Είδηση Comments posted by idonthave
Intel was not really planning to share this information with anyone yet, but thanks to guys over at HKEPC we get to see what is hidden under the IHS. The die is the same width as Kabylake 7700K, but it is noticeably longer. The 6-core Coffeelake-S CPU has a die size around 151mm2. This is not accurate because the calculations are based on the pixel area, but it it’s good enough for now.
This means that the i7-8700K has around 29mm2 more die area for the additional 2 cores. Every reviewer I spoke with says that 5 GHz should not be a problem on Coffeelake 8700K, especially with AIO cooling. If you want to go higher, delidding is highly recommended although risky. The LGA1151 delidding tools work for Coffeelake, so it’s only a matter of time before you start seeing videos showing the exact process (I think they should go live tomorrow).
SpoilerThe true star of 8th Gen Core series: i5-8400
Most reviewers received two CPUs, the 8700K and 8400. The latter is representing Core i5 series. Based on the reviews I saw, this processor will have an amazing performance to price ratio. This is a 6-core CPU with clock speeds up to 4 GHz. The 7800X and 6800K CPUs look really bad compared to this sub-200 USD CPU. Great value here, if there’s any CPU to go out of stock, it’s probably the i5-8400.
Core i7-8700K goes on sale
Overnight the 8th Gen Core series went on sale in UK:
Newegg is also selling the new Core series (in stock at the time of writing):
Source: HKEPC
Limited Availability Coffee lake at Launch and in Q4
It is hard to gauge whether or not it’s a bit of a click-bait from some media outlets, but granted it’s possible. Word out is that Coffee Lake processors will see limited availability at launch and the remainder of 2017.
We all know that Intel kinda rushed the Coffee lake launch forward to have an answer to AMD. The quick push forward is likely to result in limited availability of the processor series in Q4 2017 as the original launch was expected to be in Q1 2018.
The guys from SweClockers mention that they did rounds are Swedish etailers and, the word back was that they have very little stock. If that is the case on a global scale, then it will have an adverse effect on final etail pricing of course as high-demand drives up prices.It seems that Core i7-8700K, Core i5-8600K, and Core i3-8350K are on stock to some degree yet the Core i7-8700, Core i5-8400 and Core i3- 8100 have not even reached the stores yet.
Intel Coffee lake Uses Different Pin Configuration Than Kaby Lake and Skylake on the LGA 1151 Socket
ΠαράθεσηIntel added more VSS (ground) and VCC (power) pins for 8th Gen CPUs. This was not really mentioned by Intel during the press call, but apparently, the pin layout is now available explaining why it was necessary to exclude Kabylake CPUs from the support list on Z370 motherboards.
- VSS: 377 -> 391 (+14)
- VCC: 128 -> 146 (+18)
- RSVD: 46 ->25
According to Intel, LGA1151 socket on Z370 motherboards had to be modified for better power delivery for 8th Gen Core CPUs. The backward and forward compatibility questions could’ve all been avoided if Intel added at least one more physical pin or simply name the new socket as LGA1151v2. That did not happen. The electrical pin layout confirms that Coffelake has some RSVD (reserved) LGA1151 pins now occupied by VSS and VCC pins.
INTEL CORE I7 8700K & INTEL CORE I5 8600K - COFFEE LAKE + AORUS Z370 ULTRA GAMING REVIEW→lab501.ro
Another Core i7-8700K & Core i5 8600K Review Leaks
ΠαράθεσηAnother Core i7 8700K review leaks today, this time in Romania. As you guys know, most EU media isn't seeded processors for reviews anymore by Intel (it's like we do not exists to Intel). So when some media then get their hands on some samples, why then abide an embargo right?
So you can't really blame them. This time it is lab501 pushing the results as Monstru posted a review. he makes use of a Gigabyte Aorus motherboard and actually now that i notice it, also uses a Core i5 8600K. The procs do well and puch 5.2 GHz when tweaked (much to what I am seeing here). I'll leave the talking and writing to their article, below some of the benchmarks, courtesy to lab501 of course.
- 2
ASUS Announces ROG Prime and TUF Z370 Series Motherboards →guru3d.com
The Z370 motherboard guide: Coffee Lake brewed by ROG, Prime, and TUF →edgeup.asus.com
περισσότερες λεπτομέρειες
- 3
Intel to launch B360, H370 and H310 chipsets in Q1’2018
Intel H370, H310 and B360 chipsets coming Q1 2018
The slide confirms that Intel did indeed change the naming of their B_50 chipsets to B_60. As we explained this earlier, Intel had no other choice, due to the fact that AMD has already ‘borrowed’ the B350 name for their Ryzen chipset.
