Dj_ALeX
    2.285
  • Ημέρες που κέρδισε
    1
Posts posted by Dj_ALeX
  1. Παραθέτω τους νέους Crimson 16.6.2 WHQL για την νέα κάρτα της AMD RX480 για Win10 64bit όπως επίσης και τα release notes:
    Quote
    Radeon Software Crimson Edition 16.6.2 Highlights
      • Support for:
          • Radeon™ RX 480
        • New AMD Crossfire profile available for:
          • World of Tanks™
        • Radeon WattMan: A brand new utility for Radeon Software that allows users more complete control over their graphics processor. More information on Radeon WattMan and its supported products can be found here.
        • AMD Crossfire Toggle: A new option has been introduced into Radeon Settings under the "Gaming -> Global Settings" tab. This allows users to toggle AMD Crossfire support globally "on" for supported games or "off" for all gaming profiles.
        • HDMI® Scaling: Radeon Settings now provides the option for the user to adjust their display image scaling on HDMI® connected displays. This option is available under the "Display" tab in Radeon Settings for supported configurations.
        • Display Color Temperature: Radeon Settings now allows a user to set display color temperature based on either the displays predefined settings or manually via a slider configured to support the displays supported range. This option is available under the "Display" tab in Radeon Settings for supported configurations.
        • Desktop Color: Radeon Settings has added the option to launch the operating systems color page via the new "Desktop Color" button which is available in the "Display" tab in Radeon Settings for supported configurations.
        • Vulkan™ Version: Currently installed Vulkan™ version information has now been made available through the Radeon Settings "System -> Software" tab.
    Fixed Issues
        • Flickering may be observed in AMD Crossfire mode configurations while playing Hitman™ in select gameplay missions.
        • Flickering may be observed in AMD Crossfire mode configurations while playing Heroes of the Storm™.
        • Intermittent or minor white flashing may occur on some web browsers when using Netflix™ and hovering over the UI or icons.
        • Minor stuttering may occur in AMD Crossfire mode configurations when playing Elite Dangerous™.
        • Flickering may be observed in AMD Crossfire mode configurations while using the inventory and character pages in The Witcher® 3: Wild Hunt.
        • Flickering may be observed in AMD Crossfire mode configurations during the battle and tutorial loading screens in Star Wars™ Battlefront.
    Known Issues
        • A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
        • Radeon Pro Duo may experience a black screen in Total War™: Warhammer with the games API set to DirectX®12 and V-Sync enabled.
        • DiRT™ Rally may experience flickering terrain in some races when the advanced blending option is enabled in the games settings page.
        • Some Overdrive settings may not appear in Radeon Settings for Radeon Fury X when in AMD Crossfire mode.
        • Display may exhibit a minor flicker on Radeon RX 480 when Freesync is enabled on a games launch or exit.
        • Dota™2 may crash when using the Vulkan™ API and the user changes resolutions or quality settings.
        • Battlefield™ 4 may experience crashes when using Mantle. As a work around users are suggested to switch to DirectX®11.
        • Need for Speed™ may experience flickering on some light sources in AMD Crossfire mode.
        • Hitman™ may experience graphical corruption when the game is set to use DirectX®12 API and using zoom with weapons.
        • Frame Rate Target Control gaming profiles may fail to enable for some games.
        • Radeon Wattman may retain settings of an overclock after it has failed. If you have failed an overclock with a system hang or reboot make sure to use the "Reset" option in the Radeon WattMan settings page when the system has rebooted.
        • Low frame rate or stutter may be experienced Wolfenstein®: The Old Blood™ on Radeon™ RX 480.
        • Assassin's Creed® Syndicate may experience a game crash or hang when in game settings are set to high or greater.
        • Disabling AMD Crossfire mode on Radeon™ RX 480 may disable the device in Windows Device Manager. A workaround is to reboot the system to re-enable the device.
    Package Contents
    The Radeon Software Crimson Edition 16.6.2 installation package contains the following:
        • Radeon Software Crimson Edition 16.6.2 Driver Version 16.20.1035.
