacker territory is less than 75% and defender territory is less than 35%)
Concurrent alerts are now supported
  • Multiple alerts can now be active at the same time
  • You must be on the continent of the alert to see alert status information on the Tab screen
  • The continent selector on the map screen now displays active alerts and their timers
  • The warpgate terminal also shows active alerts and their timers
Δυστυχως βγαινω αληθινος.
Bye bye alerts:bye:
Επαιξα πολλες ωρες χθες και παιζω μπολικες σημερα εχει γενικα πολυ κοσμο αλλα απο alerts 0.Eνα θυμαμαι χθες μου φαινεται που τελειωσε και πολυ γρηγορα.Δεν εχει καταφερει καποιο faction να κατακτησει το 75% καποιου χαρτη.
Μικρα alerts δεν υπαρχουν.
θα αρχισουμε να το κανονιζουμε μου φαινεται μεταξυ μας vs-tr-nc για να παιξουμε alert.
Well game over σχεδον για μενα το παιχνιδι μετα το merge...μεχρι να κανω καμια αναβαθμιση εστω.
Πρωτον γιατι γινεται παντου σφαγη απο κοσμο και αν δω πανω απο 25frames κανω παρτυ
αλλα και δευτερον γιατι δεν μου αρεσουν τοσο μεγαλες μαχες.
τρώμε πολύ ξύλο μετά το merge, κάτσε όμως να ανασυγκροτηθούμε και θα δούνε τα στρουμφάκια και τα barneys :D
Απειρος κοσμος τρελος λαγκ,αθλιο framerate, bugs,καποια dcs(μολις πεταξε εξω ολο τον cobalt:slap:).:TD:
Merge gone bad
Merge gone bad
Με τι fps έπαιζες-παίζεις ??το cpu σου δν τραβαει,το ειχα κ ξερω..
Πολυ πολυ γενικα γιατι ξερεις οτι οι καταστασεις ειναι απειρες:
Ειχα 50-60+ στις warpgates τοσο σε μικρες μαχες, 30-40 στις normal μαχες και σε χαμο 48+vs48+
(που ξερουμε οτι το 48+ ειναι απροσδιοριστο) 20πανω κατω.Που πες οτι με το ζορι επαιζα.
Ε πλεον η πλειοψηφια των μαχων ειναι τετοιες και χειροτερες,48+ με το + να τείνει στο απειρο.
Σε μια δυο περιπτωσεις φρακαραν τα καρε κατω και απο τα 10...ξεκολλησαν φυσικα μετα λιγο but still.
Και η πλακα με ολη αυτη την ιστορια ειναι οτι και ολα κατω να τα ριξω παλι δεν σωζεται η κατασταση.
Καλα δεν το συζητω αν τα βαλω τερμα σε 48vs48 κολαει freezarei καθε λιγο και λιγακι για μερικα κλασματα.
Σημερα ηταν καπως καλυτερα παντως διαλεξαμε η μας ετυχαν πιο νορμαλ μαχες και περασα καλα.:laughing:
Γενικα παντως προτειμω και πιστευω και αλλοι χιλιες φορες το 25-48vs25-48 απο το χαμο του 300vs300
Έγινε επεξεργασία από jesus
Upcoming adjustments to Alerts & Nanite costs
We have a short work week coming up with SOE Live, but we will try to get in a small tuning patch before then. I can't guarantee this will happen (sometimes stuff goes wrong), but we will be targeting early next week.
Please note this is not the only thing we will do with alerts or Nanite costs moving forward; this is just the first step.
Adversarial Alerts
We will be lowering the criteria to trigger the alert so you will see them more often and they are more achievable.
Launch criteria - Min Faction %: 51% (down from 75%)
Attacker dominating win%: 65% (down from 85%)
Defender win %: 50% (up from 35%)
Nanites
We will be increasing the cost of pulling a MAX to reel in the MAX spam a bit.
MAX cost increased to 450 (up from 350).
As always, feedback is welcome!
Bugged τα alerts δεν ξεκινανε:hehe:
Α μωρη εταιριαρα soe...
Δεν μπορουν μια φορα απλα να φτιαξουν κατι και να μην χαλασουν κατι αλλο..
  • 1 month later...
Αστο φιλε το παιχνιδι ειναι πλεον 100% unplayable.
Τα εκαναν θαλασσα με το patch του αυγουστου (valkyrie)
Kαι προχθες το αποτελειωσαν.
Παρα πολλα προβληματα με το σημαντικοτερο αυτο
[ame=http://www.youtube.com/watch?v=HCT47jWdBS4]Hitching - YouTube[/ame]
Το παρατάει μαζικα ο κοσμος.
  • 3 months later...
Ζεσταίνουμε τα όπλα μας για παγκόσμιο ρεκόρ
https://www.youtube.com/watch?v=9WjXz4KtffQ&feature=youtu.be
Καλη φαση το απο πανω και δεν το χα παρει χαμπαρι,φανταζομαι θα το streamarei στο twitch καποιος να το δουμε.
Παιζει κανεις ρε παιδες εχει πεθανει το thread :p
Ξεκιναει και η closed beta sto ps4 στις 20 του μηνα.
Tα πιασαμε τα 50κ kills
θανατος σε ολους τους heavy VS με τα orion/sv88/betelgeuse <_<
Το κανω παραθεση στο κανονικο θεμα για PS2 που εχουμε!
Δεν το ξερα να πω την αληθεια.
Χαχαχαχαχαχαχαχαχαχαχα ο galotsas:-P
Eιναι thelabιτης?
Μια χουφτα ελληνες παιζει να παιζουμε το παιχνιδι κυριολεκτικα..
  • 3 months later...
