Είδηση Comments posted by idonthave
ετοιμάζεται επιστροφή στα κόκκινα
Intel Adds a + In the Core i5 and i7 Badges
ΠαράθεσηIntel made a slight change in the processor badges and logos. In case if you are wondering what that little + means, well, it simply means that the product is Optane ready.
It seems that Intel is going to push its partners very hard to bundle the processors and motherboards with Optane. Unfortunately, I'm afraid, it'll generate more confusion than anything else.
So in short, in combination with Optane, a manufacturer may use the new "Core i5 / 7/9 +" badges.
ASRock Teases Phantom Gaming Graphics Cards, Rumored to be AMD Radeon Powered
Whispers have been circulating the techsphere over the past couple of weeks alleging that ASRock may be entering the graphics card market soon in an exclusive partnership with AMD. There was speculation that this move may have potentially been taken by both companies in response to other AIB’s signing on to NVIDIA’s allegedly anti-competitive GeForce Partner Program which is said to preclude them from associating their high-end gaming brands with AMD.
With that being said, facts surrounding the whole debacle still remain a blend of mystery and a he said she said situation. What’s no longer a mystery however is the fact that ASRock will be entering the graphics card market. Despite some reports that have emerged in German tech media claiming that this isn’t the case, now we have definitive proof directly from ASRock that this is indeed what the company is doing.
Παράθεση
It looks like the rumors regarding NVIDIA’s Pascal GP102 going EOL hold no truth to them as a recent leak has just confirmed that mining specific P102-100 graphics cards will be hitting the market real soon.
The leak comes from the cryptomining blog who have been tipped that NVIDIA P102-100 mining specific graphics cards will be hitting market real soon. One specific variant has been fully detailed which seems to be an Inno3D discrete board.
AMD Will Send You A Free Processor To Flash Your Motherboard’s BIOS For Ryzen 2000G Raven Ridge APUs
ΠαράθεσηThe new chips are compatible with AMD’s existing AM4 socket and 300 series motherboards. However, due to the fact that Raven Ridge is based on an entirely new die, a motherboard BIOS/UEFI update is required. Otherwise the system will simply not boot. Unfortunately however, many motherboards, with a few exceptions, require that you boot up the system first to install update.
This means that even if you grab a new Ryzen APU with a compatible motherboard you might end up faced with the conundrum of a machine that won’t boot. The parts are compatible but the system will simply not start. If the motherboard that you happen to have has a clever feature to enable BIOS updates without booting up then you’re in luck. If you don’t however, fear not, AMD has you covered.
AMD Will Send You A Processor To Flash Your Motherboard’s BIOS For Ryzen 2000G Raven Ridge APUs
You can go to the company’s support page to request a “boot kit”. This kit is actually just an A6-9500 APU that the company will ship to you to boot up your system, apply the necessary update and install your new Raven Ridge Ryzen 2000G APU.
AMD Ryzen 5 2400G gets delidded and temperature tested
ΠαράθεσηOnce he successfully delidded the APU he didn't go for direct die cooling, instead, he applied Grizzly Kryonaut + Conductonaut compounds, placed back the APU and heatspreader and continued his test runs. The charts below show the temperature gains at stock clocks and when overclocked to 3975MHz. Further overclocking at the same voltage was only stable to 4000MHz, 25MHz faster, not anything significant. In our review, we reached 3.9 GHz on the stock air cooler.
- 3
τελευταία φορά που κοίταξα τιμές (πριν 1-2 βδομάδες) 1080ti η φθηνότερη στα 730-750€ (zotac), τώρα ~900€ (asus)
"από πλαίσιο οι αγορές" από εδώ κι πέρα αλλά άκυρο κι αυτό μπήκα να δω τις τιμές τους, τις πήγαν στο χιλιάρικο
Samsung 860 EVO M2 and 2.5" SSDs temporarily online at Samsung - Specs Leaked
ΠαράθεσηThe page already has been taken down but yesterday the 860 Pro 4TB surfaced, today the EVO edition says hello to the public. The page showed both a 2.5" version with a maximum capacity of 4 TB and an m.2 form factor SSD of 2 TB.
The content has been taken offline again. The M.2 models will become available in versions of 500 GB, 1 TB, and 2 TB, while the 2.5 "also sees a 250 GB and 4 TB model. The 860 EVO offers sequential transfer rates of up to 550 MB/s and up to 520 MB/s sequential writes, up to 97,000 IOPS 4K random reads, and up to 88,000 IOPS 4K random writes according to the product page.