    • Like 3
  2. 13 minutes ago, INFLAMESGOHAN said:
    Ημαρτον δλδ....350 στο eshop...... με βαση μερικα Bench που ειδα γτ τωρα παρακολουθω και τα αλλα για 2κ που θελω εγω δεν λεει η καρτουλα.... για 1080 αμα εμενα με κλειστα ματια.... μαλλον 1070 θα τεινω σε λιγους μηνες....
    Εγώ στα είχα πεί πρίν λίγες μέρες... δεν αξίζει η κάρτα με αυτές τις τιμές...
    @giorgos2187 Aς ανοίξει κάποιος θέμα λοιπόν να το συζητήσουμε εκεί, δεν θα αναλωθώ περισσότερο για το συγκεκριμένο θέμα στο παρόν thread.
  3. 13 minutes ago, konstantinakis said:
    Αυτό που λέω εγώ είναι πως αν η 480 είχε μικρότερο TDP και κόστιζε 50 ευρώ παραπάνω θα ήταν ένα σκουπίδι. Τώρα έχει μία πολύ καλή τιμή αλλά και πολύ κακό TDP συγκριτικά με αυτά που μας έδειξε η nvidia αλλά ο κόσμος δεν ενδιαφέρεται τόσο πολύ γι αυτό. Η αναλογία απόδοση/τιμή είναι που ενδιαφέρει τους πολλούς.
    Δεν διαφωνώ καθόλου σε αυτό που λές (το υπογραμμισμένο), ΑΛΛΑ εγώ με το σχόλιο μου θέλω να τονίσω ΑΛΛΟ πράγμα (αυτό που σου boldάρισα). Απο κεί και έπειτα μακαάρι να πουλήσει καλά αυτή η κάρτα μιάς και για την AMD απο ότι φαίνεται αποτελεί σημαντικό milestone για την πορεία της μετέπειτα. ΟΛΑ θα "παιχτούν" στην τιμή της "εδώ" τέλος! Για εμάς μιλάμε! Ο καθένας μας εάν θέλει/μπορεί να ψωνίσει απ'έξω ξέρει τι θα κάνει..
  4. 6 minutes ago, winters said:
    Το πράγμα είναι απλό, δεν υπάρχουν καλές ή κακές κάρτες, όλες καλές είναι. Η τιμή καθορίζει το αν αξίζει να τα ακουμπήσεις ή όχι.
    Η συγκεκριμένη κάρτα λοιπόν, η 480Χ 8GB εάν έχει στο ράφι εώς 250 είναι πολύ καλή, εάν είναι στα 300ευρώ είναι μέτρια, εάν είναι ακριβότερη είναι gtp.
    Αυτό το πράγμα προσπαθώ να τους εξηγήσω τόση ώρα και μερικοί πουλάνε τρέλα με ομπρέλα! Η τιμή είναι το ζητούμενο στις mid-range κάρτες παίδες! Επίσης έκανα και μία αναφορά για τις λιθογραφίες και κατά αντιστοιχία στην αποδοτικότητα αυτών απο τεχνολογικής πλευράς (κυρίως στο κομμάτι power efficiency/performance) και βγήκαν ορισμένοι στα γρήγορα να πουν οτι συγκρίνω ανόμοιες κάρτες σε επίπεδο τιμών! Οτι να ναι εδώ μέσα ειλικρινά... φαίνεται απο τα "τρένα" υψηλής ταχύτητας (RX 480) ορισμένοι ζαλίστηκαν :hehe: .
    Επίσης όσοι αμφισβητούν την αντικειμενικότητα ενός μέλους καλά θα κάνουν να παρακολουθούν διαχρονικά τα γραφόμενά του. Αυτά..
  5. 10 minutes ago, ARMAGEDDON said:
    άντε πάλι η 1070 θα έχει αντίπαλο την 490 όταν αυτή βγει η 1080 ti θα έχει την fury η titan την fury x
    πως συγκρίνουμε τώρα την 1070 με την 480 δεν έχω καταλάβει :p
    Ρεε ΣΟΒΑΡΕΨΟΥ και διάβαζε αυτά που γράφω!!! Έχεις τρελαθεί με την RX480 και δεν διαβάζεις τπτ...
    Αυτό πηγαίνει και στον @jesus και στον @LocoDiceGR έλα για πάμε λίγο...
