idonthave
    5.318
  • Ημέρες που κέρδισε
    78
Posts posted by idonthave
  1. NVIDIA GeForce RTX 3070 Ti (SUPER) and RTX 3070 rumored to feature GA104 GPU
    Παράθεση
    RTX 3070 Series
    According to kopite7kimi’s latest tweet, the RTX 3070 Series (Ti/SUPER etc), would use GA104 GPU with the high-end variants using the ‘400’ GPU model. What this means is that the 3070 Ti/SUPER would feature the full silicon with all CUDA cores enabled. These rumors would be in line with speculation regarding RTX 3080 series using the GA102 GPU instead. The whole lineup would simply move one GPU-tier higher than normally.
    Παράθεση
    RTX 3080 Series to use bigger GPU and wider memory bus
    The most interesting rumor so far is certainly the claim that GeForce RTX 3080 would use a GA102 GPU instead of GA104. This goes contrary to the path NVIDIA took with the last 3 generations. The xx80 models have been sticking to xx104 GPUs for quite a while, with the last ‘big GPU’ reference model being the GTX 780.
    But the reason for this change could actually be quite simple: NVIDIA wants to put more memory on the xx80 series (RTX 3080) and the choice was either to use 16GB 256-bit or 10GB 320-bit. The capacity does not really have to that be much bigger, because the bandwidth will increase anyway. However, NVIDIA has not upgraded the frame buffer size for their xx80 models ever since GTX 1080 came out. Thus, it is simply expected at this point. Using the board for Ampere GA102 GPU (PG133) designed for a 384-bit bus unlocks more memory options such as 11GB 352-bit or 10GB 320-bit.
  2. με gtx 1650 είμαι τώρα, θα βγάλει χεράκια και θα με κυνηγάει η καρτούλα σε 2k.
    Όσον αφορά το cpu, να πάρω τώρα κάποιον οικονομικό 3x00x και να αλλάζω μετά,
    πάλι η μια ή άλλη είναι ως μεταπώληση, αν είναι μένω με τον 2600.
    320€ o 3800x / 180€ ο 3600x
    Όχι δεν κοιτάζω το τελευταίο fps, αλλά να μην έχω drops  και τα min fps
    να μην προκαλούν stattering/tearing δεν θυμάμαι πως λέγεται.
    Για το football manager έχω κάνει αρκετές τρέλες (στο παρελθόν) για να πηγαίνει σφαίρα
    όσον αφορά τα loads, και τις μεταβάσεις από αγώνα σε αγώνα, την προετοιμασία κτλ.
    οπότε για 3300x εν νομίζω ?. Σε intel τρέχει καλύτερα το εν λόγω παιχνίδι.
    Όλα αυτά που αναφέρεται κι εσείς τα έχω σκεφτεί, ότι σε 1-2 μήνες θα κυκλοφορήσουν οι νέες κάρτες,
    μετά περιμένεις να εμφανιστούν στα ράφια και ψάχνεις να βρεις τιμή οπότε φτάσαμε Οκτώβρη ?
  3. τελευταία πριν σταματήσω ήταν αυτά football manager / Tomb raider / The crew / GTA / watch dogs / Battlefield
    τα επόμενα όχι τόσο πολύ→  assassins creed / Arma  / COD και είναι και "μερικά" ακόμα στην βιβλιοθήκη που
    δεν τα έχω πιάσει ακόμη  (homefront,hellblade..) μπορεί να έχω ξεχάσει και κάποιο ?
    όχι @giorgos2187
  4. 970 evo plus
    2x 860 evo
    3Tb hdd
    6TB hdd (σ'αυτόν κρατάω bakup και αφαιρείται
    *Λογικά αργότερα θα κουμπωθεί ο samsung 980 όταν κυκλοφορήσει
    από κάρτες επέκτασης αυτή την στιγμή δεν θα μπει κάτι
    λειτουργικό win10
    ως προς ψύξη, η αεροψύκτρα που έχω θεωρώ θα με καλύψει
    αν όχι μάλλον θα πάω σε kraken63 ή corsair h115i
    κουτί έχω το Phanteks Enthoo Evolv X
  5. Έχω παρατήσει καιρό το gaming και ο 9900k με την 2080 έχουν φύγει αρκετούς μήνες τώρα.