Samsung mentions V-NAND, likely new 64-layer one. Back in October the SSDs already appeared in various databases as well. Also mentioned is that this new-generation flash has been rated for "8 times higher" thus better endurance than the 850 EVO series; with up to 2,400 TBW, for the biggest volume size SSD.
The new leak indicates a launch, very soon.
κατά πόσο ισχύουν.....(?)
- 2
Samsung 860 Pro (4TB) Shows On Company Website
ΠαράθεσηIt's likely a bit of a mistake, then again could be done to create a bit of a viral. But a new Samsung series 860 PRO SSD just turned up on the company website. The thing is, this is a 4TB model.
4TB is rather something, this means Samsung is ready with their MLC NAND from the 64-layer Vertical stacked NAND production for high volume. We're sure that in due time there will be 250, 500, 1TB and 2TB models available as well. The 4 TB models has a listed price as well, it's 1900 USD, which is 47 cents per GB.
πριν 1 λεπτό, το μέλος DEADLAZARUS έγραψε:
Εμ, έπρεπε να το καταλάβουμε απ' τη συνταγή. Μπράβο στον μεγάλο νικητή.
και χωρίς τη συνταγή το καταλάβαινες
@eXhale φαγητό θέλουμε (κανονική μερίδα) και μετά τις μνήμες
- 8
καταγγέλλω τον διαγωνισμό ο @astrolabos με έχει αναφέρει 8 φορές και κέρδισα μόνο 1 φορά το internet security
σίγουρα πρέπει να επικοινωνήσουμε μαζί του?
Spoilerθα μας στείλει για μπάνια από τώρα
- 2
συγχαρητήρια σ'όλους κι ευχαριστούμε για τα δώρα,
μια Βεργίνα και τον Ρούντολφ, για τα της 4ης βδομάδας
Spoilerαν κληρώσει ένα απ'τα μεγάλα δωράκια
Spoilerτις μνήμες τις χαρίζω
Κάποια καινούρια πληροφορία για τους consumer m.2 980(?) (αν θα βγάλει) πότε τους περιμένουμε?
πριν 1 λεπτό, το μέλος ARMAGEDDON έγραψε:
βασική ερώτηση φέτος θα κόψουμε βασιλόπιτα για το 2018 άντε και για το πέρυσι 2017 αν μαζευτούμε ?
ΠαράθεσηΕπομενο στικι εκει θα μπει σε επομενο διαγωνισμο ή κοπη πίτας
2ώρες και κάτι (στοπ)
- όπεν δε λινκ → Ο Ρούντολφ με τα δώρα του & μέϊκ φατσοlike (στοπ)
- μετά σέαρ στον τουίτι και στο φατσοbook (στοπ)
complete the tasks και θα κεράσουμε pizza, σουβλάκια και μπυρόνια (στοπ)
Spoilerτα φατσοlikes στον Ρούντολφ, όχι στο φαΐ
Spoilerπείνασα
δεν ποστάρω άλλο για σήμερα, μετά τις 00:01 πάλι
Ευχαριστούμε για τον διαγωνισμό (στοπ)
Υγεία
edit
πριν 17 λεπτά, το μέλος kpetros έγραψε:Ενα παραπονο που εχω , ειναι πως δεν εχω ερθει σε κανενα meeting , παρα το γεγονος οτι πανω κατω εχω βγαλει μια εικονα για τον καθενα εδω μεσα .... την τελευταια φορα ελεγα να κανω το βημα αλλα νιωθω πολυ akward αναμεσα σε ατομα που "τεχνικα" γνωριζω πρωτη φορα
για όλα υπάρχει η πρώτη φορά στη κοπή της πίτας, θα πέσει ban
- 5
πριν 9 λεπτά, το μέλος f117 έγραψε:
astro...μετά τις 00:00 τι θα γίνει? θα κλεισουν οι κάλπες και? καπακοτά θα βγούν οι τυχεροί?
μετά τις 00:00:00 η ζωή συνεχίζετε, ο astrolabos παίρνει τις μνήμες κι εμείς
Spoilerπάμε για μπάνια
Παράθεση
Όλα γίνονται για να πάρει τελικά τις μνήμες ο Ποιος !!