  6. 9 minutes ago, jesus said:
    Ξερεις οτι η 1070 εχει χ2+ την τιμη της 480 ε?
    Επισης τι σημαινει οτι δεν ειπε κανεις για το dx12?Θα βγαινουν με το τσουβαλι απο εδω και περα dx12 τιτλοι ναι η οχι?
    Τι σε πιασε εσενα σε θυμαμαι ποιο αντικειμενικό.Μπας και ηπιες τπτ καφεδες με τον Sebastian?
    Ρε μάγκες καταρχάς μην ποστάρετε τόσο γρήγορα μου τελειώνουν τα threads :hehe:
    Πάμε στο θέμα μας... Εσύ διάβαζε τα πόστ μου ποιό προσεκτικά και άσε τους καφέδες στην άκρη! Δεν συγκρίνω την GTX1070 με την RX480 απλά μου κάνει εντύπωση οτι τα 16nm της πράσινης κάνουν στην κυριολεξία σκουπίδι τα 14nm της κόκκινης εάν αναλογιστούμε τι επιδόσεις έχει η μία και τι η άλλη. Τέλος δεν κοιτάμε τιμή κοιτάμε το πράγμα απο τεχνολογικής πλευράς. Απο κεί και έπειτα κανείς δεν είπε οτι δεν υπερέχει η AMD στο DX12 και δεν στοχεύει σε αυτό. Το ζήτημα που τίθεται είναι απλά το θέμα την σωστής τιμολόγησης. Εάν αυτή η κάρτα έρθει στην Ελλάδα σε σωστή τιμή τότε οκ όλα καλά, εάν όμως έρθει με τρελά καπέλα όπως έγινε με τα pascal τότε δεν υπάρχει λόγος να το συζητάμε. Αγοράζεις απέξω ΑΛΛΗ κάρτα και όχι αυτήν!
  7. 1 minute ago, ARMAGEDDON said:
    άντε πάλι ξαναλέμε η nvdia θα κλαίει όταν γεμίσει η αγορά DX12 παιχνίδια απλά πράματα τα γράφω και τα ξαναγράφω δεν καταλαβαίνατε βλέπω
    Εσύ δεν καταλαβαίνεις... Δεν είπε κανείς για το DX12!!! Επίσης η GTX1070 είναι ποιό power efficient απο την καρτούλα σου και σου ρίχνει και ένα 50%+ στα fps άρα καταλαβαίνεις πόσο καρτάρα είναι η RX480... μην το συνεχίζεις!
  8. @ARMAGEDDON Αν θυμάσαι στο αρχικό πόστ μου ανέφερα το + που έχει η AMD στo DX12 άρα λοιπόν μην πάς να μου την πείς ξαφνικά πονηρά πονηρά!
    Απο την άλλη η κάρτα αυτή θα εξαρτηθεί αν είναι καλή αγορά η όχι καθαρά απο την τιμή που θα έρθει Ελλάδα! Αν είναι να ψωνίσω απέ'ξω ξέρω πολύ καλά τι θα πάρω!
    Επίσης μην βιάζεσαι να βγάλεις συμπεράσματα για το Crossfire... επίσης μην ποστάρετε 4Κ bench γιατί με πιάνουν τα γέλια! ΠΟΙΟΣ απο σάς έχει 4Κ monitor και θα παίξει με αυτήν την κάρτα με sub 30 fps??? Ρεε σοβαρευτείτε!!!
  9. Just now, ARMAGEDDON said:
    Και εσύ έχει πλάκα :haha::hehe: για αυτό περνάμε καλά εδώ μέσα !
    ξαναλέω έλα σε μερικά χρονάκια που θα έχει εδραιωθεί αυτό που κάνει η amd και μετά θα έχει μονοπόλοιο χειρότερο από αυτό που έχει η Nvidia
    dx15-dx16 θα ξανά ανασάνει η nvidia
    Εγώ σου δείχνω τα γεγονότα το εάν εσύ ονειρεύεσαι την AMD στην κορυφή των επιδόσεων το 2020 αυτό είναι προσωπικό ζήτημα και δεν θέλω να στο χαλάσω!
    Απο την άλλη δεν είπα να μην γελάμε αλλά...