The H370, H310 and B360 chipsets will all arrive in the first quarter next year. The interesting part is where Intel has another Coffeelake-S CPUs coming in the same period. The difference is hidden in the TDP (95/65W changes to 65/35W). It’s hard to speculate what parts are being planned here, but Intel confirmed in a press call that Pentium and Celeron processors should be expected around that time.
Source: GamersNexus
- 2
ASRock Reveals its Z370 Chipset Motherboard Lineup
MSI Z370 Godlike Gaming & Z370 Gaming PRO Carbon
Πρώτες τιμούλεςmsi z370 godlike → ~475€
msi z370-A Pro → ~120€
- 3
Στον κινέζο πέρα από τις θερμοκρασίες και τις άλλες μετρήσεις, κάτω κάτω (με translate ) γράφει:
ΠαράθεσηDue to time constraints, we first focus on the content, first look at the 8-generation Core processor benchmark performance:
Simple summary of the stage: anyway, the eighth generation of Core's update is very surprising, but the test results we temporarily hide, and so on October 5 we once again to all the test results open to everyone ~ Please look forward to.
Σας δώσαμε μετρήσεις τα πάντα όλα 10 μέρες πριν λήξει το NDA και τώρα σας τα κρύβουμε μέχρι τις 5 Οκτώβρη!
Καλά τα click στις σελίδες αυτές, αλλά ας περιμένουμε να(όταν) βγουν τα πιο επίσημα reviews.........
και θέλουμε την οδοντόπαστα μέσα
Intel Core i7-8700K Official Performance
Since a ‘review’ of i7-8700K was already posted by Expreview, I do not think this leak will have a big value to you. What we have are official benchmark results directly from Intel’s reviewers guide thanks to our Chinese friends. Use this as a reference for upcoming reviews or compare values to your own CPU.
____________________________________________________________________________________________________________________________
ΠαράθεσηIntel officially revealed its brand new lineup of 8th generation Coffee Lake processors yesterday.Coffee Lake marks the debut of Intel’s first ever six core mainstream core i7 and core i5 parts as well as its first ever quad core i3 parts.
Intel Wants You To Buy A New Z370 Motherboard With Any Coffee Lake CPU You Choose To Buy
The new family of chips introduce higher cores counts and higher clock speeds in every product tier. With that being said, it’s not all good news. Kaby Lake owners looking to upgrade to Coffee Lake will have to buy new motherboards as Intel has decided to break compatibility with existing 200 series chipset motherboards supported by Kaby Lake.
Intel’s official statement regarding this decision is that the power delivery circuitry required some upgrades to support the higher core count processors and slightly faster DDR4 support, hence why potential buyers will need a 300 series motherboard for Coffee Lake.
ΠαράθεσηWhy This Makes No Sense
Intel was asked whether high-end Z270 motherboards with over-engineered power delivery circuitry, of which there are many, will be supported or not and the company’s official response was that no matter what Coffee Lake CPU you buy you will need to pair it with a 300-series chipset motherboard.SpoilerUpon closer inspection of Intel’s arguments we find none of them to be remotely convincing. The TDPs of Coffee Lake processors still max out at 95W, just like Kaby Lake, despite the higher core counts. Additionally, many Z270 motherboards already have beefed up VRMs to enable high overclocks and would have little trouble handling the power requirements of Coffee Lake. Furthermore, nearly all existing Z270 motherboards easily support DDR4 memory speeds far greater than 2666 MHz.
To further underline why none of Intel’s arguments for breaking compatibility make sense we needn’t go back more than a handful of years to when AMD introduced its monstrous 220W FX 9000 series CPUs. These parts had nearly double the TDP of existing FX 8000 series CPUs and required liquid cooling just to run out of the box. They also supported faster memory speeds. Instead of breaking compatibility with existing boards, the company simply certified existing 990FX motherboards that could handle the new CPUs as FX 9000 series compatible. The company has also committed to maintaining AM4 motherboard compatibility with future generations of Ryzen processors.
Truth be told the only apparent reason Intel is breaking compatibility with existing motherboards is that they’re simply after your money. Intel is a company trying to make a buck after all. If you’re upgrading to Coffee Lake from Broadwell or an older processor this doesn’t really affect you. But, we believe that this decision will only work to discourage Kaby Lake owners from upgrading to
First review of Intel Core i7-8700K leaks out
ΠαράθεσηGuys over at Expreview decided to post an early review of Intel’s Core i7-8700K, 10 days before NDA ends.
SpoilerStock clock comparison
Source: Expreview
Intel Z370 Chipset Could Support Kaby lake But Intel Will Not Allow It
ΠαράθεσηMuch has been said and spoken about Intel upcoming 6-core Coffee Lake processors. It will launch based on a LGA 1151 Socket. We’ve been able to confirm that Z370 will only support Coffee Lake processors. Here’s the shocker, they could support Kaby Lake, yet Intel doesn’t allow it.