    Μετά από καιρό πρόκειται να φτιάξω ένα νέο σύστημα για gaming και all around χρήση,
    Κοιτάω μόνο για cpu-mobo-gpu-psu
    (υπάρχουν Μόνιτορ 2K 144hz / 32gb ram / ssd-m.2 κτλ. )
    1) cpu-mobo
    είμαι μεταξύ
    • asus rog x570-E με ryzen 3800X ή
    • msi tomahawk/asrock legend Z490 με i7-10700K
    υπάρχει πιστωτικό 100€ για τα παραπάνω πράγματα, ως συνδυασμοί βγαίνουν πάνω κάτω τα ίδια +-20€
    σε X570 chipset άλλη μητρική έτσι όπως θέλω να είναι κοντά στα 200€ δεν βρήκα, μόνο την ASUS TUF
    αλλά είναι πετσοκομμένη, μετά ως εναλλακτική είναι η asus x570-F αλλά η τιμή είναι σχετικά κοντά με την E.
    ως εναλλακτικά combo 3600x - asus tuf x570  ή z490 - 10600k ?
    2) gpu αν και δεν θέλω να δώσω πολλά λεφτά
    είμαι μεταξύ
    MSI rtx2070 super gaming X (550-570€)
    MSI RX 5700XT gaming X (430€)
    ή μετά σε κάτι πιο οικονομικές gtx 1660 super (250-280€)
    Με black- blue κτλ. με τα drivers γνωρίζουμε αν έχουν διορθωθεί τα πράγματα σε περίπτωση που πάω σε 5700XT
    3) Ως προς PSU οι διαθεσιμότητες είναι ανύπαρκτες καιρό τώρα, (seasonic ή superflower)
    Corsair θέλω να το αποφύγω αλλά..
    αρνητικά
    OCP is set high on all rails / Very low efficiency with 2% load / Not efficient 5VSB rail
    Increased vampire power consumption / Small distance between the peripheral connectors
    Σε άλλα site που το έχω βρει γράφουν θετικά
    Περιμένω απόψεις για τα παραπάνω
    ps
    τώρα έχω ryzen 2600 και gtx1650  ?
  6. Linux και τα μυαλά στα μπλέντερ..
    windows για κάνα παιχνιδάκι ?
    ένα σαπάκι έχω για την μάνα μου dell g3 με i7-8750h, βαριόμουνα να το κάνω dual boot
    και το έχω αφήσει με τα 10αρια
    Αν χρειαστεί να πάω κάπου έξω το βουτάω, έχω 2ο δισκάκο μέσα για μένα ?
    • Haha 2
  7. Στο msi που αναφέρω, κούμπωσα έναν 970 evo και στο δεύτερο port έναν msata, στο Bios απ'όσο είδα
    ανέφερε ως disable τα 4 sata ports από 6 σύνολο, δεν έκατσα να το ψάξω παραπάνω μιας και δεν χρειάζεται άλλες θύρες,
    κι αν χρειαστεί στο μέλλον θα είναι 1-2 το πολύ.
    Οπότε αυτό που αναφέρουν, έλεγξε πόσα sata ports και nvme θα χρειαστείς.
  8. έστησα ένα μηχάνημα με x570 και 3700x
    αυτά που έχει περιγράψει ο giorgos2187 περί idle θερμοκρασίες τα αντιμετώπισα κι εγώ
    αλλά με την stock ψήκτρα, η οποία τούρμπιζε στα καλά καθούμενα χωρίς να κάνω τίποτα.
