λιγο Math of Exile στα armour και evasion mechanics :rubik:
[ame=http://www.youtube.com/watch?v=7OoAJda587g]PoE Math - Armor - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=kEKMg5-ezeo]PoE Math - Evasion - YouTube[/ame]
Version 1.1.2:
Content and Features:
  • Added support for checkpointing. When you die in a non-hardcore league, you can choose between reviving in town or reviving at the last checkpoint. Checkpoints are made when you enter new areas or use internal teleporters within an area.
  • Added a new corrupted Skill Gem - Vaal Storm Call: Sets a marker at a location. While the marker remains, lightning strikes random enemies near it, dealing damage to them. After a short duration, a large bolt of lightning strikes the marker, dealing damage around it. When this happens, it will also set off the lightning at any other markers from this skill.
  • Added a new Intelligence skill - Glacial Cascade: Icicles emerge from the ground in a series of small bursts, each damaging enemies caught in their area.
  • Glacial Cascade is first available to the Witch, Templar, Shadow and Scion from "The Caged Brute" in Normal difficulty.
  • Added a new Dexterity/Intelligence Support Gem - Block Chance Reduction: This is a recipe-only support gem intended to have a PVP focus. It reduces the chance to block or spell block supported skills.
  • Added five new Unique items, four of which were designed by our supporters. One of the new Uniques is a map.
  • Added two new cosmetic microtransactions: Seraph Weapon Effect and Seraph Footprint Effect.
  • New recipes have been added for the Block Chance Reduction Support Gem, and the new low level quiver unique. The recipe for Cartographer's Chisels has been extended.
  • Ground Slam's visual effect has been updated.
  • 3d art has been added for the following items: Atziri's Splendour, Rearguard, Drillneck and the alternate art Blackgleam.
  • Added two new achievements: "Hostile Territory" and "Behold My Army".
  • Introduced two new Rogue Exiles: a Templar and a Scion.
  • Introduced two new Invasion Bosses into the pool of Invasion Bosses.
  • Added a new Map Mod - Antagonist's: Rare Monsters each have a Nemesis mod.
  • Several corrupted secret area bosses and Invasion bosses have new visual effects.
  • Flamebearers in the Sceptre of God now have a new golden skin.
Balance:
  • Substantially rebalanced Invasion bosses, including changing their abilities. Many of the more extreme ones are now easier. Corrupted secret area bosses and Rogue Exiles were also updated in this process.
  • Arc and Vaal Arc have had their damage increased by 60%. Arc and Vaal Arc can now no longer chain back to the same target immediately, but must now bounce one more time. Arc now increases in chain counts as the gem increases in level.
  • Poison Arrow's damage has been increased by 8% at level 1, scaling up to an increase of 75% at level 15 of the gem.
  • Reduced Cleave penalty from -30% to -20%.
  • Shockwave Totem's pulses have been sped up from 0.75 seconds to 0.60 seconds each.
  • Arctic Breath's damage has been increased by 42% at level 1, up to an increase of 95% at level 15.
  • Flesh Offering now grants 30% attack, movement and cast speed at level 1, up to 40% at level 21 of the gem.
  • Glacial Hammer now has specific PvP raw scaling, so that it does 30% less damage in PvP situations. This is on top of existing PvP scaling.
  • Smoke Mine no longer teleports your minions with you when detonated.
  • Monster versions of Molten Shell now require more damage to set off at higher levels.
  • The "of Fracturing" map mod now gives 30% additional quantity and has been made rarer.
  • Undying Evangelists now appear less frequently within their packs.
  • Undying Evangelists' Proximity Shields have a shorter duration, and they use it less often.
  • Atziri now removes curses correctly when she enters her mirror phase.
  • Increased the drop rate of rare Vaal Fragments.
  • Reduced the drop rate of Vaal Orbs.
  • Some Rogue Exiles now use Vaal skills.
Bug Fixes:
  • Fixed a bug where using Desecrate in the Eternal Laboratory in the Invasion League would generate different monster corpses than in other leagues.
  • Fixed a bug where Chain and Fork did not work correctly with Vaal Power Siphon.
  • Fixed a bug where Dominus in the Palace Map did not correctly trigger his monster spawners when entering his second phase.
  • Fixed a bug where aura skills linked with totems and trigger gems could be cast manually in addition to being triggered.
  • Fixed a bug where Demigod's Bounty had no vendor sell price.