    Spoiler
    μας πάει πέτσα η GTX970 ρε γαμώτο... :hehe::sarcastic:
  10. 8 minutes ago, ARMAGEDDON said:
    πηγαίνες δίπλα να φτιάξετε το flickering με τα clocks και μετά τα λέμε :p
    Έχεις πλάκα :haha: :hehe: ... αλλά κοίταξε κάτι... ο άλλος δίπλα παίζει κρεμούλες και κλοκάρει όμορφα & ωραία και είναι στα 16nm και ορισμένες "γριούλες" στα 28nm και σου ρίχνουν στα αυτιά...! ;)
    Δεν θέλεις να σου μιλήσω για το VEGA αλλά ούτε για το "κατά πάσα πιθανότητα" 2πύρηνο Navi... δεν είναι ακόμα η ώρα! Ελπίζω να πήρες γεύση απο τα 14nm της AMD... ας τιμολογηθεί σωστά η RX480 να κάνει πωλήσεις η AMD και βλέπουμε τι θα γίνει παρά κάτω.
  11. 1 minute ago, ARMAGEDDON said:
    έλα μια χαρά είναι σε νέους τίτλους τα πάει καλά !
    άντε κλαψιάρηδες σας έφεξε πάλι οι μεν θα κλαίγονται οι δε πράσινοι θα χαίρονται και θα κράζουν !
    πω κρίμα που δεν θα πάρουμε fury με 200ευρώ όπως λέει ο @yanni :D
    Μια χαρά είναι η κάρτα επίσης για τους βιαστικούς να περιμένουν costum υλοποιήσεις , και με τον καιρό θα ωριμάσει όπως ωρίμασε και 290 και η 390 !
    μια χαρά είναι η κάρτα όταν μεταβούμε σε περίοδο DX12 τα ξαναλέμε με τους Πρασινοφρουρούς (χαίρονται με το μποδελο dx11 , και με όλα τα στημένα benchmarks που υπάρχουν)
    Γνωρίζεις πολύ καλά οτι ΔΕΝ χαίρομαι με αυτά που βλέπω... στην RX480!
    Εάν έχεις υπομονή για αυτό που σου υπογράμμισα καλό κουράγιο! :hehe:
  12. 9 minutes ago, yanni said:
    Δες λίγο το σχόλιό μου για τα νούμερα του τύπου πιο πάνω. Σύγκρινε τα νούμερά του με αυτά του Guru 3D. Ειλικρινά δεν ξέρω πόσο έχει οβερκλοκάρει την εν λόγω GTX 970 ώστε αυτή να ρίχνει σφαλιάρες στην GTX 980 του Guru 3D.
    Αν έχει απορίες δές εδώ (χρησιμοποιεί την GTX970EXOC της GALAX)! Btw όλες οι GTX 970 παίζουν για πλάκα 1300-1400Mhz πυρήνα! Για να μην μιλήσω για 1500+... το αφήνω απ έξω! @Helly πώς την βλέπεις την κάρτα? :p
    @ARMAGEDDON άρχισες πάλι τα "τυφλά" likes ή είναι ιδέα μου! :hehe:
  13. Μονάχα στο Hitman (DX12) υπάρχει σημαντική διαφορά υπέρ της RX480. Σε οτιδήποτε DX11 & OpenGL πέφτει γερή φάπα με την διαφορά να εκτινάσσεται από τα 3 έως τα 24 frames (βλέπε Alien Isolation & Project Cars @1080p)! Δεν νομίζω να κλαίει κανείς με GTX970! Και μην περιμένετε να κλείσει αυτή η ψαλίδα με drivers! Καλά στο DOOM μιλάμε για διαφορά των 26 frames @1080p & 14 frames @1440p! Τέλος η κάρτα  με Max OC ξεπερνάει τους 90°C με αποτέλεσμα να κρασάρει το σύστημα και όλα αυτά με σχεδόν 3 κατοστάρικα! Εύγε! Το μόνον που μπορεί να σουλουπωθεί αισθητά με κάποιο custom cooler είναι οι θερμοκρασίες.. κατά τα άλλα η κάρτα δεν λέει για κανέναν λόγο... Σίγουρα θα σταθεροποιηθούν/βελτιωθούν οι drivers αλλά ας είμαστε ρεαλιστές... αυτές οι διαφορές στα fps δεν κλείνουν ούτε στο ποιό τρελό όνειρο! Το μόνο που θααα σώσει αυτήν την κάρτα είναι η σωστή τιμολόγησή της!