    Καθαρή εγκατάσταση χωρίς πολλά πολλά (πρέπει να παίζει κάτι με τα windows).
    Θέλω να παραδώσω το μηχάνημα χωρίς να κάνει πάρτυ όλη η γειτονιά απ'τον θόρυβο.
    Έφτιαξα custom profile έθεσα ένα μικρό μείον στο offset kai απενεργοποίησα το boost στους πυρήνες.
    Απο 40C idle και 70+ έπεσα 36C και max να έχω δει 56-58C 3,8Ghz με την στοκ ψήκτρα.
    To bagdet ήταν σφιχτό και δεν μπορούσα να κάνω περισσότερα, για την χρήση που το πήρε ο άνθρωπος
    είναι κομπλέ, αργότερα αν χρειαστεί περισσότερα προσθέτουμε μια αξιόλογη ψήκτρα και ανεβάζουμε το cpu.
    msi x570 gaming plus+3700x+16gb
    Trexx δες για την msi παραπάνω αν σε καλύπτει, μην πας σε b550,
    μνήμες 32gb είχε κάτι patriot το κιτρινόμαγαζο στα 140€ τις βούτηξα αυτές (και είχα σκάσει κοντά στα 400€ για b-die σαν μ....)
    είμαι σε αντίστοιχη φάση να στήσω μηχάνημα και για μένα είτε σε x570-3700x είτε z490 με 10600k με rtx 2070 ή 2060
    αλλά ως συνήθως δεν πρόκειται να κρατήσω για πολύ τα πράγματα.
    edit
    https://www.e-shop.gr/ram-patriot-pvs432g320c6k-viper-steel-series-32gb-2x16gb-ddr4-3200mhz-dual-kit-p-PER.574786
    • Like 4
  9. Πήγαμε στο amd σύστημα με R7 3700X με το dell P2720D 2K monitor,
    δεν πρόκειται να παίξει παιχνίδια.
    • Autocad 2d
    • Αutocad 3d
    • Relux
    • Revit
    Σε ποια κάρτα γραφικών να κινηθώ (υπάρχουν και οι δυο)?
    gtx 1650
    ή
    RX 570
    4gb είναι και οι 2 κάρτες
  10. amd
    για μητρική θα περιμένω μέχρι κι αύριο για b550 chipset,
    αλλιώς πάω σε x570 για το bugdet έχουμε ήδη κάπως ξεφύγει,
    με max τα 180€ για mb θα συνδυάσω το r7 3700x με
    MSI MPG X570 Gaming Plus υπάρχει κάποια άλλη πρόταση για μητρικές μέχρι 180€ ?
    αλλά να μην είναι από τυχαίο skroutzομάγαζο (προτίμηση από egate,mgmanager,msystems,eshop ιδανικά)
    intel
    η εναλλακτική είναι intel b460 ή z490 με i5-10600/10600k
    • MSI Z490 A Pro
    • Asus Gaming Tuf B460 Plus
    Γνώμη για τα παραπάνω?
    ευχαριστώ
    Οθόνη κλείσαμε με dell P2720D
  11. AMD Ryzen 7 3800XT and Ryzen 9 3900XT Will Not Get Coolers Included
    Παράθεση
    Most previous Ryzen 3000 models received some sort of WRAITH cooler, however, the upcoming Ryzen 7 3800XT and Ryzen 9 3900XT will not get boxed with a cooler.
    At least if the latest leak is correct. It could be to shave off cost, and well if you purchase a more enthusiast cooler, you're likely not using the included stock cooler anyway. Also, it simply can be TDP related. AMD has done something similar with the 16-core part, the 3950X. This all is based on a spec sheet that momomo_us spotted, Product codes for the two SKUs are marked as "100-100000277WOF" for the 3900XT and "100-100000279WOF" for the 3800XT, with "WOF" indicates "without fan" and thus no included bundled cooler.
    AMD to postpone Zen 3 processors to 2021 due to weak competition
    • Like 3
  12. κάτι σαν το παρακάτω αν δεν βρεις,
    το περνάς από την τρύπα,  και το σφίγεις με
    παξιμάδι απ'την άλλη πλευρά,
    και έξτρα βάζεις τσόχα αν χρειάζετε,
    http://www.benos.com.gr/e-Shop/Πλαστικες-ταπες,-υποποδια,-πελματα.aspx?page=10
    http://www.benos.com.gr/e-Shop/Πλαστικες-ταπες,-υποποδια,-πελματα/PL-179.aspx
    ρίξε μια ματιά και στις άλλες κατηγοτίες μήπως βρεις κάτι
    • Like 5
  13. διάφορες διατάξεις με τους ανεμιστήρες
    HARDWARE-HELDEN.DE
    Mit über 60 getesteten Lüfterkonstellationen zeigt dieser Guide wie der perfekte Airflow für kühle Hardware erreicht werden kann.
    και ο 2600 με το special airflow και κουτάκι μου
  14. edifier θα σου πρότεινα κι εγώ,
    όταν έπαιζαν ένα φεγγάρι στα 120-140€ και μπορούσες θα σου έλεγα να πας στα 2.1 s330D,
    τώρα σε πιο προσιτή τιμή είναι τα C2XD στα 115€
    σε 2.0  δες και τα R1580MB στα 82€
  15. Σχετικά με την οθόνη, δεν γνωρίζω πως θα του είναι τα προγράμματα σχετικά με την ανάλυση,
    αν πάει σε 32" 2k ή 4Κ ή αντίστοιχα σε 27"  2k ή 4Κ.
    Ο μόνος περιορισμός είναι το γραφείο του,
    αν χρειαστεί θα πέσει δισκοπρίονο ?
  16. Καλημέρες-καλησπέρες σε όλους, θέλω να στήσω ένα μηχάνημα για τα παρακάτω προγράμματα
    • Autocad 2d
    • Αutocad 3d
    • Relux
    • Revit
    Δεν είναι για μένα το παρακάτω σύστημα
    Σε τι σύνθεση να κινηθώ
    b550/x570 με ryzen 7 3700Χ
    Υπάρχουν
    gtx 1650 4gb και rx 570 4gb,
    500 ssd και 16gb ram
    πέρα από μητρική / cpu και ότι άλλο προτείνεται,
    τα παραπάνω αρκούν και που χρειάζεται να δώσω
    περισσότερο σημασία?
    Οθόνη ίντσες και ανάλυση ?
    Ευχαριστώ
  17. trib
    • Για πόδια μπορεί να σου φτιάξει από ξύλο ο πεθερός σου, υπάρχουν και στα ικεα κάτι αντίστοιχα (αν σου αρέσει κάτι τέτοιο).
    • Για οδηγούς για τα καλώδια μπορείς να χρησιμοποιήσεις και pvc σωλήνα, αν δεν θέλεις να μπλέκεις παίρνεις το έτοιμο που έβαλες.
    20181003_160034b.thumb.jpg.48962415f88087b9a3d0387b2b9ab02f.jpg  1104338325_20181007_122456b.thumb.jpg.8dbdee7cfccc297f2015aeea73d78475.jpg
    20181007_182837b.thumb.jpg.ec8472e1ca005d7ba9907f81cf146037.jpg    20181003_143552.thumb.jpg.1c8679bd82b43eeb4c8382562f8091e3.jpg
  18. "διώροφο κουτάκι" ? για 2 pc ?υποτίθεται,
    το ένα μέρος προοριζόταν ως gaming
    και το άλλο ως home theater κλπ κλπ.
    Διαστάσεις έχει όσο mia micro-atx & psu
    αν τα τοποθετήσεις δίπλα περίπου σε πλάτος.
    Σχεδόν έτοιμο είναι αλλά από πέρσι έχει μείνει έτσι...
    • Like 9
