Βοήθεια με NAS & Bluray Player
anubis
αυτές είναι οι ιδιότητες του .avi που παίζει
General
Complete name : Z:\# New Movies\An.2012.DVDRip.XviD.AC3.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 1.41 GiB
Duration : 1h 47mn
Overall bit rate : 1 881 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2542/release)
Writing library : VirtualDubMod build 2542/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 47mn
Bit rate : 1 423 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.260
Stream size : 1.06 GiB (76%)
Writing library : XviD 64
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 2000
Duration : 1h 47mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 343 MiB (24%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
και αυτές είναι οι ιδιότητες ενός .avi που δεν παίζει
General
CompleteName : Z:\# HD Movies\720p\Aftershock [2010] 720p BRay HD\Aftershock.2010.720p.BDRip.avi
Format : AVI
Format_Profile : OpenDML
Format_Settings : rec
FileSize/String : 3.47 GiB
Duration/String : 2h 16mn
OverallBitRate/String : 3647 Kbps
Encoded_Application : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
Video
ID/String : 0
Format_Profile : Advanced Simple@L5
Format_Settings_BVOP/String : 2
Format_Settings_QPel/String : No
Format_Settings_GMC/String : warppoint0
Format_Settings_Matrix/String : Default (H.263)
CodecID : XVID
CodecID/Hint : XviD
BitRate/String : 3194 Kbps
Width/String : 1280 pixel3
Height/String : 544 pixel2
DisplayAspectRatio/String : 2.35:1
FrameRate/String : 24.000 fps2
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bit3
ScanType/String : Progressive
Compression_Mode/String : Lossy
Bits-(Pixel*Frame) : 0.191
StreamSize/String : 3.04 GiB (88%)
Encoded_Library/String : XviD 1.2.1 (UTC 2008-12-04)
Audio
ID/String : 1
Format : AC-3
Format_Settings_ModeExtension : CM (complete main)
Format_Settings_Endianness : Big
CodecID : 2000
BitRate_Mode/String : CBR
BitRate/String : 448 Kbps
Channel(s)/String : 6 channel3
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bit3
StreamSize/String : 436 MiB (12%)
Alignment/String : Alignment_Aligned
Interleave_Duration/String : 64 ms (1.54 video frames2)
Interleave_Preload/String : 192 ms
Title : 1_3_audio
μας δείχνεις 2 τελείως διαφορετικά αρχεία όσον αφορά την ανάλυση και το bitrate, άρα η εξαγωγή συμπερασμάτων είναι αδύνατη.
να υποθέσω ότι από usb παίζουν και τα 2?
ναι, βεβαια !!! Οπως έγραψα και στην αρχή του νήματος... ο τρόπος που έβλεπα όλες αυτές τις ταινίες, ήταν είτε συνδέοντας ένα εξωτερικό δίσκο στην USB θύρα του LG, είτε μέσω του PC με το Nero MediaHome 4. Η συνταγή χάλασε όταν αντέγραψα τις ταινίες στο δίσκο του dlink και είπα στο LG να τις διαβάσει από εκεί... :(
για να μην παιδεύεσαι άδικα έχω να προτείνω το εξής:
εγκατέστησε το serviio στο PC σου και δοκίμασε εάν δουλεύουν όλα οκ. εάν ναι, πάλεψε να το βάλεις στο dlink.
χρησιμοποίησες πολύ σωστή λέξη : "πάλεψε" :)
διάβασα το tutorial και απελπίστηκα ! :)
εγκατέστησα το serviio στο PC μου, πρόσθεσα στο library το δίσκο του dlink, ξεκίνησα το server, το bluray τον έδειξε στη λίστα, και έπαιξε όποιο αρχείο και να του έβαλα. Να υποθέσω ότι είναι θέμα αποκωδικοποίησης του NAS λοιπόν? Εφόσον με USB πάνω στο bluray player παίζει τα πάντα, με server πάνω στο PC παίζει τα πάντα... φταίει επομένως η "ανάγνωση" των αρχείων από τον εσωτερικό server του NAS? Συγγνώμη αν ακούγομαι πολύ Newbie, αλλά έχω καιρό να ασχοληθώ με multimedia και το έχασα το παιχνίδι μάλλον... :(
αυτό σημαίνει ότι το πρόβλημα είναι στην DLNA εφαρμογή του NAS. συνεπώς, εάν έχεις εξαντλήσει το θέμα των ρυθμίσεών της, η εγκατάσταση serviio ή twonky είναι μονόδρομος.