  • Fixed a bug with Strongbox monster spawning where some monsters would fail to be created.
  • Claw Nodes in the Shadow and Ranger areas have had their art corrected.
  • Fixed a bug where Exiles that were supposed to have the Resolute Technique Keystone were not always hitting.
  • Fixed a bug in Capture the Flag where, if a player died while converted, he would resurrect on the wrong team.
  • Unset Ring's 2D Art has been corrected to not be the same as that of the Voideye unique.
  • Fixed a bug where you could not get to The Desecrated Shrine in Descent races.
  • Fixed a bug where Sarn Arena announcements did not attribute minion kills correctly.
  • Fixed various issues with the sync and functionality of Atziri's Flameblast.
Μολις εκανα 6 socket την Lightning Coil μου και ανεβαζω ele buzzsaw να κανει παρεα τον ele wander μου, μιας και αρκετα gems και αντικειμενα ειναι κοινα. Απο drops χαλια μαυρα αν εξαιρεσουμε υψηλους χαρτες απο κιβωτια με +5 level. Τωρα ειμαι στη διαδικασια για reroll κιβωτια για guaranteed unique σε μεσου επιπεδου χαρτες.
Sent from my GT-N7100 using Tapatalk
Version 1.1.2:
[*]Arc and Vaal Arc have had their damage increased by 60%. Arc and Vaal Arc can now no longer chain back to the same target immediately, but must now bounce one more time. Arc now increases in chain counts as the gem increases in level.
:magic:
Rest in Peace 83lvl hybrid summoner . 4k life 1.5κ es gone with the wind με one-shoοted απο invader . Αν και την είχα ψιλοβαρεθεί ηταν αδικία :p Ώρα για crit ranger πάλι .
BTW Εκανα και ενα rebuild την 91lvl Legacy Kaom's Heart Ranger στο softcore σε bloodmagic απο skill tree . 7k life 30k dps frenzy 8k dps splitt arrow chain χωρίς καμία αύρα και 700++ life regen με τις bloodDance
Έγινε επεξεργασία από Athens2004
Μάλλον ηταν ο ancient constructor ( ηταν offscreen αλλα 99% ηταν αυτος ) και το map με ενα mod μονο extra projectilles ( το mod που τον ευνοεί πιο πολύ ) απλα μου εκανε εντύπωση γιατι την είχα με +70chaos res ( και τα υπόλοιπα 77-77-77) οποτε ηταν critical και πηρε το dmg και απο τα 3 projectiless του mod.
  • 3 weeks later...
Το έβαλα απόψε, μια κι ένας φίλος το πρότεινε για καλό δωρεάν.. κόλλησα για 1-2-3 ώρες στο standard με έναν duelist αν δεν κάνω λάθος.. προσπαθώ να έχω strength και dexterity.. πρέπει να έχω φτάσει 4-5lvl.. καλό! :woot:
Στην αποστολή με τους bandits Act2 τι επιλογή προτείνετε και για τις 3ς δυσκολίες ; :hmmm:
Ranger & Duelist builds.
From May 10 to 24 (US time), we'll be running a two week Path of Exile Ambush/Invasion race event to benefit the Child's Play charity. Child's Play is a charitable organisation that raises money to provide toys and games for children in over 70 hospitals worldwide.
To support the charity, we're introducing an exclusive new helmet skin called the Angelic Mask. It's only available during the two week event and 100% of the proceeds will be directly donated to the Child's Play charity on your behalf. It's priced at $5 which is hopefully a nice easy amount that everyone is comfortable donating. It goes on sale when the event starts this coming weekend.
Event Prizes:
Due to the generosity of our gaming hardware partners, we have some awesome prizes to give out. We've tried hard to make sure that everyone has a chance to win these hardware prizes, so we've pitched them at lower levels of participation.
We'll pick winners randomly from the people who reach the following levels or higher. The prize levels continue to stack as you level up. You can win prizes from multiple tiers.
Prizes available in the random draw include:
  • Level 15: 100x Stash Tab Bundles
  • Level 20: 100x Premium Stash Tab Bundles
  • Level 25: 10x Razer Mice
  • Level 30: 5x Razer Keyboards
  • Level 35: 5x NVIDIA High-performance Graphics Cards
  • Level 50: 10x Sets of all Seraph Microtransactions (Armour pieces, Wings, Weapon Effect and Footprint Effect)
  • Level 65: 5x Sets of Signed Prints of Original Early Concept Art
  • Level 85: 1x One hour private Q&A on Skype with Chris, Jonathan and Erik
In addition, the top 5 players (ranked by experience) will receive an Alternate Art Demigod's Bounty unique item.