According to some board partners the extra pins used on Z370 are merely supported voltage pahs. Ergo, (but not confirmed) perhapsvice versa Coffee lake could have been supported on Z270 as well. But this last bit remains speculation of course. But the reality is, that other processors than Coffee Lake on LGA1151 could have been supported on Z370, yet Intel simply will not allow board partners to support them.
New info also shows that the new 6-core procs can do an all-core 5 GHz overclock on a proper air cooler / liquid cooling without too much complication.
Intel Core i7 8700K Reportedly Reaches 4.8 GHz Easily, 5 GHz+ Requires Delid
ΠαράθεσηA report out of Expreview says that users should expect Intel's 8700K 6-core processor to easily clock up to 4.8 GHz with conventional cooling methods. Apparently, the chip doesn't even need that much voltage to achieve this feat either; however, thermal constraints are quickly hit when pushing Intel's latest (upcoming) leader for the mainstream desktop parts. Expreview says that due to the much increased temperatures, users who want to eke out the most performance from their CPU purchase will likely have to try and resort to delidding of their 8700K. While that likely wouldn't have been necessary with Intel's 7700K processors, remember that here we have two extra CPU cores drawing power and producing waste heat, so it makes sense that thermals will be a bigger problem.
αφού διαβάσω αυτά που θέλω στον Λάμπη, ρίχνω κι ένα βλέφαρο στα υπόλοιπα
- 2
Finally coming over to the benchmarks, we have first of all the CPU-Z test. Here, the chip is being compared to the Intel Core i7-7700K. In single threaded test, the 8700K scores 525.4 points while the 7700K scores 492 points. In multi-threaded test, the 8700K scores 3832.6 points compared to 2648 points on the 7700K. In Fritz Chess benchmark, the single thread score is reported at 3513 kilonodes while the multi-threaded score is reported at 24537 kilonodes. The Cinebench R15 score for the Intel Core i7-8700K is 1402 points with all cores and an OpenGL score is reported at 144.33 FPS.
Intel Core i7-8700K CPU Benchmarks:
Benchmark Name AMD Ryzen 5 1600X AMD Ryzen 7 1800X Intel Core i7-7700K Intel Core i7-8700K CPU-z Single Core N/A N/A 492 525.4 CPU-z Multi-Core N/A N/A 2648 3832.6 Fritz Chess One Core N/A ~2500 ~3500 3513 Fritz Chess Multi Core N/A ~20500 ~17500 24537 Cinebench R15 Multi ~1130 ~1600 ~1050 1402 3DMark Time Spy ~5800 ~7900 ~5500 7686 3DMark Firestrike ~15300 ~18400 ~14500 19250 Intel Core i7-8700K 5.3 GHz and Intel Core i3-8350K 5.0 GHz Overclock Possible On Good AIO Coolers
Now when it comes to overclocking, there are kind of mixed reports. One Chinese source has said that 5.3 GHz on the Core i7-8700K and 5.0 GHz on the Core i3-8350K are possible with simple core tuning but you would require a good AIO cooler or high-end air coolers to keep these chips cooler under load.
Expreview points out that the chips will have really low voltage which means that overclockability will be generally higher but as soon as the chips start going beyond 5.0 GHz, there’s a overheating issue. The reason cited is use of TIM (Thermal Interface Material) instead of solder. Now Intel has been using TIM on their chips for several generations but it remains to be seen just how far these chips can be pushed on standard air and liquid coolers at full load before heat becomes an issue. Expect more details on the Coffee Lake chips in the coming weeks.
ASUS ROG MAXIMUS X HERO (WIFI-AC) ASUS TUF Z370-PRO GAMING
ASUS ROG STIRX Z370-F GAMING ASUS PRIME Z370-A
- 2
Intel 8-core LGA1151 Processor For Z390 Could Be 14 nm Coffee Lake After All
ΠαράθεσηEarlier last week we talked a little about the fact that Intel will be releasing another chipset called Z390 late this year. That is next to Coffee lake 6-core processors on the Z370 platform. Some new information appeared online, and the assumption that Z390 would be for 8-core 10nm Ice Lake products seems invalid.
To step that up, it seems to be the case that intel has an 8-core 14nm Coffee Lake processor in the works. The new information surfaced from an XTU errata log is showing change-log entry that reads out as "[CFL] Added support for 8,2 core,", see below. CFL obviously is short for Coffee Lake.
ΠαράθεσηIt would be an interesting move from Intel, as typically they design one desktop processor and base all models off from that one proc. To create an additional processor holding 8-cores is very unusual. If correct, this would be a 8-core/16-threaded part in the mainstream segment, and that would mean serious competition for AMD Ryzen 7.