    • Like 3
  14. Καλά άσε τώρα τα παραμύθια για το Crysis 3... μην ακούω τρέλα πράγματα... έλα!
    Επίσης σε 2Κ ναί είναι λογικές οι επιδόσεις σε σχέση με την κατηγορία τιμής που την κατέταξε η ίδια η AMD... σαφώς! Αλλά εδώ μιλάμε οτι αυτή η κάρτα χτυπάει 78+ βαθμούς και θα πωλείται σε τιμή καρά fail.... μακααάρι να βγώ ψεύτης!
  15. Just now, Helly said:
    Καβουρδιστηρι με ψυκτρα-εμφανιση καρτας 15 ετιας και επιδοσεις χειροτερες απο καρτες 28nm τεχνολογιας 3ετιας.Το κανε το θαυμα της παλι η AMD.Βασικα δε το κλεινουν το μαγαζι καλυτερα ετσι κι αλλιως δινουν τσαμπα fame points στο κορεατη χαλβα της πρασινης με αυτα που κανουν.Κερασακι στη τουρτα καμια τιμη κοντα στα 350€ Ελλαδα και θα σας τρολαρει ο @sebastian μεχρι 2ας παρουσιας
    Για 1ή φορά δεν θα έχει άδικο... βέβαια στο δίπλα thread με τα pascal έχει πετάξει τα διαμαντάκια του αλλά οκ.. no worries! :hehe:
  16. 1 minute ago, Physiciant said:
    Καλά η 970 G1 έχει πέσει στα 290 καινούργια..οπότε και τα 220 ευρώ για οποιαδήποτε 970 σχετικά πολλά μου φαίνονται για 2 χρονών κάρτα, εκτός και είναι αγορασμένη σχετικά 'πρόσφατα'.
    Καλά εσύ σε αυτό "κόλλησες".. στην βρίσκω και με 2 κατοστάρικα δεν είναι εκεί το θέμα... διάβασε το συλλογισμό μου γιατί μερικοί αγαπάνε την AMD και το καταλαβαίνω αλλά μερικές φορές βάζουν μία κουρτίνα μπροστά απο τα μάτια και δεν βλέπουν καλά το τι συμβαίνει εδώ πέρα... Ξανά λέω ελπίζω να βγώ ψεύτης!
  17. 4 hours ago, yanni said:
    Οι χρονισμοί της Zotac, αν δεν κοίταξα λάθος μοντέλο, είναι
    Base: 1152 MHz
    Boost: 1304 MHz
    Αν επιβεβαιωθούν τα νούμερα, νομίζω στο τέλος θα μείνουμε με βασικό επιχείρημα "Ναι αλλά είναι φτηνή". Το μόνο ότι την συγκρίνανε σε DX11 παιχνίδια. Σε DX12 ή παιχνίδια που ζητάνε πολύ μνήμη πιθανόν να φεύγει μπροστά. Αλλά περίμενα να καθαρίζει την 970 εύκολα. Ακόμα και μια OCed.
