Πειτε ο,τι θελετε......
jax7480
  • Replies 34,9k
Αρχική απάντηση από zyx [Σήμερα, στις 03:11]
amd amiga καλομοιρα ftw i love u ;p
αραπινο kiss my ass ;p
μιχαλακης ρεεε
Τραβα χαραξε κι αλλο τα cd του WoW ρε. Τωρα με τους Core Duo και την τρελλη επεξεργαστικη ισχυ διαβαζουν ακομα και χαραγμενα cd αν εχεις κανα σοβαρο reader οπως τα LiteOn. :p
Αν δοκιμασεις να χαραξεις πανω τους την φραση "Ειμαι ακυρος WoW-er και δεν θα ξανασχοληθω με τον Sir Charles" τοτε μπορει και να υπαρχει σωτηρια για σενα.
Πορευσου εν ειρηνη τεκνο μου.
Been wanting to run this variation for a while.
"Here's how it goes down:
You're all scientists in a remote facility in the Arctic.
One of you has become infected and turned into a hideous shapeshifting monster - The Thing. While you appear normal during the daytime, at night you take on hideous form and infect another player with your monstrousness.
From then on, the Things decide together who to infect.
Fortunately, the scientists have worked out an incontrevertible way of testing for whether someone is a thing. THe problem is the method relies on an obscure chemical component which can be generated in only two ways - one, harvested from the corpses of a Thing; two, synthesised in small amounts in a procedure that takes 24 hours.
The upshot of all this is as follows:
* The scientists can test two people per day for free. (This is the synthesised test-serum)
* If you get a Thing with the second of your Tests, you can test again. (The first batch of test-serum causes caustic damage to the THing making his corpse unsalvagble. Or something.)
* If you get a Thing on the third test, you can test again, and so on ad infinitum.
Discovered Things are killed and out of the game. Undiscovered things still get to vote on the testing.
Accidentally tested humans do not die, they remain the game.
If you are converted to a Thing, you are informed via Pm that this has occured, but NOT who your fellow Things are until you meet them the following night! You are expected to play the new role of Thing fully to the best of your ability.
No PMs are allowed between anyone except between the Things at night only, and the Things with me (to communicate the transformation, obviously).
There is no Seer or any other equivalent roles. Just scientists and an ever increasing number of Things. Unless you test the right people, of course.
Ok, so, I reckon twenty players sounds like a fun number and just a single Thing all on his lonesome to start. We start with a Day phase, so if you get lucky you'll win in a single round!
EDIT: Oh yeah, and the Things win whenever the number of things is equal to the number of Scientists, just as in regular Werewolf. The Scientists have to eliminate all the Things."
Ψηνετε κανεις?
http://octopusoverlords.com/phpBB2/viewtopic.php?t=40016&start=0&postdays=0&postorder=asc&highlight=
Αρχική απάντηση από SLN
To βυσμα των ηχειων εχει 4 τζακ που πανε στο γουφερ και καταληγουν σε 3 τζακ στην καρτα ηχου. Για τις creative αυτο το 4->3 ειναι αρκετο αλλα για τις onboard θελει 4->4.
Οποτε με τα χρωματα αφηνω 2 (π.χ. center+front) τα οποια τα συνδεω γουφερ+καρτα και με 2 ξεχωριστα τζακ, συνδεω τα πισω και πλαϊνα με τα αντιστοιχα της καρτας ηχου. Αυτη η πατεντα δουλευε μια χαρα για το karayan της DFI. Στην Ρ5Β δεν θελει να δουλεψει...
Εν τω μεταξυ δεν μπορω να ανοιξω παλι thread και να αρχισω να χωνω στην Ιντελ, γιατι θα μου το κλειδωσουνε παλι οι τραμπουκοι mod... :TD:
Ξαναλέω:
Έλεγξε ποια ''περιοχή'' του κάθε mini jack που μπαίνει στην κάρτα ήχου (το κάθε mini jack πρέπει να έχει μέχρι και 3 ''περιοχές'' 1 παραπάνω δλδ από το κλασικό στερεοφωνικό) αντιστοιχεί σε ποιο ηχείο, κοίτα το αντίστοιχο και με τις εξόδους της κάρτας ήχου της μητρικής (εκεί λογικά θα παίζει και ρύθμιση μέσω driver) και θα βγάλεις άκρη (το πολύ-πολύ να χρειαστεί να φτιάξεις κάποιο ''custom'' καλώδιο).
Αρχική απάντηση από totally_wired
ΚΑΛΑ ΝΑ ΠΑΘΕΙΣ ΑΘΕΕ
που έδωσες την x-fi... και δεν είπες τίποτα...
Όπως πάντα θεός!
Αρχική απάντηση από ea6gka [Σήμερα, στις 12:27]
κανενα ανεκδοτο καμμια αστεια φατσα να γελασουμε τπτ? παρασκευη ειναι ρα , chosen δωσε κανα γατί ρε γελασουμε :hehe:
’ντε ρε παιχταρά, αφιερωμένα:
Και ένα τελευταίο που θα σε στείλει καρφί στην τουαλέτα:
Αρχική απάντηση από astrolabos
www.rarhost.com
Ολο μου βγαζει error unknown...αλλα δεν εχει οριο στο upload..:T:
Αρχική απάντηση από deninho
το www.rapidshare.de κάνει;
Πρεπει να εχει οριο στα 50 mb...
Telika εσπασα το κομματι στα δυο και εφυγαν στο savefile.com
η ερωτηση ηταν τι συνδεση ιντερνετ εχει εκει...και η απαντηση ακολουθει...
FUGGER says:
6meg
FUGGER says:
first part done
GoriLLakoS says:
OMG
GoriLLakoS says:
i have only 1meg
FUGGER says:
at home 10m
GoriLLakoS says:
This device is for diagnosing DDR Ram errors problems
Χαχα ναι καλά, για "διάγνωση" ε;
- Ναι, γεια σας, Tech Support εκεί;
- Μάλιστα.
- Έχω ένα σύστημα με Fedora Core 4 OS και λίγο μετά το POST, τρώω kernel panic!
- Ωραία, θα σας στείλουμε έναν τεχνικό με ένα Maximizer, να σας ρίξει 4-4.5 Volts στις μνήμες, για να δούμε τι φταίει.
Αρχική απάντηση από Chosen [Σήμερα, στις 02:38]
- Μάλιστα.
Εγκαθετος της M$!!! Στα ΟΠΛΑ Σωτηρη (μου)!!!
Βρειτε τον σωστο διαλογο και κερδιστε ενα DVD με την μαγικη πορεια του "Πειρατικου" για τα προκριματικα του mundial 2006...
- Μάλιστα.
- ΠΑΣ ΚΑΛΑ ΑΝΘΡΩΠΕ ΜΟΥ?!?!?!??! Εχεις linux και θελεις να μας πεισεις οτι κρασαρε????? Αντε παιξε παραπερα γιατι εχουμε και σοβαρες δουλειες να κανουμε....
Υ.Γ. Καλες δουλειες Τζωρτζιο... Το newegg ποτε θα σε "στολισει"?