Φαίνεται και από το παρακάτω
Υπάρχει χρόνος να μαζέψετε φατσοlikes σε 8 ώρες
Spoilerτις τελευταίες 440ώρες μάζεψα 4 φατσοlike
& babies για τα μεγάλα παιδιά
Spoilerκαλή χρονιά
- 4
πριν 33 λεπτά, το μέλος tommybertsen έγραψε:
Πάλι γκρίνια;
Να πεις και στην Νεφέλη να κάνει like, αλλιώς θα το πάρω πίσω
γκρίνια mode off
over & out
- 2
ρε σεις από 19 Δεκεμβρίου μέχρι τώρα ούτε ένα like (οκ έχω πάρει 2 από τότε),
αποσύρομαι από τον διαγωνισμό (απ'τις μνήμες) , δεν σχολιάζω....... περιγράφω.. άλλο!
Spoilerθα αρχίσω να αφαιρώ τα like μου
Spoilerσελίδα 6, στο μέσον της για κανά like
Καλή χρονιά είπαμε?
Καλή χρονιά
άντε κι απ'τον καινούριο χρόνο διπλή (οι singles)
καλή χρονιά να έχουμε, υγεία
- 6
προτείνω οι φανταστικές δημιουργίες μας, να συγκεντρωθούν όλες μαζί (μιας κι έχουν "χαθεί") όταν λήξει ο διαγωνισμός,
να έχουμε Χ ψήφους ώστε να ψηφίσουμε 1,2,3... δημιουργίες/ευχές που μας αρέσουν και να βγει ο νικητής για το μεγάλο δώρο
με τις περισσότερους ψήφους, που θα είναι μπανάρισμα ούπς οι μνήμες ήθελα να γράψω!!!
Spoilerαν ζητάω πολλά κάντε πως δεν το διαβάσατε
Spoilerτώρα μπορώ να φάω ban
- Δημοφιλής Δημοσίευση
ΠαράθεσηΒάλτε το μυαλό σας και φτιάξτε κάτι καλό και πρωτότυπο γιατί βλέπω τις μνήμες να πηγαίνουν για τον επόμενο χριστουγεννιάτικο
Μιας και ζητήθηκε από τον 'αυτος 1-0' να φτιάξουμε οι καλημεράκηδες και μη "κάτι καλό" πάμε.
Ήθελε λίγο αλκοόλ η δημιουργία για να επιτευχθεί, ο Λάμπης με τα λαμπίσια δώρα του πέρα από τις μνήμες
θα μοιράσει επιπλέον έναν i7 8700k, έναν Samsung 960 evo και 16gb ram 3200mhz (samsung b-die)!!
Τα δώρα θα τα δείτε στο έλκηθρο της amstel , απαραίτητη προϋπόθεση για να τα διεκδικήσετε και
να μπείτε στην κλήρωση είναι να κάνετε like → σε τούτο εδώ το post
Ο Ρούντολφ και η παρέα του έσκασαν μύτη (τα έχουν πιει λίγο) και μοιράζουν δώρα
Σας εύχονται καλές γιορτές με υγεία
Περάστε πάρτε, απ'όλα έχει ο σάκος, ι7, ryzen 7, ripper, Vega (τρέχει σαν τον Βέγγο), Τατιάνες πράσινες,
Κροσερ, σκιλ, δίσκους, που σου γιου κλπ κλπ, περάστε πάρτε!!!
Και για να σας γλυκάνουν derby και kinder bueno.
Δεν περιγράφω άλλο
Υγεία πάνω απ'όλα
- 21
- 2
Μιας και οι συμμετέχοντες δίνουν με το σταγονόμετρο τα like, προτείνω μια αλλαγή στους όρους για το μεγάλο δώρο,
να γίνει κλήρωση από 5 like και πάνω ή όσοι δώσουν τα περισσότερα like να το κερδίσουν,
ειδάλλως θα χρησιμοποιήσω αθέμιτα μέσα
Spoilerγια παράδειγμα όσοι κάνετε like σε post μου,
θα μπείτε "σε κλήρωση για να κερδίσετε" έναν samsung 960 evo
καλές γιορτές είπαμε?
καλές γιορτές και
αγάπη μόνο
Spoilerδεν θέλω ban
Την εμφάνισή τους online, έκαναν οι νέοι NVMe SSDs της Samsung
In Ειδήσεις
· Έγινε επεξεργασία από idonthave
Samsung Releases 970 PRO and EVO m.2. SSDs
_________________________________________________
Samsung 970 EVO M.2 500GB NVMe SSD review