    Θα πώ ένα πράγμα και θα μετά θα περιμένω μέχρι αύριο... Όταν έχεις εδώ και 2 χρόνια στην αγορά μία κάρτα που καίει πάνω κάτω το ρεύμα της RX480 και αποδίδει πάνω κάτω τα ίδια στα (DX11) games ), ίσως και καλύτερα, είναι κατασκευασμένη στα 28nm και προσφέρει τα ίδια πράγματα με την "υποτίθεται φρέσκια" RX480 των 14nm, και την βρίσκεις στα μεταχειρισμένα απο 220€ (και μάλιστα custom υλοποιήσεις με υπόλοιπο εγγύησης), πέσμου τώρα εσύ 2 πράγματα... 1ον πόσο θα πρέπει να έρθει η RX480 Ελλάδα (αντικειμενικά) και 2όν γιατί να μην πάρεις μία GTX970 OCed στα χρήματα που προανέφερα?? Εάν η RX480 έρθει στην Ελλάδα στην τιμή που "ακούγεται" τότε για τα εδώ δεδομένα θα αποτελεί ένα ακόμη fail για την κόκκινη δυστυχώς... Ελπίζω να βγώ ψεύτης... διότι στις αγγελίες οι τιμές θα πάρουν την ανιούσα..! Εγώ αυτό που βλέπω και πρέπει να αλλάξει το συντομότερο είναι η αρχιτεκτονική GCN... ακόμη και στα 14nm (απο οτι φαίνεται μέχρι στιγμής) είναι πολύ δυσκοίλια σε ορισμένα βασικά πράγματα... δεν γίνεται να σε πατάει η GTX970 των 2ετών και των 28nm.. είναι ντροπή! Δλδ μιλάμε οτι είναι πολύ πίσω η AMD σε πράγματα που ο αντίπαλος στα έχει προσφέρει καιρό τώρα και σε "χειρότερες" συνθήκες κατασκευής και λιθογραφίας..
    • Like 5
  18. Πάντως είναι απογοητευτικό ένα chipaki στα 14nm να κλοκάρει χειρότερα απο ένα άλλο που είναι 2 χρόνια στην αγορά και το οποίο είναι κατασκευασμένο με λιθογραφία 28nm... με την τιμή που περιμένω να έρθει η RX480 (Ελλάδα), την βλέπω να πηγαίνει στον κάδο... Ελπίζω να βγώ ψεύτης..!
  19. 6 minutes ago, INFLAMESGOHAN said:
    Κοιτα στα 1350 σου λεω οτι ειναι το μαχ οβερκλοκ σε refernce καρτουλα με 80 μαξ θερμοκρασιες θα παιζει ανετοτα σε 2κ απλα καιγομαι ρε συ να δω τι θα βγαλουν απο τιμες ελλαντα γτ ειλικρινα σου λεω αμα ειναι 350 τιμη τοτε παω σε 1070 refernce και εχω το κεφαλακι μου ησυχο... οσο για το φιλο μας τον Μαυρο σε αυτο το θα παιχτουν σφαλιαρες γτ ειναι 3-4 ακομα και μετα διακοπες .... θα βρω το λινκ να στο στειλω σε PM
    1) Aρκετά λιγότερο (+ ένα καλό fan profile) ;)
    2) Σου είπα... ;)
    3) Δεν θα πώ τιμή...
    Spoiler
    4) Δεν μπορώ να απαντήσω...
    5) Γιατί δεν ανοίγεις ένα thread στα offtopic να κάνουμε κουβεντούλα? :p
  20. 13 minutes ago, INFLAMESGOHAN said:
    btw black goku θα φαει πολυ ξυλο !! κυριακη θα  παρω και POPKORN :D Στο θεμα μας  αν καταφερει η καρτουλα να παει στα 1350 με 1400 που δν το κοβω  θα παραγει Δυνατα FPS
    Έχω κάνει την προσωπική μου πρόβλεψη... 1300-1350 Max υπολογίζω εγώ στις reference που βγαίνουν τώρα... δεν περιμένω να δώ τρελά πράγματα... όσο για το άλλο που είπες.. έχει Σάββατο 3 το πρωί live... ξύλο δεν θα πέσει σε αυτό τόσο, στο επόμενο με τον φίλο μου τον black! :p
  21. 4 minutes ago, INFLAMESGOHAN said:
    Ξερω οτι δεν προκειτε να δω οτι βγαζει η 1070-1080 αλλα να ειναι σε κοντινα επιπεδα ενδιαμεσα σε 980 + 390χ  και προφανως σε τιμη VFM γτ θελω να παω να χτυπησω μια 2κ οθονη και μια καρτουλα !!! τωρα ποια.... θα δειξει απλα περιμενω κ εγω να μαθω :D εχω τοσα παιχνιδακια να παιξω που δεν κρατιεμαι 30 χρονων μαντραχαλος :D
    Έκει θα παίξει μπαλίτσα... με OC πάντα και φυσικά σε παιχνίδια που δεν θα περιλαμβάνουν Nvidia CrapWorks...