Μια καλή λύση είναι και το Plex.
To έχω εδώ και 4 μήνες σε βάση με 465 ταινίες και λειτουργεί αψογα.
το πρόβλημα με το Plex είναι ότι αν πας να το κατεβάσεις για NAS, βγάζει εκδόσεις για 5-6 εταιρείες (Synology, Qnap κλπ) και δεν έχει μέσα τη D-Link. Θα προχωρήσω βήμα-βήμα τη λύση εγκατάστασης του Serviio στο NAS μου και βλέπουμε...
ναι, το είδα το θέμα της ταχύτητας... αλλά με €73 που πήρα το dlink.. δεν έπαιρνα τίποτα άλλο !!
λοιπόν... εγκατέστησα το srviio στο NAS βήμα-βήμα σύμφωνα με το tutorial που μου υπέδειξε ο GriGas και τώρα βλέπω τον serviio server στη λίστα των συσκευών στο BluRay. Τον επιλέγω, πηγαίνω στο φάκελο Video και βλέπω όλους τους φακέλους που πρέπει να υπάρχουν (Directors, actors, Series, folders κλπ). Επιλέγω Folders και μου λέει "Empty". Εν μέρει είναι λογικό γιατί όλη η εγκατάσταση του server έγινε στο Volume_1 του NAS, ενώ τα αρχεία μου είναι στο Volume_2. Τι κάνω τώρα...? Έλα, λίγο ακόμη έμεινε για να δω ταινιούλες... :)
Σε πρώτη φάση πρέπει να δηλώσεις το πού βρίσκονται τα αρχεία σου. λογικά σε ΄μια διεύθυνση του τύπου ip.tou.nas/serviio/ θα βρεις την κονσόλα ρυθμίσεων. από εκεί στην καρτέλα library θα ορίσεις το πού θα ψάχνει για αρχεία. ανάλογα με το πλήθος των αρχείων και τα metadata που θα πρέπει να κατέβει (και δεδομένου ότι το nas σου είναι αργό) μπορεί να κάνει από λίγα λεπτά έως μερικές ώρες για να ενημερωθεί πλήρως.
σε περίπτωση που έχεις πρόβλημα με την κονσόλα, εάν σου βρίσκεται συσκευή android μπορείς να δοκιμάσεις να κάνεις την ρυθμίσεις με την εφαρμογή servidroid.
αυτά για την ώρα... δοκίμασε και εδώ είμαστε!
επανέρχομαι, μετά από μεεερες παιδέματος. Εγκατέστησα -όπως ξαναείπα- το serviio στο NAS, αλλά δεν είχα ποτέ πρόσβαση στο WebUI της εγκατάστασης, λόγω του ότι δεν υπήρχε εγκατάσταση Apache server, ώστε να μου ανοίξει και να κάνω τις απαραίτητες ρυθμίσεις για Libraries αρχείων κλπ. Anyway, εγραψα στους τύπους του forum, με "έγραψαν" κι αυτοί ΚΑΝΟΝΙΚΑ και... σταμάτησα να ασχολούμαι με το θέμα ! Μια ερώτηση, αφού έχω ΗΔΗ απεγκαταστήσει serviio Κλπ...
Διάβασα σε ένα forum της Dlink ότι "Someone correct if I am wrong but the NAS box has nothing to do with encoding or decoding files. This is all done by your TV, PS3 or what ever your trying to use to view media files. "
Αρα... μήπως παιδεύομαι αδίκως και για το μήνυμα "Cannot play this file" του LG... φταίει το LG ??????????
edit: μάλλον δεν ισχύει αυτό, γιατί αν δεν μπορούσε να παίξει τα αρχεία το Player, δε θα τα έπαιζε κι από το USB δίσκο, έτσι δεν είναι ? ;)
α! μια λεπτομέρεια που μπορεί να σας πει κάτι...:
όταν του βάζω να παίξει mkv... μου βγάζει κατευθείαν το μήνυμα Warning : Cannot play this file", ενώ όταν του βάζω mp4, κάνει περίπου 10 δευτερόλεπτα να το πετάξει...!!! :angry:
