Προβλημα με 9950
nalamanos
Έχει η AMD Fab στην Κόρινθο ? :hehe: ( just joking )
Εύχομαι να πάνε όλα καλά...
By the way...με αφορμή το θέμα σου, έστειλα στo Support της Gigabyte σχετικό email για την υποστήριξη του 9950 από την 790FX-DS5 :
1/19/2009 01:51
Question : Dear Sirs,
Regarding the CPU Support page of this motherboard, i have a question.
Does this motherboard support the Phenom X4 9950 B3 140W Cpu, or even the 125W version of it ?
I think that the Bios Update page, in a previous form showed Bios F6 comments as "Update CPU ID (Support AM2 Phenom 9950 CPU)".Now that text comment has changed and shows only "Update Agesa ... etc.".
This motherboard seems to be a "light" version of DQ6 one, so it's strange that the DS5 does not seem to support these cpu's. Is it a matter of non-updated Cpu Support Page?
Thank You
Kind Regards
xxx xxxxxx
Απάντηση :
Dear ΧΧΧΧΧ,
Thank you for your kindly mail and inquiry. About the question you mentioned, due to chipset specification and hardware design, GA-MA790FX-DS5(rev. 1.0) cannot support AMD Phenom X4 9950 processors by BIOS update. Sorry for the inconvenience. Here is the CPU Support List about the motherboard for your reference: CLICK HERE.
According to the CPU support list on our website, we have tested and verified every list CPU on the motherboard. If there is the word "N/A = Not support" besides the CPU you want to use, it means there is no BIOS or other way to let the motherboard use it.
At last, if you still have any further question to this issue or suggestion about our products/service, please do not hesitate to contact with us. If you have any issue different from original, make sure you issue a new form in order to get proper assistance and it may be response faster as well. We will try our best to help you resolve the problem ASAP.
Best Regards,
GIGABYTE TECHNOLOGY
Να επαναλάβω πως σε παλαιότερο update είχε συμπεριληφθεί (και το έχω δεί με τα μάτια μου) μέχρι και ο 9950 140W στους υποστηριζόμενους επεξεργαστές...Aπό κάποια ημερομηνία και έπειτα, άλλαξε το σχόλιο για το συγκεκριμένο Update και ο 9950 ΖFA, ZXA, 9850 διαγράφηκαν από τους συμβατούς...
Παιδια οτι εγινε εγινε η cpu ειχε προβλημα αφου μιλοντας με τον ιδιο τον τεχνικο μου ειπε οτι η cpu του εκαψε μια mobo καινουργια μιας και δεν ειχε καποια μεταχειρισμενη για να δοκιμασει.Τωρα πια με καινουργια mobo M3A79-T Deluxe και καινουργια cpu δεν θα υπαρχει προβλημα.
nalamanos πιστεύω θα είναι όλα οκ με την καινούρια σου μητρική...είναι δοκιμασμένη από πολλούς και έχει αρκετά features...
εγω παντως δεν ειχα δει ποτε υποστηρηξη του...:confused:
Δεν πειράζει...πάντως το είχαν δεί κι άλλοι (1, 2) εκτός από μένα...έμπαινα κανα-δυό φορές τη μέρα στις 4 μητρικές από 770 έως 790FX, μιας και έψαχνα τότε...έμεινε εκεί αν όχι μία-δύο εβδομάδες ίσως λιγότερο...
Επιτελους το pc ειναι ετοιμο και ο επεξεργαστης μια χαρα με την Asus.Το Thermaltake Kandalf δειχνει να τα πηγαινει καλα με την θερμοκρασια του Phenom μιας και δουλευει 32 idle και φτανει μεχρι 38 σε game.
ma790fx-ds5 ηταν η δικη μου και asus m3a32 deluxe wifi.
Η ds5 δεν υποστηρίζει phenom 9950!!!! Επίσης η μητρική αυτή έχει τρελά προβλήματα!
τι προβληματα?
