liakjim
    7.703
  • Ημέρες που κέρδισε
    7
Everything posted by liakjim
  1. liakjim
    Wamta FUN, dual class, team cup!
    Στανταρντ έχει clipping. Με το anticlipping app θα το φτιάξει. Στο 1.4. το FFB είναι καλύτερο από ποτέ. Επίσης το enhanced understeer effect παρα είναι δυνατό για τα γούστα μου.
  2. liakjim
    Ναι Άρη, το ptracker πρέπει να είναι ανοιχτό και από τα options αλλά και από τα apps. Αν είσαι συνδεδεμενος σωστά, θα γίνουν πράσινες και συνδεδεμένες κάτι σαν πριζούλες που έχει.
  3. liakjim
    Assetto Corsa tips and tricks
    Σχετικά με το damping και ειδικότερα αυτές τις τιμές : DAMPER_MIN_LEVEL=0.0 DAMPER_GAIN=1.0 ; Set to 0 for Logitech g920 [LOW_SPEED_FF] SPEED_KMH=3 ; Under this speed the reduction will start MIN_VALUE=0.01 ; The FF multiplier for 0kmh. Let's start with the Damper. This is a DX effect that tends to slow down the wheel rotation.. the faster the wheel is rotating the more opposite force is added. The implementation is left to the driver/hardware.. so there isn't much control over it. In AC it is currently used to simulate the "stiff" wheel when the car is not moving. DAMPER_GAIN sets how strong this damper effect is... the reason it is there is because some wheel (that will go unnamed ) screw up the damper implementation and vibrate like crazy when the car is not moving.. so I had to had this value to allow to turn the damper off, or reduce the effect. DAMPER_MIN_LEVEL is the amount of damper that is left on while driving. In other words, as the car is speeding up the amount of damper goes from DAMPER_GAIN to DAMPER_MIN_LEVEL. The reason why it is here is because some wheels are mechanically very "loose" and smooth and some users missed the old "FF DAMP" value that we had in AC in previous versions. The LOW_SPEED_FF stuff is totally unrelated. It kills the forces coming from the tyres at low speed to avoid unnatural vibration when the car is about to stop or starting.. because it works at super low speed (3kmh by default) I really don't see any reason to mess up with this one at all. link Τα είχα καταλάβει λάθος . Τα έβαλα DAMPER_MIN_LEVEL=0.1 DAMPER_GAIN=0.4 ; και βλέπουμε.
  4. liakjim
    Γιώργο δήλωσε εδώ http://doodle.com/poll/rpzwt2nax68gth2a Έμεινε μια θέση μόνο, hurry up. ΑΑΑΑ το είδα πως δήλωσες. Οκ Στέλιο έκλεισαν οι θέσεις.
  5. liakjim
    O Vitas γιατί δεν δήλωσε? @rapid_fast O Γιάννης ? @uhu
  6. liakjim
    Assetto Corsa
    Πιο φτηνή δικαιολογία δεν μπορούσες να βρεις? Έλα και θα κλέψω για να βγω 1ος ώστε να πάμε ομάδα. Άγγελε εσύ? @AngeloVZR.
  7. liakjim
    Done.
  8. liakjim
    Τσάμπα χάρηκε βρε.Προς το παρόν τους γύρους τους θέλουν τα παιδιά για να δουν ότι όλοι είναι οκ. Τα χρονόμετρα θα μετρήσουν από Παρασκευή βράδυ.
  9. liakjim
    Για τις G25/G27 στο 90%.
  10. liakjim
    Τί να κάνεις back up? Απλά copy paste.
  11. liakjim
    Assetto Corsa Multiplayer Racing [Greek Gatherings]
    Τέλεια. Ευχαριστώ πολύ. Οπότε μπορείς να βάλεις φίλτρο για τους W ( wreckers ) . Καλό είναι να μπει και στο όνομα του σέρβερ πχ thelab.gr [ MR ABCN ] .@panosdimp
  12. liakjim
    Κάνε μια απονεύρωση.
  13. liakjim
    Ναι, έχω βάλει λινκ πιο πάνω.
  14. liakjim
    Σιγά τις πολλές σελίδες.
  15. liakjim
    Assetto Corsa
    Αλλάζει κ το FLEX. Δεν ξέρω φυσικά στο τιμόνι σου αν θα δεις διαφορά. Νομίζω όχι. Απαγορευτικό δεν το κάνει , απλά προσωπικά δεν θα ήθελα να μάθω τρόπο οδήγησης αλλά κυριώς setup σε ένα μοντέλο ελαστικών που θα γίνει obsolete.
  16. liakjim
    Assetto Corsa
    Έχει προστεθεί η παράμετρος "Heating from rolling Resistance" και έχει αλλάξει ο υπολογισμός του Flexing. . Πιο πολύ Info , εδώ. "SURFACE_ROLLING_K (Tyre Model 6.0) Like ROLLING_K but dedicated to surfaces. Prior to V6 the ROLLING_K value was used to generate heat as function of rolling both for Core and Surface, from V6, ROLLING_K is used for Core and SURFACE_ROLLING_K is used for Surface." "FLEX This value is not more used in V5 (but still loaded so leave it in the tyre.ini anyway for now to avoid warnings/error while loading). The functionality has now been replaced by the FLEX_GAIN value."
  17. liakjim
    Παρομοίως (έχω κ την πτυχιακή) . Θα τρέξω αλλά δεν με βλέπω να έχω χρόνο για practice.
  18. liakjim
    Assetto Corsa
    FXX !!!
  19. liakjim
    Assetto Corsa
    Δεν έχω δει κάποια λίστα. Πάντως αν έχει σκοπό να κάνεις , καλή τύχη
  20. liakjim
    Εμείς?
  21. liakjim
    rFactor 2
    Την Παρασκευή που πέρασε είχε αγώνα με 50 άτομα στο RD!!!!. Κρίμα που δεν το πήρα πρέφα (παρόλο που τρέχανε με το mod)
  22. liakjim
    Assetto Corsa
    Αφού το ξέρεις , με τρώει χαχαχα. Άντε το κόβω και πιάνω την κούρσα.
  23. liakjim
    Assetto Corsa
    Οδηγικά εννοώ. Αν παίξω ένα 2ώρο στο rF2 και πάω στο AC , θα νιώσω σαν το σπίτι μου. Το rF2 έχει λίγο καλύτερο FFB. Αν το rF2 είναι στο 10 , το AC παίρνει 9.5, πολύ μικρή διαφορά. Όσο για τα άλλα Ελαστικά -> δεν το ξέρεις . Θερμοκρασίες κινητήρα και φυσική κινητήρα -> σωστό Αεροδυναμικη και στροβιλισμοι ανέμου -> δεν το ξέρεις Κανόνες Pit και κανόνες σημαίας -> μικροδιαφορές FFB -> βλ παραπάνω Αληθινός δρόμος -> ναι οκ. Αλλά όχι laserscanned πίστες Συνθήκες καιρού -> σωστό Μην πούμε όμως κ τα προτερήματα του AC, δεν τελειώνουμε ποτέ. Τα αγαπώ και τα 2 εξίσου.
  24. liakjim
    Assetto Corsa
    Έκανα quote εκεί που έπρεπε.
  25. liakjim
    Assetto Corsa
    Πού? Πάντως κάτι κάνεις λάθος. Οι διαφορές με το rF2 είναι ελάχιστες.
