ΒΟΗΘΕΙΑ cisco 876w
PainkiLer
  • Replies 78
Φιλαράκο σου ετοιμάζω ένα configuration για να είσαι έτοιμος. Το μόνο που θα χρειάζεται να κάνεις είναι να σεταρεις την adsl απο το sdm.
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret yourpassword
no aaa new-model
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1
ip dhcp pool vlan
import all
network 192.168.0.0 255.255.255.0
dns-server 62.1.1.62
default-router 192.168.0.1
no ip bootp server
ip name-server 62.1.1.62
ip inspect name INSPECT_INTERNET tcp
ip inspect name INSPECT_INTERNET udp
ip inspect name INSPECT_INTERNET icmp
ip inspect name INSPECT_INTERNET ftp
ip inspect name INSPECT_INTERNET http
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
multilink bundle-name authenticated
username yourusername privilege 15 secret yourpassword
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
description CONNECTION TO ADSL LINE
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode adsl2+
interface ATM0.1 point-to-point
description PVC TO ISP
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description Connection to GbLan
ip address 192.168.0.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
description ADSL CONNECTION TO INTERNET
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect INSPECT_INTERNET out
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname username@ote.gr
ppp chap password yourpassword
ppp pap sent-username username@ote.gr password yourpassword
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark VTY/HTTP ACCESS
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 deny any log
access-list 100 remark rules for inbound traffic to vlan1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark rules for inbound traffic to WAN interface
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 224.0.0.0 31.255.255.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
access-class 1 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
  • 5 months later...
Δεν ανοίγω καινούριο θέμα γιατί δεν έχει νόημα.
Το router είναι σε άλλο τεχνικό, που έχει πάει και αυτός στην σχολή της cisco.Αλλά χρειαζομαστέ firmware και IOS γιατί τελικά μου είχαν περάσει λάθος εκδόσεις.Αν δεν περαστεί καινούριο IOS στο rοuter, το παλιό IOS δεν φεύγει ούτε με reset.
Αυτά που χρειάζομαι είναι τα εξής: Firmware 3.014 και IOS 12.4(15)T
Δεν τα βρίσκουμε πουθενά αν μπορεί κάποιος να τα κανει upload ή να μου τα στείλει με mail θα με σώσει.
Ευχαριστώ πολύ
Περίμενε λίγο γιατί τα λες περίεργα. Γιατί πιστεύεις ότι σου πέρασαν λάθος έκδοση; Και ποιο feature set θέλεις να έχει η 12.4(15)T;
Ενημερωτικά υπάρχει 12.4.15Τ13, ενώ η τελευταία είναι η 12.4.24Τ3.
Για όλα αυτά πρέπει να σβήσεις το ήδη υπάρχον image πιο πριν γιατί δε χωράνε και τα 2 στη flash σου.
Firmware δε βλέπω να υπάρχει στο site της cisco και δεν καταλαβαίνω πού το είδες το συγκεκριμένο.
εγώ με το παρακάτω ios
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(15)T7, RE
LEASE SOFTWARE (fc3)
έχει μέσα το firmware 3.0.18 και έβαλα επάνω την 4.0.18
το c870-advsecurityk9-mz.151-1.T την έχει ήδη embedded.
IOS να ξέρεις δεν είναι free , θα πρέπει να αγοράσεις συμβόλαιο που να σου επιτρέπει να κατεβάσεις τις νέες version του IOS
@trendy δώσε sh dsl int atm0 και θα σου λέει
Init FW: init_AMR_4.0.018.bin
Operation FW: AMR-E-4.0.018.bin
FW Source: external
FW Version: 4.0.18
αυτό είναι το firmware του modem
Κάτι ψιλιάστηκα, αλλά στη σελίδα του modem με τα ios δεν είδα να έχουν fw. Ίσως το έχουν στη σελίδα με τα adsl wics.
Δεν πιστεύω ότι πέρασαν λάθος έκδοση, αυτό είναι γεγονός.Γι'αυτό και δεν συγχρόνιζε.Τεχνικός μου το είπε.
Μου είπε επίσης πως το router έχει περασμένο ένα firmware 2.5 κάτι.
Το firmware και το IOS το είδε από εδώ http://www.cisco.com/en/US/prod/collateral/routers/ps221/prod_bulletin0900aecd801d5c4c.html
Το IOS το βρήκα c870-adventerprisek9-mz.124-15.T13.bin , από την εταιρία που μου το έστειλαν, αλλά σύμφωνα με το παραπάνω Link χρειάζομαι και το κατάληλο firmware, το οποίο δεν το έχουν.
Αν μπορεί κάποιος να μου το στείλει θα με σώσει.
  • 5 months later...
Καλησπέρα σας.
Είμαι νέος στο Forum και μόλις άρχισα να ασχολούμαι με cisco.
Είχαμε ένα VPN μέσω ΟΤΕ με cisco router 876.Μετά από καιρό, διακόψαμε τη σύνδεση και τώρα θέλω να τα χρησιμοποιήσω στις ADSL συνδέσεις που έχω. Το πρόβλημα είναι ότι έχουν διαμορφωθεί από τον ΟΤΕ και δε μπορώ να κάνω τίποτα με αυτά!Υπάρχεις τρόπος να κάνω reset σε factory defaults μιας και δε γνωρίζω καν τους αλλαγμένους κωδικούς πρόσβασης στο modem;
Ευχαριστώ!
  • 8 months later...
Καλησπέρα
Τελικά το router είχε κάποιο πρόβλημα και με επέκταση της εγγύησης με έδωσαν ολοκαίνουριο.
Αλλά μετά αντιμετώπισα πρόβλημα με τους DNS του φοιτητικού connex.
Τώρα που τελείωσα με το φοιτητικό και μου άλλαξαν το username και μπορώ να μπω με τους κανονικούς dns του ΟΤΕ, δεν ξέρω πως ν'αλλάξω το username.
Μπορεί κάποιος να μου στείλει τις εντολές να το αλλάξω;
Αφού κάνεις login γράψε enable και πάτα enter. Δώσε τον κωδικό για να γίνεις super user και μετά κάνε paste τις παρακάτω εντολές:
conf t
int dialer0
no ppp chap hostname oldusername@ote.gr
no chap password oldpassword
no ppp pap sent-username oldusername@ote.gr password oldpassword
ppp chap hostname newusername@ote.gr
ppp chap password newpassword
ppp pap sent-username newusername@ote.gr password newpassword
end
wr
...Δώσε τον κωδικό για να γίνεις super user και μετά κάνε paste τις παρακάτω εντολές:...
Όταν λες κωδικό, εννοείς άλλον από αυτόν του login;
Στο config πιο πάνω που σου είχε δώσει ο alexkhr είχε την εντολή
Αν μπαίνοντας σε βγάλει σε promt που τελειώνει με > πρέπει να τρέξεις την εντολή enable και να βάλεις τον κωδικό που έβαλες εκεί. Αν το promt τελειώνει με # τότε είσαι ήδη super user και δε χρειάζεται να δώσεις enable πιο πριν.
