  • astrolabos
    astrolabos
    Phanteks announces new products at Computex 2023
    Phanteks, a leading manufacturer of computer components and accessories, has announced the launch of its latest range of products at Computex in Taipei, Taiwan. Two new chassis will be added to the NV series line, the full tower NV9 and the mid-tower NV5. Extending the Revolt series power supplies with unique cableless options, Phanteks has collaborated with world renowned cable brand, CableMod. New high performance all-in-one CPU water cooling solutions are seen with Glacier One D30 models which include a larger 420mm variant with D30-140 fans. Wrapping up the announcements from Phanteks will be a Premium GPU bracket which has the ability to be set at an angle and is complemented with integrated lighting.
    NV9 – BIGGER AND BETTER
    Introducing the NV9 chassis, a premium full tower with bigger and better features than its predecessor, the NV7. Accommodating up to 12x 120mm or 11x 140mm fans, the NV9 has near-seamless tempered glass panels for a clear view of your hardware. It boasts direct GPU cooling, with support for three 420 radiators and up to 480 radiators on the side, ensuring optimal performance.
    The NV9’s hinged rear door is similar to that of the NV7, providing a clean cable management system that delivers a cable-free setup. Additionally, the NV9 incorporates integrated DRGB lighting control with dual channels making it easy to expand and synchronize. With its exceptional features, the NV9 promises an unparalleled user experience.
    NV5 – THE NEW MID TOWER
    Available September 2023
    Meet the NV5 mid-tower chassis, featuring a stunning near-seamless glass view and support for 8x 120mm fans and space for a 360 radiator in the top and side for optimal cooling. With a dedicated bottom fan for enhanced GPU cooling and spacious interior to accommodate modern GPUs and cables, the NV5 is designed to excel. Its PSU cover opens for easy cable management, and its DRGB lighting system is customizable and easy to sync. With its sleek design and convenient features, the NV5 is the perfect choice for a high-performance PC build that looks as good as it performs.
    Available August 2023
    REVOLT POWER SUPPLIES – CABLEMOD COLLABORATION
    Extending the Revolt Series power supplies, Phanteks will offer a power supply without cables for users who want custom cables from CableMod. The new Revolt power supplies give you complete control to choose which power supply and which cables you need, saving needless cables in the process.
    The Revolt power supplies from Phanteks have been developed with Seasonic to ensure the highest standards of performance and reliability. All models fully support and exceed the latest Intel ATX 3.0 specifications and come with either 80 Plus Platinum or Titanium certification. Wattage capacity ranges from 1000 Watt all the way up to 1600 watt.
    Not only will the Revolt Series power supply perform flawlessly with its build quality, but when matched with custom cables from CableMod, a truly unique system can be created.
    GLACIER ONE D30 & D30-140 FANS
    Available July 2023
    The Glacier One D30 AIO cooler is a high-performance cooling solution that offers a smooth D-RGB lighting solution thanks to the D30 fans. The Glacier One D30 AIO cooler equipped with D30 fans, can be daisy-chained and controlled through a single cable. Its large copper base and fin array make it suitable for use with high-end CPUs, while its design allows for maximum clearance with motherboard and RAM components. The cooler is available in both 360 and 240 models, providing builders with a range of options to suit their needs. With its advanced features and sleek design, the Glacier One D30 is an excellent choice for those seeking a reliable and efficient AIO cooler for their PC builds.
    The new D30 fans are now available in 140mm and bring a multitude of innovations from the D30-120. The D30-140 features bridge connector clips, screw covers, and single cable connector to make your system looker cleaner and installation much easier. The HALOS lighting ring reflects on both sides of the fan blades while the clips and covers link multiple D30-140 fans together as one. Like the D30-120, the D30-140 will be available in black and white as well as normal and reverse models.
    PREMIUM GPU BRACKET
    The Premium GPU bracket combines flexibility and style to bring focus to graphics cards in a way only Phanteks can. The bracket is fully supported in vertical orientation but can also be adjusted up to 30 degrees to create a visually appealing display. With its RGB lighting feature, the bracket adds a vibrant and eye-catching element to your gaming setup, enhancing the overall aesthetics and creating a visually stunning experience. Whether a hardcore gamer or a dedicated PC enthusiast, the Premium GPU bracket delivers outstanding functionality that will ensure a system that stands out from the crowd.
