Παπακοκαλημέρες...
Elden Ring [21 Ιανουαρίου 2022]
DEADLAZARUS απάντησε στο θέμα του tommybertsen topic στην ενότητα PC Gaming
Someone is Suing FromSoft Because Elden Ring is Too Hard - Insider Gaming INSIDER-GAMING.COM One zany player is attempting to sue FromSoft because they think there's another world in Elden Ring that's... -
ΤΟ ΑΠΟΛΥΤΟ 4Κ MONITOR
DEADLAZARUS απάντησε στο θέμα του DEADLAZARUS topic στην ενότητα Οθόνες & Projectors
Acer Predator X32 X 240Hz 4K Curved QD-OLED | PC Monitors PCMONITORS.INFO The Acer Predator X32 X features a 31.5" '4K' UHD 240Hz QD-OLED panel with 1700R (moderate) curve... -
ΚΑ ΛΗ ΜΕ ΡΑ...
DEADLAZARUS απάντησε στο θέμα του astrolabos topic στην ενότητα Off topic
Ινδία: Φόβοι για εκατοντάδες νεκρούς από πλημμύρες και κατολισθήσεις | Protagon.gr WWW.PROTAGON.GR Ο μουσώνας έφερε σφοδρές βροχοπτώσεις στην Κεράλα, όπου ποτάμι υπερχείλισε και παρέσυρε... -
Hogwarts Legacy [10 Φεβρουαρίου 2023]
Harry Potter: Quidditch Champions is coming to PC on September 3rd, and here are its PC requirements WWW.DSOGAMING.COM Warner Bros has announced that Harry Potter: Quidditch Champions will be coming to PC on September...- 98 απαντήσεις
- action
- action/adventure
(και 1 επιπλέον)
Intel 10nm CPUs - LGA1700
DEADLAZARUS απάντησε στο θέμα του GFFermari topic στην ενότητα Intel Platform
Intel's crashing CPU crisis deepens as more models are affected than originally thought WWW.TECHSPOT.COM The news coming out of Intel about its crashing 13th- and 14th-generation CPUs is not getting any better, even... The first disappointment is that the patch won't fix the processors if they are already crashing. Intel has advised owners to use Intel Default Settings in their motherboard BIOS while waiting for the microcode update, although this is not a guaranteed fix. But it appears the best course of action for customers that have already experienced damage is to simply replace the processor instead of tweaking BIOS settings. Intel would not share estimates with reporters of how many chips are likely to be irreversibly impacted. Worse, it now appears that the crashing issue is also affecting all 65W and higher CPUs as well as the mainstream non-K models alongside their K/KF/KS variants. -
Cinebench Scores for AMD Ryzen 9900X, 9700X, and 9600X Surface WWW.GURU3D.COM A new leaks has surfaced online showcasing the benchmark results of AMD's upcoming Ryzen 9000 series...
AMD RX 7000 - RDNA3 Architecture
DEADLAZARUS απάντησε στο θέμα του ARMAGEDDON topic στην ενότητα Κάρτες Γραφικών
https://videocardz.com/newz/amd-introduces-fluid-motion-frames-2-better-frame-generation-with-lower-latency -
[SFFPC] SFF Cases, Builds, Hardware
DEADLAZARUS απάντησε στο θέμα του DEADLAZARUS topic στην ενότητα Κουτιά
Corsair SF1000 ATX v3.1 PSU Review - Small power dwarf for thirsty ITX builds WWW.IGORSLAB.DE The Corsair SF1000 is one of the most powerful SFX power supplies currently available on the market. It... -
. Κ Α Λ Η Μ Ε Ρ Α... pan widget
Μαίνεται η φωτιά στην Εύβοια – Νέα μηνύματα από το 112 | Η ΚΑΘΗΜΕΡΙΝΗ WWW.KATHIMERINI.GR Στις φλόγες τυλίχθηκε για μια ακόμα φορά περιοχή της Εύβοιας χθες, όταν ξέσπασε σφοδρή πυρκαγιά που... -
AMD may have delayed Ryzen 9000 launch due to a typo — mislabeled Ryzen 7 chip emerges, Ryzen 5 9600X impacted, too [Updated] | Tom's Hardware WWW.TOMSHARDWARE.COM AMD has apparently encountered a marking issue that has morphed into a marketing issue.
'Καμπανάκι' από την επιστημονική κοινότητα για τα φαινόμενα λειψυδρίας σε περιοχές της χώρας WWW.CAPITAL.GR Συνολικά 14 δήμοι της χώρας έχουν κηρυχθεί σε κατάσταση έκτακτης ανάγκης. -
Δηλαδή, κ α λ η μ έ ρ α, κ α λ η μ έ ρ α, κ α λ η μ έ ρ α..
Ch.L-UEFA, & ΝΒΑ και λοιπές δημοκρατικές δυνάμεις v2.0
Ελλάδα - Καναδάς 79-86 | SDNA WWW.SDNA.GR Η Εθνική το πάλεψε, ο Γιάννης έκανε όργια (34π.) αλλά χρειαζόταν συμπαράσταση και με εξαίρεση τον...- 3.764 απαντήσεις
- 2
- αθλητισμός
- μπάσκετ
(και 1 επιπλέον)
Mortal Kombat 1 Gets a Huge Content Reveal at SDCC - Insider Gaming INSIDER-GAMING.COM Ed Boon took to the stage at SDCC to reveal the next year of Mortal Kombat 1 content. There's an epic piece of...
Κ Α Λ Η Μ Ε Ρ Α
500 ευρώ για μία γκαρσονιέρα 30 τ.μ.: Ο εφιάλτης της αναζήτησης φοιτητικής κατοικίας WWW.NAFTEMPORIKI.GR Μετά την επιτυχία στις Πανελλήνιες Εξετάσεις και την εισαγωγή σε κάποιο πανεπιστημιακό ίδρυμα... Ενοικιάζεται όπως είναι επιπλωμένο... -
No Rest for the Wicked [Early Access 18/4/24]
No Rest for the Wicked update revamps its Crucible roguelite endgame mode WWW.EUROGAMER.NET No Rest for the Wicked developer Moon Studios has released a rather hefty update for its early access...- 8 απαντήσεις
- arpg
- role-playing
(και 1 επιπλέον)
https://videocardz.com/newz/amd-ryzen-9000-reviews-will-be-posted-day-before-launch
Καλημεράκηδες... Αντικαλημεράκηδες...
Δυστυχώς -
Το ηλεκτρονικό μάτι της εφορίας εστιάζει στα ακίνητα: Ποιοι κρύβουν ενοίκια, τετραγωνικά, αυθαίρετα WWW.NAFTEMPORIKI.GR Η ακίνητη περιουσία περισσότερων από 7 εκατομμυρίων φορολογούμενων μπαίνει στο...