Specific Information:
  • This event has the properties of both the Ambush and (recently rebalanced) Invasion challenge leagues. That means that you'll encounter enchantable Strongboxes, guest monsters and Invasion bosses as you compete. It's parented to the Invasion league, so you'll be able to continue your character in that league once the race ends.
  • The two-week race will start at 1pm PDT on Saturday, May 10 and end exactly two weeks later at 1pm PDT on Saturday, May 24. This is 4pm EDT, 10pm CEST and 8am Sunday morning in New Zealand.
  • It's good to arrive ten minutes early to create a character in the right league. Just run Path of Exile, log into your account and you'll see the event on the list below the character list (from around half an hour beforehand). Click "Join" and create a character in the event. You won't be able to move until the event starts.
  • Race events like this are a self-contained economy - you won't be able to access your existing characters or stash. When the event ends, your race characters and stash will be moved to the Invasion league. If any characters die during the race, then they will be moved to the Standard league.
  • If you're interested to read more about the rules of race events, check out this link.
  • While it is a hardcore event, which means that your character is eliminated when it dies, we've made sure that dead characters will still receive prizes. There's nothing stopping you from pushing for the highest prize tiers and giving it another shot if you want to try to beat your previous character.
Other Rules:
  • The single highest level character in this league on your account will be considered.
  • Do not enter with multiple accounts - this will disqualify you.
  • GGG Staff members are not eligible for prizes.
Tomorrow's Build of the Week video shows an example character build that would work well in this event. If you (or your friends) are struggling to work out what build to play, then give it a shot with this one.
We'll be updating this thread with more information as it becomes available. We'll create a link to purchase the Angelic Mask (with all proceeds going to the Child's Play charity) once the event starts. We really look forward to seeing you there!
2 σπαστικά πράγματα μετά από αρκετές ώρες λιώσιμο...
1) γιατί δεν έχει κάτι σαν waypoint να σου δείχνει ΠΟΥ ΝΑ ΠΑΣ! Έχω βαρεθεί να τριγυρνάω προσπαθώντας να κάνω κάποια quest.. και δε βρίσκω κ πουθενά ΠΟΥ ΝΑ ΠΑΩ! Σε κάνα site πχ.. μπαίνεις σε ένα κτήριο κ πρέπει να γυρίσεις και τους 3 ορόφους για να πας εκεί που πρέπει τελικά; Ήμαρτον...
2) Έφαγα ένα disconnect πάνω στο καλύτερο.. ξανά από την αρχή :wall:
επίσης υπάρχει τρόπος να βλέπω περισσότερο χάρτη; πάντα έτσι στα σκοτεινά θα πηγαίνω; και όσο κι αν ανακαλύψω από έναν χάρτη.. πάντα θα μπορώ να δω γύρω μου μόνο;
τέλος αυτά τα orb of transmutation ΠΟΥ ΕΙΝΑΙ και θέλω να αγοράσω πράγματα;;;
Κατά τ'άλλα... για free gane παιχνιδάρα.. και μεγάλο κόλλημα! Ή είχα καιρό να παίξω τέτοιου τύπου παιχνίδι...
1) εννοείς να σου δείχνει βελάκι προς τα που; hc game είναι γι'αυτό :p
2) εαν είσαι σε party σου κάνουν portal και είσαι οκ.. αλλιώς έχεις κάποιο χρονικό όριο πριν κλείσει το instance που άνοιξες.. (με ctrl+click ανοίγει new ή επιλέγεις που θες να μπείς..όπως και στα tp)
3) με τα arrow keys κουνάς το map (δεν είχες παίξει diablo; :p) - σκοτείνα εννοείς; το light radius; ναι πάντα γύρω σου, γι'αυτό το κάνει απρόβλεπτο χωρίς να ξέρεις τι είναι γύρω σου.