Intel Core i9-7980XE early benchmarks
ΠαράθεσηIntel Core i9-7980XE: early benchmarks
The benchmarks come from Coolenjoy, where we learn that the CPU was tested on ASUS APEX motherboard (designed for overclockers). What was discovered is that the CPU boosts up to 4.2 GHz on all cores during Cinebench. It’s unclear if this is a motherboard-specific feature or this is exactly how it’s supposed to be. Officially the i9-7980X should only boost up to 4.4 GHz on two cores in Turbo Boost Max 3.0 and up to 4.2 GHz in Turbo Max 2.0.
- 3
Intel Kabylake CPUs will not work with Z370 motherboards, at least not yet
Guys over at Hardware.info tested what we all wanted to know, the inter-compatibility between the sockets. The short story is that you cannot upgrade your Kabylake processor to a new motherboard (Z370), despite the fact that the motherboard has the same socket. It works both ways, because you cannot use i7-8700K CPU with the Z270/170 motherboard either, but that may just need a new BIOS. The new (Z370) motherboard should, however, already support Kabylake processors, unless, Intel had no plans for it.
A picture of Intel Core i7-8700K and 7700K was also provided. The new Coffeelake processor can be seen on the right side.
Intel Core i7-8700K Cinbench scores leaked
i7-8700K appears on Geekbench
Core i7 8700 pictured
ΠαράθεσηAt Reddit, you can find pictures of upcoming 8700 non-K variant. The CPU was pictured from both sides and compared to current (7th) generation Kabylake processor. The pin layout seems to be the same, which again raises the question why Intel is not making 8th Gen CPUs compatible with existing motherboards, at least the ones with powerful enough VRMs?
7700? 8700?
Spoiler- 1
European Core i7 8700K Coffee Lake prices Spotted in Germany
Looking at the differences we see that Coffee Lake will be a bit more expensive compared to the current Core i5 and i7 lines. The Core i7 8700K with six-cores and one thread will cost €389,- the 8600K with six cores and threads €273. Below an overview of prices, cores and frequencies. The prices listed will differ here and there a bit basically due to differences of VAT per country.
GIGABYTE AORUS Z370 motherboard specs
ΠαράθεσηThe slide you are about to see comes from the official press event of AORUS Z370 motherboards. I can assure you it’s not fake, but there is (supposedly) a big mistake here. The slide says quad-channel memory support. As far as I know, Coffee Lake-S is dual-channel only.
Εδώ (πρέπει να) έχουν κάνει λάθος για το quad channel
GIGABYTE Z370 AORUS motherboards pictured
Παράθεση
The most interesting thing about the roadmap is that it is the first public confirmation of the Z390 chipset. We have already heard a lot about the Z390 chipset but it looks like it will be replacing the Z370 chipset or will be a more better tuned design for high-performance 6 core chips in the Coffee Lake family. For users that are worried if there Z370 investment will go to waste need not to worry a lot as this chipset won’t be available until second half of 2018.
- ASRock Shows Coffee Lake SKUs on 1151 socket
πριν 8 ώρες, το μέλος minast έγραψε:Μετά την πολύ καλή εντύπωση από τους Ryzen, ομολογώ ότι δεν παρακολουθούσα πολύ στενά τις εξελίξεις στους coffee. Για την ανάγκη νέου chipset δεν σχολιάζω καν... Αλλά αφού το πήραν απόφαση και έβαλαν 6 cores στους i5, τους έπεφτε πολύ να βάλουν και HT, έστω στον 8600Κ?
Η διαφορά στους i5 με τους i7 (απ'όσο θυμάμαι) ήταν πάντα το HT, αν είχαν HT θα είχαν κι αυτοι 4c/8t.
Με τον τρόπο αυτό οι i5 (ξεκλείδωτοι) είτε θα ήταν θα ήταν το "απόλυτο vfm" στα 250-270€ και killer του ι7, είτε θα ήταν
ακριβότεροι και θα τους ονόμαζε i7.
Πρόσφατο παράδειγμα o pentium g4560 (60€) με HT 2c/4t και "παραπλήσιες επιδόσεις" με τον I3-7100 (110€).
Και επειδή είχε πολύ καλές πωλήσεις δες τι έκανε η intel (αν δεν το είχες διαβάσει)
Ανακοινώθηκαν και επίσημα οι 8ης γενιάς επεξεργαστές Core για desktop συστήματα
In Ειδήσεις
· Έγινε επεξεργασία από idonthave
Ο 8350k ένας "7600k" στα 200€ (αν και νωρίς για τις τιμές)
https://ark.intel.com/compare/126689,97144