Δες εδώ να έχεις μια ιδέα περί vendor: Vendor recipes - Path of Exile Wiki
και quest rewards: Quest Rewards - Path of Exile Wiki
αργώ να απαντήσω αλλά έρχομαι μετά από εβδομάδα διακοπών σε μέρος που με το ζόρι είχε ρεύμα (πόσο μάλλον νετ)
1) ναι κάτι τέτοιο.. ή στο περίπου ένα σημάδι για το πού πάω περίπου.. hc τι είναι;
2) δεν είμαι σε party.. αξίζει να είμαι; υπάρχει κάποιο "αξιόλογο" κέρδος από κάτι τέτοιο; αποφεύγω να μπω, μια και μπαίνοντας σε κάτι τέτοιο, έρχονται κι οι "υποχρεώσεις".. κ δεν έχω καιρό για τέτοια..
3) ντρέπομαι που το λέω αλλά όχι :whistle2: αλλά αν είναι έτσι κ πιο καλό, θα μπει σε λίστα αναμονής για λιώσιμο.. ναι, αυτό εννοώ.. πως βλέπεις λίγα πράγματα και στην ουσία, ποτέ δε βλέπεις ΟΛΟ το χάρτη μιας περιοχής, οπότε δε μπορείς να θυμάσαι κι επακριβώς από που πέρασες για να μην ξαναπεράσεις.. να χαράξεις μια πορεία βρε αδερφέ.. ευτυχώς μένουν τα κουφάρια των τεράτων κ φαίνεται από πού πέρασες ήδη..
για τα λινκ ευχαριστώ.. αυτό με τα quest rewards το είχα, αλλά αυτό με τα vendor κλπ θα χρειαστεί...
Επίσης ήθελα έναν μπούσουλα για το ΤΙ ΕΙΝΑΙ ΠΙΟ ΚΑΛΟ για να έχει ο χαρακτήρας μου.. συνήθως όποτε περάσω από "μαγαζάκι" ψωνίζω κάτι λίγο καλύτερο.. αλλά two handed sword ή ace ή axe; Ή ότι προτιμώ; Ή σπαθί κ ασπίδα; Για duelist μιλάμε πάντα.. δεν ξέρω τι βολεύει ή τι μου δίνει καλύτερα boost.. απλά γνωρίζω πως κατευθύνομαι προς μεγαλύτερο dexterity κ strength..
όχι...χεχε είναι hardcore game αυτό εννοώ και επίσης δεν είναι user-friendly. Όπως και επειδή υπάρχουν τα races που το κάνει πιο ενδιαφέρον στον ανταγωνισμό, απ'ότι θα είχε σημαδάκια προς τα που να πας (εκτός από τα fixed-seed races - όλο το map ανοιχτό)
Αν πρόσεξες, στα areas που μπαίνεις κάθε φορά είναι τελείως αλλαγμένο το pattern-tiles. Εχεί χιλιάδες συνδιασμούς, τελείως randomized για να μην ξέρεις προς τα που να πας :p
Καλύτερα solo στην αρχή να πηγαίνεις με το πάσο σου, για να μην σε τρέχουν στο group.
Περιέργο που δεν είχες παίξει...αλλά το συγκεκριμένο είναι πιο πολύπλοκο από κάθε άλλο arpg, καθώς για να μάθεις τα βασικά και τι παίζει, πρέπει να αφιερώσεις πάρα πολλές ώρες. Δεν είναι απλά μπαίνω μέσα με ένα σπαθί και σφάζω τα πάντα! :p (για τέτοιο στυλ δες d3-torchlight-grim dawn)
Πιστεύω να έχεις καταλάβει ότι δεν είναι class-based..και είναι περισσότερο από πιο σημείο του tree ξεκινάς σε αναλογία με τι build θες να παίξεις, skill gems κτλ :)
Μπορείς να κάνεις από duelist low-life/vaal pact με dual-totem phys/frenzy wand - αντί για το συνηθισμένο επειδή λέει duelist πρέπει να είναι melee κτλ.. δηλαδή έχει τρελό build diversity :jump:
Δες και αυτό για να ξέρεις τα skill gems, τα level τους, μέχρι που θες να τα ανεβάσεις, τα quality τι δίνουν κλπ
Skills - Path of Exile Wiki
Τώρα για το τι είναι πιό κάλο :crazy: δύσκολα..δεν έχει boost.. απλά συνέχισε να παίζεις, να μπείς στο νόημα του..Τα πρώτα πάντως build που θα κάνεις μόνος σου θα είναι σίγουρα "λάθος", θα σου πρότεινα να δεις κάποιο build-guide από το forum του site και εδώ ότι θες help κλπ:meeting:
